FOSSVPS.org is born!
2»
    Progress: The FOSSVPS server kindly donated by Alexhost showed disk issues, so Alexhost kindly replaced some of the 8 disks and reinstalled the server. I'm delighted to say that the server now is up again. Thanks Alexhost! <3
    I have to double check what I can, and then try making some VPSes to give away. More soon!
    ---------------------------------- nws.sh ---------------------------------
          A simple script to bench network performance using speedtest-cli
     Version            : v2025.07.08
     Global Speedtest   : wget -qO- nws.sh | bash
     Region Speedtest   : wget -qO- nws.sh | bash -s -- -r <region>
     Ping & Routing     : wget -qO- nws.sh | bash -s -- -rt <region>
     Basic System Info
     CPU Model          : Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz
     CPU Cores          : 40 @ 1200.000 MHz
     CPU Cache          : 25600 KB
     AES-NI             : ✔ Enabled
     VM-x/AMD-V         : ✔ Enabled
     Total Disk         : 2.1 TB (5.2 GB Used)
     Total RAM          : 251.8 GB (2.2 GB Used)
     Total Swap         : 2.0 GB (0 Used)
     System uptime      : 0 days, 7 hour 28 min
     Load average       : 0.12, 0.11, 0.35
     OS                 : Ubuntu 24.04.3 LTS
     Arch               : x86_64 (64 Bit)
     Kernel             : 6.8.0-71-generic
     Virtualization     : NONE
     TCP Control        : cubic
     Basic Network Info
     Primary Network    : IPv6
     IPv6 Access        : ✔ Online
     IPv4 Access        : ✔ Online
     ISP                : Alexhost SRL
     ASN                : AS200019 ALEXHOST SRL
     Host               : Alexhost SRL
     Location         Latency     Loss    DL Speed       UP Speed       Server
     ISP: Alexhost
     Nearest          0.64 ms     N/A     284.13 Mbps    284.28 Mbps    Orange Moldova SA - Chisinau
     Bangalore, IN    174.67 ms   0.0%    289.44 Mbps    260.64 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      187.23 ms   0.0%    274.00 Mbps    272.04 Mbps    Jio - Chennai
     Mumbai, IN       159.83 ms   0.0%    299.65 Mbps    275.29 Mbps    Melbicom - Mumbai
     Seattle, US      181.19 ms   N/A     287.04 Mbps    276.38 Mbps    Comcast - Seattle, WA
     Los Angeles, US  171.53 ms   0.0%    292.18 Mbps    285.42 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       152.71 ms   0.4%    284.27 Mbps    281.72 Mbps    Hivelocity - Dallas, TX
     Miami, US        148.80 ms   0.0%    292.21 Mbps    279.80 Mbps    Telxius - Miami, FL
     New York, US     115.28 ms   0.0%    297.62 Mbps    282.13 Mbps    GSL Networks - New York, NY
     Toronto, CA      130.10 ms   0.0%    291.67 Mbps    253.13 Mbps    Rogers - Toronto, ON
     Mexico City, MX  222.00 ms   N/A     267.84 Mbps    278.68 Mbps    INFINITUM - Ciudad de México
     London, UK       54.15 ms    0.0%    287.27 Mbps    236.26 Mbps    VeloxServ Communications - London
     Amsterdam, NL    45.72 ms    0.0%    289.98 Mbps    276.30 Mbps    31173 Services AB - Amsterdam
     Paris, FR        45.69 ms    N/A     293.42 Mbps    257.81 Mbps    Axione - Paris
     Frankfurt, DE    45.81 ms    0.0%    289.38 Mbps    241.47 Mbps    Clouvider Ltd - Frankfurt am Main
     Warsaw, PL       55.17 ms    0.0%    286.93 Mbps    280.15 Mbps    Play - Warszawa
     Bucharest, RO    34.79 ms    0.0%    287.44 Mbps    287.16 Mbps    Vodafone Romania Mobile - Bucharest - Bucharest
     Moscow, RU       FAILED
     Jeddah, SA       114.97 ms   0.0%    295.26 Mbps    258.29 Mbps    Saudi Telecom Company
     Dubai, AE        158.79 ms   N/A     305.93 Mbps    281.03 Mbps    e& UAE - Dubai
     Istanbul, TR     73.33 ms    0.0%    289.50 Mbps    271.01 Mbps    Turkcell - Istanbul
     Tehran, IR       109.09 ms   0.0%    262.78 Mbps    274.22 Mbps    Irancell - Tehran
     Cairo, EG        92.08 ms    0.0%    296.06 Mbps    254.58 Mbps    Telecom Egypt - Cairo
     Tokyo, JP        256.51 ms   87.0%   301.21 Mbps    20.42 Mbps     GSL Networks - Tokyo
     Chengdu, CM-CN   FAILED
     Hong Kong, CN    245.14 ms   0.0%    285.43 Mbps    119.32 Mbps    Misaka Network, Inc. - Hong Kong
     Singapore, SG    FAILED
     Jakarta, ID      202.02 ms   1.3%    275.62 Mbps    284.93 Mbps    PT Solnet Indonesia - Jakarta
     Sydney, AU       285.11 ms   0.0%    314.66 Mbps    278.45 Mbps    Aussie Broadband - Sydney
     Avg DL Speed       : 289.27 Mbps
     Avg UL Speed       : 255.80 Mbps
     Total DL Data      : 10.56 GB
     Total UL Data      : 8.30 GB
     Total Data         : 18.86 GB
     Duration           : 12 min 32 sec
     System Time        : 05/08/2025 - 20:53:09 MSK
     Total Script Runs  : 119962
     Result             : https://result.nws.sh/r/1754415806_BCVECL_GLOBAL.txt
  • Congrats on, erm, giving birth.... Did not know men could do that, but this is 2025 afterall!
    Anyway, whats the IP situation over there? IPv6 with NAT IPv4 or just NAT IPv4 only?
    Seems like with increasing price of IPv4, more and more low end host is opting for IPv6 VPS, which is great news for IPv6 adapters :D
    So far all the server donors have kindly included a few extra IPv4s, like a routed /29 or a /28, or some on-link IPv4s.
    We've been giving out IPv4 + IPv6 VPSes.
  • @somik said: Sir, with all due respect, you are old
    oh c'mon, with his profile pic, you think he is gen alpha? :D
    With that logic, you are a talking triangle with no mouth, just an eye :D
    Thanked by (2)terrorgen Not_Oles
    I am the all seeing eye!
    Thanked by (2)Not_Oles somik
    Here is some definite progress. I just logged into the first Alexhost VPS made by hand with cloud-init and virt-install.
    Welcome to Ubuntu 24.04.2 LTS (GNU/Linux 6.8.0-64-generic x86_64)
     * Documentation:  https://help.ubuntu.com
     * Management:     https://landscape.canonical.com
     * Support:        https://ubuntu.com/pro
     System information as of Thu Aug  7 01:37:27 UTC 2025
      System load: 0.05              Memory usage: 9%   Processes:       137
      Usage of /:  8.6% of 18.33GB   Swap usage:   0%   Users logged in: 0
    Expanded Security Maintenance for Applications is not enabled.
    0 updates can be applied immediately.
    Enable ESM Apps to receive additional future security updates.
    See https://ubuntu.com/esm or run: sudo pro status
    The list of available updates is more than a week old.
    To check for new updates run: sudo apt update
    The programs included with the Ubuntu system are free software;
    the exact distribution terms for each program are described in the
    individual files in /usr/share/doc/*/copyright.
    Ubuntu comes with ABSOLUTELY NO WARRANTY, to the extent permitted by
    applicable law.
    To run a command as administrator (user "root"), use "sudo <command>".
    See "man sudo_root" for details.
    ubuntu@testvm1:~$ date
    Thu Aug  7 01:37:41 UTC 2025
    ubuntu@testvm1:~$
    Now for some more testing! And then make more VPSes! Then give VPSes away!
    Thanks Alexhost! <3
    Thanked by (1)babywhale
    edited August 2025
    Here's a Yabs from the initial testvm1 on FOSSVPS' Alexhost server!
    Thanks to Alexhost for their kind donation! <3
    Probably I will make some more of these, maybe 4 cores, 4 GB RAM, and 100 GB disk? Then give them away.
    Maybe I will write a recipe for LES Talk about how I made this test VPS with cloud-init and virt-install.
    I want to check on the disk caching. My guess is that this server has a pretty conservative disk cache setup. With conservative caching, plus RAID 10, the server ought to be pretty reliable if there is a power outage or another disk problem.
    Fri Aug  8 00:56:00 UTC 2025
    Uptime     : 0 days, 0 hours, 32 minutes
    Processor  : Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz
    CPU cores  : 2 @ 2800.038 MHz
    RAM        : 1.9 GiB
    Swap       : 0.0 KiB
    Disk       : 19.3 GiB
    Distro     : Ubuntu 24.04.3 LTS
    Kernel     : 6.8.0-64-generic
    ISP        : Alexhost SRL
    Host       : Alexhost SRL
    Country    : Moldova
    Read       | 184.59 MB/s  (46.1k) | 1.99 GB/s    (31.1k)
    Write      | 185.07 MB/s  (46.2k) | 2.00 GB/s    (31.3k)
    Total      | 369.67 MB/s  (92.4k) | 4.00 GB/s    (62.5k)
    Read       | 2.15 GB/s     (4.2k) | 2.34 GB/s     (2.2k)
    Write      | 2.26 GB/s     (4.4k) | 2.50 GB/s     (2.4k)
    Total      | 4.42 GB/s     (8.6k) | 4.84 GB/s     (4.7k)
    Clouvider       | London, UK (10G)          | 283 Mbits/sec   | 277 Mbits/sec   | 51.2 ms
    Eranium         | Amsterdam, NL (100G)      | 281 Mbits/sec   | 287 Mbits/sec   | 42.5 ms
    Uztelecom       | Tashkent, UZ (10G)        | 245 Mbits/sec   | 136 Mbits/sec   | 108 ms
    Leaseweb        | Singapore, SG (10G)       | 247 Mbits/sec   | 242 Mbits/sec   | 153 ms
    Clouvider       | Los Angeles, CA, US (10G) | 254 Mbits/sec   | 125 Mbits/sec   | 189 ms
    Leaseweb        | NYC, NY, US (10G)         | 240 Mbits/sec   | 267 Mbits/sec   | 121 ms
    Edgoo           | Sao Paulo, BR (1G)        | 238 Mbits/sec   | 82.6 Mbits/sec  | 229 ms
    Clouvider       | London, UK (10G)          | 280 Mbits/sec   | 227 Mbits/sec   | 51.1 ms
    Eranium         | Amsterdam, NL (100G)      | 274 Mbits/sec   | 283 Mbits/sec   | 42.4 ms
    Uztelecom       | Tashkent, UZ (10G)        | 235 Mbits/sec   | 117 Mbits/sec   | 107 ms
    Leaseweb        | Singapore, SG (10G)       | 241 Mbits/sec   | 242 Mbits/sec   | 153 ms
    Clouvider       | Los Angeles, CA, US (10G) | 238 Mbits/sec   | 129 Mbits/sec   | 189 ms
    Leaseweb        | NYC, NY, US (10G)         | 245 Mbits/sec   | 249 Mbits/sec   | 121 ms
    Edgoo           | Sao Paulo, BR (1G)        | 228 Mbits/sec   | 102 Mbits/sec   | 229 ms
    Single Core     | 637
    Multi Core      | 1118
    Full Test       | https://browser.geekbench.com/v6/cpu/13219899
    YABS completed in 20 min 56 sec
    ubuntu@testvm1:~$
    Here is NWS from the test VM on Alexhost node. Thanks Alexhost! <3
     Basic System Info
     CPU Cores          : 2 @ 2800.038 MHz
     CPU Cache          : 16384 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 19.3 GB (2.0 GB Used)
     Total RAM          : 1.9 GB (314.7 MB Used)
     System uptime      : 0 days, 0 hour 3 min
     Load average       : 0.09, 0.05, 0.01
     Virtualization     : KVM
     TCP Control        : cubic
     Basic Network Info
     ISP                : Alexhost SRL
     Host               : Alexhost SRL
     ISP: Alexhost
     Nearest          0.90 ms     0.0%    282.18 Mbps    282.09 Mbps    Moldtelecom JSC - Chisinau
     Bangalore, IN    186.08 ms   0.0%    287.42 Mbps    281.02 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      193.61 ms   0.3%    292.35 Mbps    286.60 Mbps    Jio - Chennai
     Mumbai, IN       157.67 ms   0.0%    303.00 Mbps    259.15 Mbps    Melbicom - Mumbai
     Seattle, US      179.63 ms   N/A     284.89 Mbps    281.35 Mbps    Comcast - Seattle, WA
     Los Angeles, US  173.11 ms   0.0%    278.20 Mbps    273.58 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       152.46 ms   0.0%    280.84 Mbps    279.52 Mbps    Hivelocity - Dallas, TX
     Miami, US        149.41 ms   0.0%    289.43 Mbps    276.70 Mbps    Telxius - Miami, FL
     New York, US     116.15 ms   0.0%    303.23 Mbps    285.44 Mbps    GSL Networks - New York, NY
     Toronto, CA      131.57 ms   0.0%    287.44 Mbps    273.19 Mbps    Rogers - Toronto, ON
     Mexico City, MX  224.46 ms   N/A     281.00 Mbps    275.19 Mbps    INFINITUM - Ciudad de México
     London, UK       52.30 ms    0.0%    288.01 Mbps    231.46 Mbps    VeloxServ Communications - London
     Amsterdam, NL    45.95 ms    0.0%    289.38 Mbps    279.24 Mbps    31173 Services AB - Amsterdam
     Paris, FR        43.58 ms    N/A     292.23 Mbps    279.99 Mbps    Axione - Paris
     Frankfurt, DE    46.45 ms    0.0%    290.27 Mbps    269.25 Mbps    Clouvider Ltd - Frankfurt am Main
     Warsaw, PL       51.83 ms    0.0%    288.17 Mbps    284.86 Mbps    Play - Warszawa
     Bucharest, RO    34.83 ms    0.0%    285.86 Mbps    286.40 Mbps    Vodafone Romania Mobile - Bucharest - Bucharest
     Moscow, RU       FAILED
     Jeddah, SA       114.58 ms   0.0%    296.92 Mbps    287.90 Mbps    Saudi Telecom Company
     Dubai, AE        174.64 ms   N/A     305.76 Mbps    33.44 Mbps     e& UAE - Dubai
     Istanbul, TR     72.39 ms    0.0%    291.25 Mbps    273.76 Mbps    Turkcell - Istanbul
     Tehran, IR       132.07 ms   0.0%    276.53 Mbps    261.38 Mbps    Irancell - Tehran
     Cairo, EG        91.32 ms    0.0%    294.10 Mbps    233.68 Mbps    Telecom Egypt - Cairo
     Tokyo, JP        FAILED
     Hong Kong, CN    264.00 ms   N/A     288.28 Mbps    59.30 Mbps     Misaka Network, Inc. - Hong Kong
     Jakarta, ID      204.51 ms   0.0%    294.28 Mbps    290.27 Mbps    PT Solnet Indonesia - Jakarta
     Sydney, AU       260.57 ms   0.0%    293.01 Mbps    259.38 Mbps    Aussie Broadband - Sydney
     Avg DL Speed       : 289.76 Mbps
     Avg UL Speed       : 255.37 Mbps
     Total DL Data      : 10.27 GB
     Total UL Data      : 8.13 GB
     Total Data         : 18.40 GB
     Duration           : 12 min 16 sec
     System Time        : 08/08/2025 - 17:30:32 UTC
     Total Script Runs  : 120190
     Result             : https://result.nws.sh/r/1754673639_SMSXRN_GLOBAL.txt
