Wow - what a great deal. That's really awesome. Free shell accounts used to be really popular and all - but with new generation kind of died out. Glad to see someone still offering them
One thing I'd like to try is how NetBSD fares with tilemaker, but with most of the disk space already occupied by Debian and OpenBSD I'll need to get some more space for NetBSD. One option is to just mount the OpenBSD file system under NetBSD and use that, hoping it's actually really the same file system. It seems to work for light read-only usage, but not sure if it could corrupt the OpenBSD partition under heavy load. @Not_Oles okay with you to take that risk?
The purpose of the server is to have fun. So, yeah, sure, whatever you want.
As you certainly know, another option might be to remove the Debian and the OpenBSD installations and just go with NetBSD. But, however you want to proceed is fine with me.
After things settle down a little, no rush, I might want to start compiling NetBSD-current, if that would be okay with you. Maybe (probably!) you can show me a better method after I post how I am doing the compiling now. Also, I wonder about testing network performance and, if needed, optimizing network speed.
@Not_Oles said:
Do you plan to serve the map on http(s)?
Here is the map of Europe (installed lighttpd as the web server with my FastCGI backend)
Awesome! I will have to go look inside at what you did. I am sure I can learn something!
FWIW, here in Mexico, on Chrome in my Duet 5 Chromebook, a part of the rendering seems faster than it was on OpenBSD, another part seems about the same. What happens appears to be in two steps: an initial "wait" with no rendering (maybe about the same elapsed time period between OpenBSD and NetBSD), then the "rendering step," where rendering starts and more slowly (OpenBSD) orr more quickly (NetBSD) moves across the screen.
In a practical sense it doesn't make any real difference, maybe about a second.
I think you changed other things besides just the OS, so the OS difference may not be a cause of any of the small difference that I imagine I might be seeing.
Are you a fan of lighthttpd and FastCGI? When, if at all, would you move from that stack to something else, and what would the something else be?
If somebody else here wants to join the server and maybe be able to see and learn from what @cmeerw did, you would be more than welcome!
The initial wait is probably because it takes time to load the Javascript library loaded and started up (it's almost a MB of Javascript).
On OpenBSD I used their built-in httpd as the web server - one difference could be that httpd only supports HTTP/1.1, but lighttpd also supports HTTP/2.0.
I think the other option would be nginx, but at the time I moved from Apache to lighttpd, it was similar to nginx (probably more mature than nginx), and never had a reason to move away from it.
The good thing about FastCGI is that it is somewhat simpler to parse than HTTP and thereby avoids the request smuggling issues with HTTP (which would be the other, and more popular option nowadays).
I did ls in /home and in /usr/pkg/etc plus /usr/pkg/etc/lighthttpd.
Is it okay for me to look deeply inside?
It's fine either way.
I never used lighthttpd before, so it's interesting to me.
Also, while I am making trouble, do we want to compile and run -current? I am doing that elsewhere, redundantly, so it's not like I need to do it on hlcs.
Since not too many LESbians seem super excited about joining, do we want to post about the availability of this fine server on one of the NetBSD mailing lists? Maybe some of the NetBSD guys might want to join LES and join hlcs?
Thanks @Hosteroid! Lovely server! @cmeerw and I are enjoying it very much!
Does anyone else want to join? Please check the "How To Apply" section in the OP.
Sure, but the set up will still need a few tweaks to automatically start up after a reboot, and the certificate renewal needs to be set up (usually using acme-tiny for that)
We could, we just need more disk space for the NetBSD partition. I think we can retire OpenBSD and use that space for NetBSD.
Could do that as well - I guess it's a fine line of what to promise and setting the right expectations.
On the table for discussion at the moment are at least:
your nice lighthttpd and map install -- I need to take a look
the LBA[1] filesystem install that you set up -- I need to look more
running NetBSD-current
retiring OpenBSD on this server, for the moment, to free up more space
a few more users, hopefully LESbians, but maybe also from NetBSD.org
Maybe, instead of nudging for additional changes, I could use more time on hlcs the way it is right now to address the first two items on the list.
I might be a bit extra slow right now.
As a learning exercise, I'm writing minimal login pages in PHP and in Javascript. I'm reading some of the FOSSBilling code. I'm compiling NetBSD-current on a test VPS. If the test passes, then my daily driver VPS also gets compiled on NetBSD-current.
Three server nodes already are going for FOSSVPS, which I hear is about to receive several additional server donations.
I'm adding inventory at the various locations to the FOSSVPS website.
A friend with whom I am sharing a VPS is introducing me to XMPP.
@Not_Oles said: your nice lighthttpd and map install -- I need to take a look
Just did some work on this so it properly restarts on a server reboot.
The LE certificate is now managed via acme-tiny in /var/lib/acme-tiny with a cron job in /etc/crontab (and update and restart scripts in /usr/local/bin/acme-tiny-update.sh and /usr/local/bin/acme-tiny-restart.sh)
I have also modified /etc/rc.d/lighttpd to also create /var/run/lighttpd (for the FastCGI Unix domain sockets) - and my map server is started via a @reboot cron job (under my user).
Why not start it using the systemd instead?
There is no systemd on NetBSD.
Yes, but it does use /etc/rc.conf to define startup applications, and since you already added the file to /etc/rc.d/lighttpd you can set it to run on bootup with a simple lighttpd=YES in your rc.conf file.
Yes, and that's what I am doing for lighttpd itself.
The part I am not starting via /etc/rc.d is the FastCGI application - this one doesn't have any of the daemonize/setuid functionality built in, so just using a @reboot cron job is the easiest option.
Ah, yes, the fastcgi runs separately in lighttpd, but from what I remember, lighttpd has a mod to startup the php's fastcgi application on lighttpd's bootup. So you enable the fastcgi and fastcgi-pho mods and they start up together.
FYI, you do have to change the fastcgi config (which I am sure you already did) to ensure fastcgi runs as www-data and not root user.
Yes, lighttpd could be used to start the fastcgi program - but as you say that is limited to running the fastcgi program as the same user as lighttpd, which I try not to do (ideally, I should create a separate user for the fastcgi program - but for convenience I haven't done that yet, and just run it under my user account).
AFAIK, lighttpd-enable-mod is a Debian thing (at least it's not something that comes with lighttpd). And my fastcgi program is not PHP based - it's written in C++.
BTW, on Linux (on my more production-like set up) I am actually running each fastcgi application as its own user, and further restricting what it can do by putting it into its own namespace (using bwrap), but that's not something NetBSD supports (yet). But I really think a fastcgi application should be separated from the web server process as much as possible.
Does anyone here at LES want to join @cmeerw and me?
Thanks to @Hosteroid for hlcs!
@cmeerw
Best!
Tom
Thanks to Hosteroid for our lovely server!
Thanks to @cmeerw for awesome system administration!
Good point, I have actually already adjusted a few settings (mostly based on https://wiki.netbsd.org/tutorials/tuning_netbsd_for_performance/)
NetBSD and Linux are running on some VPSes that I have at several providers.
With one provider, I noticed that the network seemed slower on one NetBSD install than on a comparable Linux install. I wondered why, even after I applied the optimizations at https://wiki.netbsd.org/tutorials/tuning_netbsd_for_performance/ .
I haven't had a chance to look into this as much, as slowly, and as carefully as I would like.
To be clear, the NetBSD install works fine, it's just a little slower, and I expected it to be a little faster.
Most likely I made mistakes in the setup!
Tried that tilemaker job, and it ran fine,
time -lshowed:That looks pretty similar to what it took on Linux
Yes, just need to set up the web server part for that on NetBSD.
Excellent!
Awesome!
Thanks again to @Hosteroid for the lovely server!
@cmeew I looked around a little.
I did
lsin/homeand in/usr/pkg/etcplus/usr/pkg/etc/lighthttpd.Is it okay for me to look deeply inside?
Thanks @cmeerw!
[1] Logical Block Addressing -- Allows change of OSes and partitions from inside the server.
acme-tinyin/var/lib/acme-tinywith a cron job in/etc/crontab(and update and restart scripts in/usr/local/bin/acme-tiny-update.shand/usr/local/bin/acme-tiny-restart.sh)I have also modified
/etc/rc.d/lighttpdto also create/var/run/lighttpd(for the FastCGI Unix domain sockets) - and my map server is started via a@rebootcron job (under my user).Why not start it using the systemd instead?
/etc/rc.confto define startup applications, and since you already added the file to/etc/rc.d/lighttpdyou can set it to run on bootup with a simplelighttpd=YESin yourrc.conffile.If you want information, feign ignorance reply with the wrong answer. Internet people will correct you ASAP!
/etc/rc.dis the FastCGI application - this one doesn't have any of the daemonize/setuid functionality built in, so just using a@rebootcron job is the easiest option.Ah, yes, the fastcgi runs separately in lighttpd, but from what I remember, lighttpd has a mod to startup the php's fastcgi application on lighttpd's bootup. So you enable the fastcgi and fastcgi-pho mods and they start up together.
AFAIK,
lighttpd-enable-modis a Debian thing (at least it's not something that comes with lighttpd). And my fastcgi program is not PHP based - it's written in C++.BTW, on Linux (on my more production-like set up) I am actually running each fastcgi application as its own user, and further restricting what it can do by putting it into its own namespace (using
bwrap), but that's not something NetBSD supports (yet). But I really think a fastcgi application should be separated from the web server process as much as possible.Googling suggests that Lighttpd is fast for static files. But Lighttpd does work with PHP.
-- Setting up PHP with Lighttpd
"We have nothing to hide, so please use our bugtracker for all kinds of bugs."
Issue tracking
-- Lighttpd Overview
@Not_Oles I think you should combine all your offers into a single thread
Speaking of that, what are the differences in the offers? (sorry if i missed it)
Yes, maybe there are too many threads.
This offer is different than all the others because it is the only one that requests personal ID in the OP.
Thanks for asking!
You can see the FOSSVPS offers listed, with specs, locations, and inventory, on the FOSSVPS website.
The MetalVPS offers are listed on the MetalVPS website.
All the FOSSVPS offers are free. Some of the MetalVPS offers are free.
that's something I am planning to do soon.
Hi, any free server for me? thanks
Hi @bronxies! Welcome to LES! Please read the How To Apply section in the OP. Thanks!
