Advice on VPS for Video Downloading Site.
in Help
Hi,
Someone I know is working on a project that enables downloading videos from YouTube and other video platforms, and they asked me for advice on which VPS to purchase.
Does anyone here have experience hosting such sites? What would be the minimum requirements?
Apart from bandwidth and storage, are there any other factors one should consider when choosing a VPS for this task?
Thank You.
Hello world.
I am guessing you are also "converting" the videos? It depends on how many concurrent users you expect and what is your expected performance.
Remember, 1 core = 1 ffmpeg thread for video conversion. So 4 core = 4 simultaneous video conversions.
More RAM = more cache for video download and conversion. If a GPU is present, video conversion goes much faster.
Disk usage depends on how long you want the video to be stored. My estimates are based on about 48 hour video storage before deletion. If you want the video to be stored for longer, larger disk is needed.
Network speed matters only for download, and even then, most video sharing sites limits connection so going for a 10 Gbps is not worth it. Moreover, most of the time is taken in converting the video...
Most of these popular "download" sites uses 1 server (master node) for their their frontend where the user interacts, and multiple servers (slave nodes) in the backend doing the video conversion works. So you might want ask your "friend" to change his script to match that. If he is using
yt-dlpfor downloading the videos, a simple script is needed for the slave nodes to receive "work request" from the master node.If you want information, feign ignorance reply with the wrong answer. Internet people will correct you ASAP!
Forget the VPS specs - you’ll get suspended fast no matter where you host it. YouTube downloading violates ToS everywhere, and providers actively block it. Even if it runs at first, once they detect traffic patterns or abuse reports, it’s over.
Save the time and trouble. This isn’t like running a script on your own machine - hosting it publicly on a VPS? Not feasible long term. You’ll bounce from provider to provider until you find one that doesn’t care, and those come with their own problems.
Interesting, may I ask, do you follow every ToS?
Providers block YouTube traffic? Detect traffic patterns for it? It’s the exact same data stream as watching yt so these supposed providers have some rather novel analysis techniques
That all sounds rather strange…
YouTube aggressively blocks servers downloading large numbers of videos. Unless it's a paid platform I don't think there is any host where it'll work.
By request of the family, I have a Proxmox container running MeTube for just that: https://community-scripts.github.io/ProxmoxVE/scripts?id=metube
Crazy simple. Incredibly capable software. 1 vCPU & 2GB RAM for this use case.
Large number = 10 videos per day? 100 videos per day? 1000 videos per day? What metrics is that based on?
Does it also apply for logged in user or only if the user is not logged in (anonymous video download)? Does this apply for free user or also for premium users?
And your server did not get blocked like some of our concerned users stated? Amazing!
Providers/hosts dont care about youtube downloads. What they do care about is video conversion as it maxes our CPU core. Hosts cant/dont monitor your traffic pattern unless it is unencrypted and is torrent related. Abuse reports don't come from youtube. They dont bother notifying hosts.
Well, you are entitled to your opinion, but unless you are willing to provide details and basis for your "assumption" I am with @havoc here. From my experience, youtube has never blocked "my friends" video downloads, even when pulling 100s of videos per day for nearly a month using the same server with 1 IPv4. And he runs it every 2~3 months to get new videos. Video lengths are between 3 mins and 5 mins.
And for legal reasons, I must state that all videos are deleted immediately after download and this service is run for educational purposes only and is definitely not open to public. And I would never promote such behavior.
The machine spec is not very important. The IP will be restricted after downloading for a period of time.
youtube to wav ogg mp3
I don't think that will happen, I actually have hosted it for a month on shared hosting, they downloaded a few videos during that time. Dont think web hosy might have noticed it at all.
As long as there isn't heavy traffic or continuous downloads, it should work fine.
Hello world.
Do you know specs of his VPS and approx CPU Usage while downloading multiple vids?
Hello world.
Master node (that servers the html page to user) uses a low specs VPS to serve a page to choose format and provide the url. It also hosts his database that keeps track of the videos and files.
2 core CPU of Xeon (not sure which one)
2 GB RAM (DDR4)
10 GB SSD
1 Gbps
And 2 to 4 slave nodes with around:
4 core CPU (no idea on model)
6 GB RAM
50 GB SSD
1 Gbps
Can convert 4 videos at the same time per slave node. Any more then that goes into workflow queue which is randomly picked up by the slave nodes to process.
As far as I know, none of his IPs were blocked/banned as of yet.
