AIO WP Migration discontinued lifetime deal - 69$/year now
edited December 2022 in WordPress
AIO WP Migration WordPress Plugin (by Servmask) no longer is available for a one-time fee. Instead charges 69$/year now.
Another lifetime deal I happy I have snagged before it was gone :)
@vyas @bikegremlin
Thanked by (2)bikegremlin vyas
«13
  • If I remember correctly, the deal was $69/lifetime right ?
  • I use that thing a lot, it just works and save time when migrating WP websites. Versus manually doing things. I go full legacy manual if the WP is outdated a lot, might get f* when restoring. So in those cases zip files uploads, dump DB / import, done.
    Yes, it was.
    Yeah, it's a great tool.
    edited August 27
    Seems like they've decided to not honour the lifetime.
    Tech. support says it's all good - but I still get those errors and can't update.
    Frustrating.
    Google says I'm far from the only one.
    It is also worth noting that newer versions won't activate offline, so any LAN use is impossible, pracrticaly.
    Far from happy.
    edited August 27
    Frustrating.
    Far from happy.
    Hm that's odd. I didn't use it for a long time but just tried to install it on a wp install I have and it worked without issues.
    Step 1: Install AIO WP Migration Public plugin from WP Store.
    Step 2: Upload Unlimited Extension:
    Premium Features seem to be unlocked, too:
    Back then I saved the Download Link for the Unlimited Extension as a bookmark in my browser and it still works.
    Maybe try that again with the link.
    Just noticed there are new features like Reset Hub and Scheduling:
    In case you lost your purchase, try: https://servmask.com/lost-purchase
    edited August 27
    edited August 27
    @Ympker said:
    duplicate
    I've been using it for years.
    I did save all the info, including the original download link (which used to work).
    Now it no longer works.
    @Ympker said:
    duplicate
    Hm, that's indeed odd. Have you tried the "lost purchase" link I posted above? Had to fill in my email I used for the purchase and received a new download link. Then you can download and manually install (not update) probably.
    @Ympker said:
    @Ympker said:
    duplicate
    @Ympker said:
    @Ympker said:
    duplicate
    That's annoying😅🙃
  • @Ympker said:
    @Ympker said:
    @Ympker said:
    duplicate
    That's annoying😅🙃
    This calls for reverse engineering and forcing a "license". Also known as "nulled" plugin :lol:
    (Note: Sarcasm. If you care about your wp, do NOT use illegal things)
    @Ympker said:
    @Ympker said:
    @Ympker said:
    duplicate
    That's annoying😅🙃
    There's still that old version of the plugin flying around where limits could be liftened by editing constants.php file. The memories..
    Yea, those were the days!
    Now you have to write your own code to replicate the features you want. Maybe after the AI becomes smart enough, AI can write the plugin for you and, get this, have it actually work! :lol:
    Yeah haha :D
  • @bikegremlin have you tried searching for it on github?
    https://github.com/d0n601/All-In-One-WP-Migration-With-Import
    https://github.com/dev071/all-in-one-wp-migration-unlimited
    AI created this with a few prompts:
    Just gotta test it on a wp install some time :D
  • somiksomik OG
    edited August 29
    Sharing is caring! Do publish it on your github (after your testing/fixes) so we can enjoy the free backup/restore plugin!
    Also, consider adding a scheduled backup to google drive or similar online platforms (if dont have it already, but i guess SFTP counts as one too) in case the server gets compromised...
    @Ympker said:
    @Ympker said:
    @Ympker said:
    duplicate
    That's annoying😅🙃
    The tech. support is still claiming it's just a temporary glitch.
    The most recent "jewel" was a suggestion to "try without a VPN if you are using one" - as if my Net connection has anything to do with hosted WordPress updates not working.
    Sigh...
    This looks really cool! Would love to see the final output once done.
    P.S.: What are you using to have such a simplified WordPress Admin UI?
    I test drived it on https://playground.wordpress.net/ and it loaded just fine but backup couldn't be restored. Could be due to limitations from the sandbox. I don't have a wp install to play around with setup rn, so I'll need to do that in some days. But sure, I'll put on GitHub if it works.
    The screenshot preview was taken by the AI. It's not my dashboard. I need to give it a test-run still :P
    I call scam! Got scammed by the AI generated image! :lol:
    Thanked by (2)Ympker Khalequzzaman
    edited August 29
    This is how it looks for a local install (not that bad tbh):
    Edit: Backup restore didn't work. Will have to check/prompt again some time.
    Ooo, not bad looking! AI generated scripts never work for me, so the fact that backup worked is a big deal already. For me, only "github copilot code assist", or as i call it, "AI auto-complete" works...
    edited September 1
    Going back-and-forth with the tech. support for about a week now.
    "Your licence works. Try without a VPN."
    I've tried without a VPN from at least two different computers and ISPs, it's not working, nor from the hosting server.
    "Yes, very frustrating, try this one..."
    No, not working either...
    edited September 1
    Since they're saying your license is valid maybe ask them to issue a new license code along with a new download linkand invalidate the old ones. Maybe that'll work.
    I suppose we'll get to that in a month or two. LOL. :)
    To be fair I haven't used the plugin in a long while. Updraft Free did all the heavy lifting for me. Great plugin :)
    Can updraft free:
    • Export test1.example.com
    • Import it on www.example.com
    • Fix any links and email domain changes (ideally with an option to do the same without altering email domains)?
    That's why I found the AIO very helpful - it made such stuff simple and trivial.
    Especially for offline (LAN) setups.
