MicroNode hosting package update
AuroraZeroAuroraZero ModeratorHosting ProviderRetired
edited September 5 in Industry News
Hey folks,
Wanted to share an important update about MicroNode hosting. I’ve decided to roll all of the packages into one simple, consolidated option — the Snowflake Plan which is 15 USD a year.
👉 The Snowflake Plan:
  • 512 MB RAM
  • 20 GB Disk Space
  • 500 GB Bandwidth
What this means:
  • Existing clients: All existing clients have been moved to this plan and will keep it until the end of their respective terms.
  • Future clients: everything is now standardized to the Snowflake Plan. This makes things easier to manage on the backend and ensures that resources are allocated more fairly across the board.
The reason for doing this is pretty simple — I’d rather focus on running a stable and sustainable platform than splitting resources across too many tiny plan tiers. This keeps the service affordable, reliable, and fair to everyone.
If you want to grab a Snowflake instance, you can get one here:
👉 Sign Up Now!!
Thanks again to everyone who’s supported MicroNode — you’ve helped me keep this community-driven project alive.
Thanked by (2)skorous Chievo
  • Welcome to nginx!
    If you see this page, the nginx web server is successfully installed and working. Further configuration is required.
    For online documentation and support please refer to nginx.org.
    Commercial support is available at nginx.com.
    Thank you for using nginx.
    Welcome to nginx!
    Works fine for me Firefox, chrome, vivaldi and mobile
  • skorousskorous OGSenpai
    Welcome to nginx!
    It did that to me one time too. Didn't redirect for some reason.
    👉 Sign Up Now!!
    Please allow me to confirm that @AuroraZero's link seems to work from here (Chrome Browser (Version 139.0.7258.164 (Official Build) (64-bit) (with experimental color rendering changes that might change the expected color)):
    Welcome to nginx!
    I will check and see what's up.
    Welcome to nginx!
    It's worked fine everytime since then. Figured it was a glitch in the Matrix.
    Welcome to nginx!
    Could be anything as you said probably a glitch. Better safe than sorry though.
  • Seems like it’s happening when you access via HTTP. HTTPS is working fine though
    good catch! http to https redirection is probably messed up...
    Thanked by (2)Not_Oles sanvit
    I will look into it as soon as I am back at my desk. Thank you for the heads up
    Weekend = you should stay away from desk unless something catches fire.
    It's good to use the time to relax and unwind.
    I don't take breaks brother. If I do it's usually a week at a time. Too much to do not enough time in the day anymore.
    Fixing tractors and planting rye this week. Never a dull moment
    Thanked by (3)somik skorous yoursunny
