MicroNode hosting package update
Hey folks,
Wanted to share an important update about MicroNode hosting. I’ve decided to roll all of the packages into one simple, consolidated option — the Snowflake Plan which is 15 USD a year.
👉 The Snowflake Plan:
- 512 MB RAM
- 20 GB Disk Space
- 500 GB Bandwidth
What this means:
- Existing clients: All existing clients have been moved to this plan and will keep it until the end of their respective terms.
- Future clients: everything is now standardized to the Snowflake Plan. This makes things easier to manage on the backend and ensures that resources are allocated more fairly across the board.
The reason for doing this is pretty simple — I’d rather focus on running a stable and sustainable platform than splitting resources across too many tiny plan tiers. This keeps the service affordable, reliable, and fair to everyone.
If you want to grab a Snowflake instance, you can get one here:
👉 Sign Up Now!!
Thanks again to everyone who’s supported MicroNode — you’ve helped me keep this community-driven project alive.
Welcome to nginx!
If you see this page, the nginx web server is successfully installed and working. Further configuration is required.
For online documentation and support please refer to nginx.org.
Commercial support is available at nginx.com.
Thank you for using nginx.
vps9
hostname is available. affbrrWorks fine for me Firefox, chrome, vivaldi and mobile
It did that to me one time too. Didn't redirect for some reason.
Please allow me to confirm that @AuroraZero's link seems to work from here (Chrome Browser (Version 139.0.7258.164 (Official Build) (64-bit) (with experimental color rendering changes that might change the expected color)):
I will check and see what's up.
It's worked fine everytime since then. Figured it was a glitch in the Matrix.
Could be anything as you said probably a glitch. Better safe than sorry though.
Seems like it’s happening when you access via HTTP. HTTPS is working fine though
good catch! http to https redirection is probably messed up...
