Any details on your Telegram bot projects? Are they open source so that you could give us a link to the repo? Is NAT IPv4 plus IPv6 okay for you, or do you need dedicated IPv4 plus IPv6?
Thank you!
Tom
For now the projects are closed, private development to help develop their chats and channels, if the bots are successful and useful, I will post them for everyone. Right now the simplest server and IPv4 will be enough
Two VPSes, the last currently available in Chisinau, have been assigned to applicants on Nodeseek.
Thanks again to @Alexhostcom for their kind donation!
Possibly more Chisinau VPSes might become available if more IPv4s are donated, if another server is donated, or if someone moves elsewhere.
Right now, FOSSVPS still has 3 NAT IPv4 VPSes available in London. Two of them, if I recall correctly have applications which are pending. Thus, there might be only one remaining fully available. Thanks to [OnlyServers] for their kind donation!
Great news! Alexhost has kindly agreed to extend it's sponsorship of FOSSVPS' Chisinau node beyond the previously set expiration date of October 30, 2025. No new expiration date has been set. Alexhost also added an additional 5 dedicated IPv4 addresses. Thanks @Alexhostcom!
Important!
The Chisinau node needs to be rebooted. Probably the reboot will happen about or after 3:00 PM UTC on Saturday, September 6, 2025.
Another post will be made here prior to the reboot.
The previous time the Chisinau node was rebooted, a power bump was needed to get the node restarted. That might happen again.
If you need the reboot to be delayed, please post here.
New Giveaway
Five IPv6-only VPSes on our excellent Alexhost node in Chisinau, Moldova:
Specs: KVM, Ubuntu 24.04 LTS or Debian 13, 4 E5-2680 v2 vCores, 4 GB ECC RAM, 100GB Disk RAID 10, 1Gbps, No IPv4, One IPv6/128
Inventory: 0 assigned, 5 available
Expires: No date set
Renew: Not applicable
How to apply:
Please post here in this thread.
Ubuntu 24.04 LTS or Debian 13?
What do you want to run on your VPS?
Please post any links you want to add (your website, blog, source repository, etc.)
In case you are wondering, there are no strings attached to @Not_Oles's offer. As for the VPS uses, you can use the VPS with the IPv6 address to run your project site, since most ISPs allows access to IPv6 websites.
If you are still worried, I recently found out that you can use cloudflare to "proxy" your website so it'll load on both IPv4 and IPv6, all the while using a proper CDN for your project site.
Following attention by Alexhost support, the Chisinau server is again online. It responds to ping, and I can log in. virsh seems to think that all the current VMs are running.
root@alexhost:~# date
Sat Sep 6 18:08:42 UTC 2025
root@alexhost:~# virsh list
Id Name State
1 vm8 running
2 vm6 running
3 vm11 running
4 vm1 running
5 vm12 running
6 vm2 running
7 vm5 running
8 vm7 running
9 vm10 running
10 vm4 running
11 vm3 running
12 vm13 running
13 vm9 running
root@alexhost:~#
If anyone is experiencing any trouble, please let me know!
Maybe it might not sound so super wonderful to say, "It means a lot!" But as we go through life, how often do we meet kind, honest, generous, dependable, "real" people?
Fortuitous meetings happen for me from time to time. I am lucky to know you!
@Not_Oles said:
There also are going to be 5 more dedicated IPv4 plus IPv6/128 VPSes available "soon." Thanks again to alexhost for the additional 5 IPv4 addresses.
Now I want to get one!
Ding!
5 - 1 = 4
I have to update the website. And . . . and . . . and. . . .
There are 5 new IPv6-only Ubuntu 24.04 LTS VPSes ready to go on the Alexhost node in Chisinau.
Since the recent node software update and reboot a few days ago, there has been some trouble making new Debian VPSes, which no longer boot. Also, there may now be some file I/O instability on the existing Debian VPSes. Nevertheless, the new Ubuntu VPSes seem fine! Also an OpenBSD VPS seems to be working excellently.
It again is time for me to sleep, so I will be back tomorrow. Hopefully I can review the existing requests and try to assign some free VPSes.
Have a wonderful day! Best wishes!
Tom
Hey Tom,
Rest well you deserve it man. I would be interested in an ipv4 to use for a code/dev server. If you do not have the room or need anything let me know.
I'm about to put a few new dedicated IPv4 + IPv6/128 up on Alexhost in Chisinau. Of course, I'd be delighted to give you one. But, it might be kind of far away (too much latency) for an interactive graphical application? Of course, it might work great!
As an alternative, if you don't mind sharing it with me, and if you don't mind Debian unstable, I've got a 2 vCore Ryzen 9950X that we could try. Well, if you don't like Debian unstable, we could reinstall it. This VPS has a pretty good connection, and it's not too far from your location.
Hi @aski!
I'm looking forward to reviewing your request as soon as your project is open sourced.
Thanks very much, again, for your request! Welcome, again, to LES!
Best wishes!
Tom
Best wishes!
Wonderful Alexhost Update!
Important!
New Giveaway
How to apply:
Good morning! Reboot time has arrived!
The Chisinau server again seems offline following the attempted reboot.
I opened a ticket with Alexhost requesting a hardware reset.
More before too long!
virsh
seems to think that all the current VMs are running.If anyone is experiencing any trouble, please let me know!
Thanks to the Alexhost Support Team for helping!
Sorry @Not_Oles these are nat correct?
No. Dedicated IPv4, not NAT.
The VMs shown above from
virsh list
on the Alexhost Chisinau server are the currently allocated, dedicated IPv4 plus IPv6/128 VPSes.I just made the first IPv6-only VM. I need to test a little more, and then 5 IPv6-only VPSes will become available.
Damn man that is generous!!! Good luck man I know you put alot of work into this and your other projects>
@AuroraZero Your support means a lot!
Ding!
5 - 1 = 4
Hello!
Tom
Hey Tom,
Sorry to go offtopic, but that reminds me, @Not_Oles did you try to run VS code web on one of the servers yet? If not, give it a try.
Demo: https://vscode.dev/
Instructions/code on: https://github.com/coder/code-server
Since you are now using ubuntu, it should be easy enough to setup and run!
Have a nice evening!
