Popular free image hosts and hosting scripts
2»
  • edited September 9
    I guess it's time i look into migrating back out of cloudflare, specially since this exists. I dont want a 70k or a 100k bill anytime soon!
    CloudFlare doesn't charge for traffic. You will be asked to upgrade to a paid plan or get restricted.
    Edit: Catbox doesn't block every VPN IP. It's more likely that I'm lucky enough to always pick banned proxies and VPNs.
  • MasonMason AdministratorOG
    @havoc said:
    I'm just using the built in image functionality?
    Is there a reason people are using external?
    Folks with the 'Content Writer' tag have special permissions to use that feature. Mainly to help when staging LES Talk articles so you don't have to use external sites. It's blocked for everyone else since it was being abused a bit.
  • vyasvyas OGSenpai
    RedBeard has spoken.
    That explains why I could upload images before, not anymore...
    Hope all well!
    Thanks, but i decided to move the site away form "potential" downtime and instead go with "report here" button for my own image hosting script. Hope that'll at least mitigate that issue. If not, i'll move the image hosting site to a different provider to keep it from bringing my entire server stack down...
    Have you considered implementing integration with a third party image hosting service like PostImages? They offer javascript only plugins that can help upload image to their site and add the "hotlink" back to the message box: https://postimages.org/plugins
    The dont have one for this specific forum script, but the script itself is simple enough to be added/modified.
    ah got it. Right...will try to use an external host going forward then.
