[FOSSVPS - OnlyServers] Free London VPS with a pretty good network!
edited August 7 in Offers
Hello!
Thanks to @dan_onlyservers' kind server donation, <3, @netixen, and @babywhale of BashVM fame, FOSSVPS is giving away six Debian 12 London IPv4/IPv6 VPSes. These VPSes share a pretty good, unmetered network. The time period is until October 25, 2025, and might be renewed.
Please check the below Yabs and NWS test results for the specs. Please note that each VPS offered here has one dedicated IPv4 address and also an IPv6/80. We expect that there soon might be a second round of NAT IPv4 VPSes on this server.
To apply for a free VPS, please post in this thread. This giveaway will be open for a day or two at least. In your post, please explain what you want to run on your VPS and why FOSSVPS should select you as a recipient of a free VPS.
Free and open source software only.
White hat only.
Not for commercial use.
No service level agreement.
Ephemeral. Could disappear at any time!
Clueless™ Administrator!
---------------------------------- nws.sh ---------------------------------
      A simple script to bench network performance using speedtest-cli
 Version            : v2025.07.08
 Global Speedtest   : wget -qO- nws.sh | bash
 Region Speedtest   : wget -qO- nws.sh | bash -s -- -r <region>
 Ping & Routing     : wget -qO- nws.sh | bash -s -- -rt <region>
 Basic System Info
 CPU Model          : Intel(R) Xeon(R) Gold 5115 CPU @ 2.40GHz
 CPU Cores          : 2 @ 2394.374 MHz
 CPU Cache          : 16384 KB
 AES-NI             : ✔ Enabled
 VM-x/AMD-V         : ✔ Enabled
 Total Disk         : 45.5 GB (1.7 GB Used)
 Total RAM          : 3.8 GB (355.0 MB Used)
 System uptime      : 0 days, 6 hour 53 min
 Load average       : 0.00, 0.00, 0.00
 OS                 : Debian GNU/Linux 12
 Arch               : x86_64 (64 Bit)
 Kernel             : 6.1.0-37-amd64
 Virtualization     : KVM
 TCP Control        : cubic
 Basic Network Info
 Primary Network    : IPv6
 IPv6 Access        : ✔ Online
 IPv4 Access        : ✔ Online
 ISP                : Packet Star Networks UK
 ASN                : AS249 European Network
 ASN (IPv4)         : AS204044 PACKET STAR NETWORKS LIMITED
 Host               : Packet Star Networks Limited
 Location         Latency     Loss    DL Speed       UP Speed       Server
 ISP: Packet Star Networks
 Nearest          1.85 ms     N/A     9276.09 Mbps   9258.19 Mbps   YouFibre - London
 Bangalore, IN    132.53 ms   0.0%    5636.89 Mbps   709.71 Mbps    Bharti Airtel Ltd - Bangalore
 Chennai, IN      145.19 ms   0.0%    5199.33 Mbps   551.08 Mbps    Jio - Chennai
 Mumbai, IN       189.08 ms   0.0%    4182.30 Mbps   594.15 Mbps    Melbicom - Mumbai
 Seattle, US      139.44 ms   N/A     4927.06 Mbps   536.21 Mbps    Comcast - Seattle, WA
 Los Angeles, US  127.42 ms   0.0%    5853.62 Mbps   689.56 Mbps    ReliableSite Hosting - Los Angeles, CA
 Dallas, US       100.49 ms   0.0%    7697.65 Mbps   619.61 Mbps    Hivelocity - Dallas, TX
 Miami, US        103.44 ms   0.0%    1921.70 Mbps   686.11 Mbps    Telxius - Miami, FL
 New York, US     67.93 ms    0.0%    7731.64 Mbps   1565.10 Mbps   GSL Networks - New York, NY
 Toronto, CA      81.01 ms    0.0%    6275.83 Mbps   1146.27 Mbps   Rogers - Toronto, ON
 Mexico City, MX  168.53 ms   N/A     3859.63 Mbps   484.91 Mbps    INFINITUM - Ciudad de México
 London, UK       2.17 ms     0.0%    9248.60 Mbps   7052.38 Mbps   VeloxServ Communications - London
 Amsterdam, NL    8.95 ms     0.0%    8954.72 Mbps   6544.17 Mbps   31173 Services AB - Amsterdam
 Paris, FR        14.24 ms    N/A     9105.57 Mbps   2051.73 Mbps   Axione - Paris
 Frankfurt, DE    27.27 ms    0.0%    7350.81 Mbps   5286.65 Mbps   Clouvider Ltd - Frankfurt am Main
 Warsaw, PL       28.25 ms    0.0%    9207.54 Mbps   3721.15 Mbps   Play - Warszawa
 Bucharest, RO    40.33 ms    0.0%    7009.43 Mbps   2577.38 Mbps   Vodafone Romania Mobile - Bucharest - Bucharest
 Moscow, RU       FAILED
 Jeddah, SA       66.09 ms    0.0%    9223.94 Mbps   791.85 Mbps    Saudi Telecom Company
 Dubai, AE        118.72 ms   0.0%    4740.16 Mbps   218.82 Mbps    e& UAE - Dubai
 Istanbul, TR     51.64 ms    0.0%    9338.75 Mbps   2046.16 Mbps   Turkcell - Istanbul
 Tehran, IR       93.50 ms    0.0%    1975.95 Mbps   871.98 Mbps    Irancell - Tehran
 Cairo, EG        66.17 ms    0.8%    3334.62 Mbps   968.28 Mbps    Telecom Egypt - Cairo
 Tokyo, JP        204.47 ms   N/A     3491.21 Mbps   519.92 Mbps    GSL Networks - Tokyo
 Chengdu, CM-CN   FAILED
 Hong Kong, CN    191.93 ms   0.0%    4130.98 Mbps   251.85 Mbps    Misaka Network, Inc. - Hong Kong
 Singapore, SG    FAILED
 Jakarta, ID      170.16 ms   0.0%    4337.63 Mbps   551.93 Mbps    PT Solnet Indonesia - Jakarta
 Sydney, AU       262.41 ms   0.0%    3022.81 Mbps   411.77 Mbps    Aussie Broadband - Sydney
 Avg DL Speed       : 6039.81 Mbps
 Avg UL Speed       : 1950.27 Mbps
 Total DL Data      : 201.80 GB
 Total UL Data      : 54.15 GB
 Total Data         : 255.95 GB
 Duration           : 12 min 6 sec
 System Time        : 07/08/2025 - 00:40:48 EDT
 Total Script Runs  : 120065
 Result             : https://result.nws.sh/r/1754541060_GSQKS4_GLOBAL.txt
Wed Aug  6 11:20:13 PM EDT 2025
Uptime     : 0 days, 5 hours, 45 minutes
Processor  : Intel(R) Xeon(R) Gold 5115 CPU @ 2.40GHz
CPU cores  : 2 @ 2394.374 MHz
RAM        : 3.8 GiB
Swap       : 0.0 KiB
Disk       : 45.5 GiB
Country    : United Kingdom
Read       | 6.30 MB/s     (1.5k) | 91.13 MB/s    (1.4k)
Write      | 6.30 MB/s     (1.5k) | 91.61 MB/s    (1.4k)
Total      | 12.61 MB/s    (3.1k) | 182.75 MB/s   (2.8k)
Read       | 119.94 MB/s    (234) | 161.05 MB/s    (157)
Write      | 126.31 MB/s    (246) | 171.77 MB/s    (167)
Total      | 246.25 MB/s    (480) | 332.82 MB/s    (324)
Clouvider       | London, UK (10G)          | 8.69 Gbits/sec  | 7.46 Gbits/sec  | 1.59 ms
Eranium         | Amsterdam, NL (100G)      | 9.35 Gbits/sec  | 8.15 Gbits/sec  | 10.7 ms
Uztelecom       | Tashkent, UZ (10G)        | 2.25 Gbits/sec  | 648 Mbits/sec   | 108 ms
Leaseweb        | Singapore, SG (10G)       | 1.02 Gbits/sec  | 1.11 Gbits/sec  | --
Clouvider       | Los Angeles, CA, US (10G) | 1.11 Gbits/sec  | 1.23 Gbits/sec  | 142 ms
Leaseweb        | NYC, NY, US (10G)         | 2.50 Gbits/sec  | 2.66 Gbits/sec  | 70.3 ms
Edgoo           | Sao Paulo, BR (1G)        | 1.33 Gbits/sec  | 1.12 Gbits/sec  | 178 ms
Clouvider       | London, UK (10G)          | 8.49 Gbits/sec  | 6.27 Gbits/sec  | 1.55 ms
Eranium         | Amsterdam, NL (100G)      | 9.21 Gbits/sec  | 8.39 Gbits/sec  | 10.7 ms
Uztelecom       | Tashkent, UZ (10G)        | 2.07 Gbits/sec  | 1.70 Gbits/sec  | 108 ms
Leaseweb        | Singapore, SG (10G)       | 1.23 Gbits/sec  | 1.11 Gbits/sec  | --
Clouvider       | Los Angeles, CA, US (10G) | 1.18 Gbits/sec  | 1.27 Gbits/sec  | 142 ms
Leaseweb        | NYC, NY, US (10G)         | 2.72 Gbits/sec  | 2.66 Gbits/sec  | 70.3 ms
Edgoo           | Sao Paulo, BR (1G)        | 969 Mbits/sec   | 978 Mbits/sec   | 178 ms
Single Core     | 1122
Multi Core      | 2013
Full Test       | https://browser.geekbench.com/v6/cpu/13206574
YABS completed in 16 min 7 sec
Thanked by (3)cold babywhale bliss
  • Thanks Tom, you know I am keen. It does seem like a lot of work (to build) if the server is going away in October, lets hope it extends. Keep up the good work.
    Thanks @msatt! Sent you login credentials via PM. Please post here in this thread to let us know how it goes! Best! Tom
    Thanked by (1)msatt
  • Looking good thanks Tom. Just about to try and install proxmox ......
    Good luck with Proxmox! Please let us know how that goes! :star:
    Progress:
    We now have an additional six Debian 12 London NAT IPv4 / IPv6 VPSes available to give away.
    So, if you want one, please let us know. From now on requests should specify which type of VPS is being requested: dedicated IPv4 or NAT IPv4.
    The more effort you invest in reading this thread and in writing your request, the more likely it is to be successful. <3
    Thanks to @babywhale from BashVM for coming aboard and making these VPSes for us! <3
    Thanks to @dan_onlyservers for the kind server donation! <3 Thanks to @netixen for facilitating the donation! <3
    Thanks to FOSSVPS' wonderful users! <3 Thanks to LES! <3
  • Thank you very much for the kindness. I really appreciate your efforts(among other people) on FreeVPS.org, which helps me watch BBC videos occasionally.
    I don't need this resource, hopefully kind people in need can get it, and wish everything goes well with you.
    Reconfiguring Proxmox to create vmbr0 screwed up and needed @Not_Oles help (thanks Tom) to reset the interfaces file back to original. If anyone else is going to use Proxmox on the server this is what my working /etc/network/interfaces looks like.
    source /etc/network/interfaces.d/*
    auto lo
    iface lo inet loopback
    iface enp1s0 inet manual
    auto vmbr0
    iface vmbr0 inet static
    address 45.139.197.XX/29
    gateway 45.139.197.XX
    dns-nameservers 1.1.1.1 8.8.8.8
    bridge-ports enp1s0
    bridge-stp off
    bridge-fd 0
    iface vmbr0 inet6 static
    address 2a06:7e00:0000:1a00:XX::1/80
    gateway 2a06:7e00:0000:1a00:XX::1
    dns-nameservers 2001:4860:4860::8888 2606:4700:4700::1111
    Set XX to value in original /etc/network/interfaces
    Hope that helps someone.
  • somiksomik OG
    edited August 9
    auto lo
    auto vmbr0
    bridge-ports enp1s0
    bridge-stp off
    bridge-fd 0
    Follow this guide. I follow it every time I need to setup a proxmox on 1 public IP:
    https://somik.org/proxmox-with-one-public-ip/
    Includes network port forwarding / ip table routing.
    Thanked by (2)msatt Wonder_Woman
    Hello friends! Happy Saturday!
    As you also can see at FOSSVPS, there are three NAT VPSes still available on this nice Node with its nice network.
    Please check the Yabs and NWS posted above.
    Anybody want a free VPS with a nice network?
    @Not_Oles said: To apply for a free VPS, please post in this thread. . . . In your post, please explain what you want to run on your VPS and why FOSSVPS should select you as a recipient of a free VPS.
    Thanks to OnlyServers for donating this server, and to @netixen for arranging the donation. <3
    All the Chisinau VPSes have been assigned.
    All the London VPSes have been assigned.
    All the Los Angeles VPSes have been assigned.
    Thanks to FOSSVPS' wonderful server Node donors: OnlyServers, Alexhost, and @fmxm. <3 Thanks to @babywhale for BashVM! Thanks to @AuroraZero for hosting the FOSSVPS wesite on YetiNode free! <3
    Thanks to our 34 wonderful users! <3
    More soon! :star:
    Thanked by (1)msatt
    Good morning!
    OnlyServers has kindly extended their donation of the London server until January 25, 2026!
    Thanks to Dan! <3
  • Ey
    I would like to get a vps :D
    @KevvoGeek Congrats on joining us here at LES!
    Could you tell is a little about yourself so we can get to know you?
    Also (from the original post in this thread):
    @Not_Oles said: To apply for a free VPS, please post in this thread. This giveaway will be open for a day or two at least. In your post, please explain what you want to run on your VPS and why FOSSVPS should select you as a recipient of a free VPS.
    White hat only.
    White hat only.
    So no always online closed source commercial black hat project that requires 200 pages of service agreement managed by IT expert level admins? Too bad :lol:
    Good morning!
    Thanks to Dan! <3
    Thank you very much to both, it is greatly appreciated.
  • somiksomik OG
    edited September 13
    Deleted
    Deleted
    Ya, sorry about that. For anyone wondering, I was testing my firefox plugin for LES that lets me upload and attach images from this comment box (textbox) and while testing, instead of clicking "preview" clicked "Post comment"... So quickly removed my message and since i couldn't keep it blank, changed it to what you see above :D
    Anyway, good luck to FOSSVPS and ... erm... their sponsor... who I can only assume, uploads a lot of pictures of their servers... :lol:
    @somik
    I thought your deleted post was a funny joke!
    If a server expires, it gets "deleted." If the server's expiration date is pushed back, then, in a sense, the deletion gets deleted, hence "deleted." :)
    @somik
    Lol, no, it was much more simple, just a mistake :lol:
  • Can confirm mine is still running smoothly. This is great, thanks again @Not_Oles
    @epoch314
    Delighted you are satisfied with your FOSSVPS!
    I need to make some more London VPSes. These would be either NAT IPv4 or IPv6 only.
    Also, one VPS was suspended for high CPU use, and, since I have no response from the client, that VPS might be re-assigned. I have to check to see whether it's dedicated IPv4.
    I will post again when some more VPSes are available. Might take a couple of days.
    Thanks to OnlyServers for their kind donation! <3
