Please note, you will have a 15GB remote upload traffic limit for the life of your account (only applicable to free plan). Premium and business users get unlimited Remote Upload Traffic.
https://microlxc.net/
@Fritz said: 15GB remote upload traffic limit
Does this mean I can only upload 15gb of the 20gb?
- | Free Uptime Kuma | Best Web Hosting Deal
@nikhm2n said: @Fritz said: 15GB remote upload traffic limit Does this mean I can only upload 15gb of the 20gb?
@nikhm2n said:
Unless you use their website or pcloud app, yes. If you use their app, then such limits do not apply.
Never make the same mistake twice. There are so many new ones to make. It’s OK if you disagree with me. I can’t force you to be right.
@Fritz said: Please note, you will have a 15GB remote upload traffic limit for the life of your account (only applicable to free plan).
Indeed, and that seems only the remote 'fetch from URL' facility. WebDAV doesn't seem to be available at all on the free account.
@cochon said: @Fritz said: Please note, you will have a 15GB remote upload traffic limit for the life of your account (only applicable to free plan). Indeed, and that seems only the remote 'fetch from URL' facility. WebDAV doesn't seem to be available at all on the free account.
@cochon said:
(Windows) Network Drive should be available via the proprietary client. That said, it's not the same ofc.
Guys, I think I got the wrong cloud...
@somik said: Guys, I think I got the wrong cloud...
Yeah. I believe you got the one powered by batteries with acid inside, instead of the one using green energy.
@root said: @somik said: Guys, I think I got the wrong cloud... Yeah. I believe you got the one powered by batteries with acid inside, instead of the one using green energy.
@root said:
Oh thank god! I thought I got the Lgbtq version, but nope, it's just pcloud syncing my files. Guess it's finally coming out of the cloud closet
(ok, I'll see myself out of the door)
