Please note, you will have a 15GB remote upload traffic limit for the life of your account (only applicable to free plan).
Premium and business users get unlimited Remote Upload Traffic.
Indeed, and that seems only the remote 'fetch from URL' facility. WebDAV doesn't seem to be available at all on the free account.
Does the limit apply for Rclone pCloud remote?
Good question, I'm guessing not, as rclone's access seems to be based on their API. Their FAQ says (of remote upload traffic):
This is the traffic you accumulate when you use Remote Upload or pCloud Save to upload files.
I was planning to add pCloud to some backup routines which were already using WebDAV to other services, but might shoehorn rclone in as an alternative here, I'll easily blow the 15GB in a few weeks and feed back if it stops working.
https://microlxc.net/
Does this mean I can only upload 15gb of the 20gb?
- | Free Uptime Kuma | Best Web Hosting Deal
Unless you use their website or pcloud app, yes. If you use their app, then such limits do not apply.
(Windows) Network Drive should be available via the proprietary client. That said, it's not the same ofc.
Guys, I think I got the wrong cloud...
Yeah. I believe you got the one powered by batteries with acid inside, instead of the one using green energy.
Oh thank god! I thought I got the Lgbtq version, but nope, it's just pcloud syncing my files. Guess it's finally coming out of the cloud closet
(ok, I'll see myself out of the door)
vps9
hostname is available. affbrrGood question, I'm guessing not, as rclone's access seems to be based on their API. Their FAQ says (of remote upload traffic):
