pCloud 20GB Free Lifetime Cloudstorage
2»
  • edited September 2025
    Please note, you will have a 15GB remote upload traffic limit for the life of your account (only applicable to free plan).
    Premium and business users get unlimited Remote Upload Traffic.
    Thanked by (2)Ympker yoursunny
  • @Fritz said: 15GB remote upload traffic limit
    Does this mean I can only upload 15gb of the 20gb?
    Unless you use their website or pcloud app, yes. If you use their app, then such limits do not apply.
    Indeed, and that seems only the remote 'fetch from URL' facility. WebDAV doesn't seem to be available at all on the free account.
    (Windows) Network Drive should be available via the proprietary client. That said, it's not the same ofc.
    Thanked by (1)cochon
  • Guys, I think I got the wrong cloud...
    Thanked by (1)ehab
    Yeah. I believe you got the one powered by batteries with acid inside, instead of the one using green energy.
  • somiksomik OG
    Oh thank god! I thought I got the Lgbtq version, but nope, it's just pcloud syncing my files. Guess it's finally coming out of the cloud closet :lol:
    (ok, I'll see myself out of the door)
    Does the limit apply for Rclone pCloud remote?
    No hostname available. affbrr
    Good question, I'm guessing not, as rclone's access seems to be based on their API. Their FAQ says (of remote upload traffic):
    This is the traffic you accumulate when you use Remote Upload or pCloud Save to upload files.
    I was planning to add pCloud to some backup routines which were already using WebDAV to other services, but might shoehorn rclone in as an alternative here, I'll easily blow the 15GB in a few weeks and feed back if it stops working.
    Thanked by (2)yoursunny Ympker
    I thought their API and WebDAV access is only for paid customers? Can free users also use it?
    WebDAV certainly doesn't work for me, but rclone seemingly does, and it appears to use the API.
    That said I read they only made WebDAV a premium feature in 2022, so API access could yet be pulled from the free tier, and I need to test if it's subject to that 15GB remote upload limit.
    Which app is unlimited?
    If you use the official pCloud App there is no traffic upload limit is what they probably meant.
    Thanked by (1)MGarbis
