What do you use to block ads?
2»
  • Using PiHole + the Mullvad DNS Blocklists... overall great but some ads still get through (for example on a Samsung Smart TV)
  • I used uBlock Origin on Chrome, but Google kept disabling it under different pretexts.
    Switched to Vivaldi with "Block Trackers & Ads" on across all my machines.
  • Apple Private Relay + Adguard DNS is a solid combo - way less intrusive than Wipr, and you still block most trackers without breaking sites. I switched to it last year after getting tired of buttons disappearing or forms not loading.
  • WolveixWolveix OG
    edited September 17
    AdGuard Home with various lists for network-wide adblock (all DNS traffic is forced through it), then uBlock Origin in all browsers
