If your audience is in the Caribbean, you can try InterServer, as their datacenter in New Jersey (East US) is fairly close and should offer good latency.
Anything in that area I use BuyVM / Frantech Miami nodes. Isn't the cheapest but the convenience of it "just working" is worth it to me. I use a small one as a jump box for friends in south america to play minecraft at a lower latency than if they routed all the way to LV or NY over the open net.
Get a paper map, hang it on the wall, take a dart, throw it at the map. Where it lands, get your server there.
(also works with a monitor, but it's a bit difficult to see where the dart lands due to all the smoke)
Most ISPs from the Caribbean are present on the MiamiIX (Equinix MIA) or FL-IX, so getting a provider that has a combination of both or any one of them, should net you the best latency/speed as possible.
Miami will likely be your best bet for cheap.
[ IncogNET LLC ] - Since 2020
Came here to say this
Considering the energy costs in the Caribbean area I don't think there would be any explicitly cheap hosts there
datalix's aff #1 fan
easy, let other electricity subscribers subsidize the datacenter by raising their per kWh costs and give the datacenter a discount!
/s
Surrounded by sea! Might as well use some of it for cooling!
/hj
