I used uBlock Origin on Chrome, but Google kept disabling it under different pretexts.
Switched to Vivaldi with "Block Trackers & Ads" on across all my machines.
Apple Private Relay + Adguard DNS is a solid combo - way less intrusive than Wipr, and you still block most trackers without breaking sites. I switched to it last year after getting tired of buttons disappearing or forms not loading.
Switch to a all in one list, that only blocks ads and nothing else. Your family will not come back and tell you that "abc" site isn't loading with this:
Using PiHole + the Mullvad DNS Blocklists... overall great but some ads still get through (for example on a Samsung Smart TV)
AdGuard Home with various lists for network-wide adblock (all DNS traffic is forced through it), then uBlock Origin in all browsers
Other places you can find me
go-hole with a few blocklists, and that's it
Try this blocklist?
https://raw.githubusercontent.com/hagezi/dns-blocklists/main/hosts/native.samsung.txt
https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts
Thanks, actually looks good for now.
Didn't found anything yet that the list blocks, but still great to have that in mind if that ever happens.
Got a lot:
Your mom
Brave everywhere, and wireguard + adguard dns when connected to vpn
