microLXC Public Test
1161718192022»
  • @Neoon said:
    Maintenance announcement
    Gonna upgrade the backend to a new debian release, on Sunday, at around 22:00 CET, the panel will be unavailable for about 30 minutes, tops.
    Offtopic, if debian only releases LTS (or 5 year support releases), why does ubuntu have non LTS when it's based on debian? And if ubuntu non LTS is based on the bleeding edge branches, who wants it?
    @Neoon said:
    @Neoon said:
    Debian 13 is now available.
    Additional, image housekeeping.
    • Fedora 39 (KVM) and CentOS Stream has been removed, since nobody was using it.
    • Additionally, new Alpine versions have been added.
    Alpine is fun! I was using it on a 64 MB RAM LXC VPS for a while. Was fun while it lasted. Not of much use, but still fin to use none the less!
    I love giving myself the extra hassle of fitting services under those LXCs just for the sake of fitting them, then deleting it all after.
    Once managed to nginx, discord bot, and VNC vim… not for long though
    Ya, I know what you mean! Spending unhealthy amount of time to make something you "think" you need, and then once you are done making it, just moving on to the next thing you "think you need"...
  • edited September 21
    EXACTLY.
    Kuma? lasted 5 seconds.
    Lavalink? Didn't even bother--too much blah-blah, too little optimisation
    gohttpserver self-compiled? Took me an hour of tweaking (and resizing) to get the right amount of RAM without triggering OOMKiller, lasted 10 minutes and vanished.
    "just-in-case-i-need" VNC? Has lasted 3 months, haven't seen a need yet but I can see it coming soon..... hopefully....
    Amazing service though, shows me how foolish I can be, maybe I need to learn Docker
    EXACTLY.
    Sounds fun! Nothing better then the feeling of completing a project you thought was near impossible!
    Highly recommend learning docker. Makes life easy for others.
    User: Your app doesn't work for me
    Dev: But it works fine on my system
    Docker: Give your system & configs to the user?
    After the Maintenance I checked a few things, I noticed that Console / Shell was partially broken on some nodes.
    I pinned the issue down, however still working on a fix, no ETA currently, probably, some breaking change to hypervisor, despite its LTS.
  • PK, Islamabad IPv6 down?
    I forwarded it.
    Thanked by (1)SwordfishBE
    I am trying to reach out to the dev, I would have to change at least partially if not entirely the backend.
    This should be fixed until the end of the week though.
    A security issue has been fixed with this update, which has not been published yet.
    As precaution, I also disabled Console / Shell for LXD nodes, probably it also affects LXD which hasn't been patched yet.
    I have theoretically a fix, to make it work again, gimme some time to implement it though.
    I just learned a few hours ago, what the actually cause is.
    Thanked by (1)Wonder_Woman
  • @Neoon said:
    I forwarded it.
    Works again! Thnx
