[FOSSVPS - Alexhost] Free Chisinau 2 x E5-2680 v2, 4 vCores, 4 GB DDR3 ECC RAM, 100 GB RAID 10 Disk!
124»
    @jmaxwell
    Your VPS is rebuilt from scratch since restoring from the snapshot did not work. The new version is not using backing store, which means everything needed is actually within your qcow2 file.
    Everything should work as before. I have tested that I can get in on IPv4 and on IPv6. Please remove my keys if you wish. Password login is disabled. Yabs from inside your VPS is shown below.
    Please post here to let us know if you get in and if everything looks okay.
    Sorry about continuing problems!
    Best wishes!
    Tom
    No worries, I got in and all looks good. Thanks for fixing.
    Why?
    Wow! The VPS which was restored using @cmeerw's brilliant method of copying the deleted qcow2 file out of /proc seems to have worked! At the least, the VPS now is running again, and it responds to ping and ping6. I'm waiting to hear from the client about whether he can log in and if everything looks good. Command line output posted at https://www.nodeseek.com/post-431916-37#365. Double wow if the VPS looks good from inside!!
    Thanked by (2)cmeerw tmntwitw
    Stop giving away all our secrets publicly!!! Keep this up and people won't need us anymore!! Well won't need you everyone needs the Yeti.
    Here is the status of the Alexhost Chisinau node following this morning's data center power maintenance. If your Alexhost VPS still needs an adjustment, please let me know. Thanks!
    root@alexhost:~# date; uptime
    Mon Oct  6 15:12:00 UTC 2025
     15:12:00 up  3:30,  1 user,  load average: 4.22, 4.40, 4.30
    root@alexhost:~# virsh list
     Id   Name   State
     3    vm19   running
     7    vm12   running
     8    vm1    running
     9    vm13   running
     10   vm14   running
     11   vm16   running
     12   vm4    running
     14   vm6    running
     15   vm3    running
     16   vm21   running
     17   vm10   running
     18   vm17   running
     19   vm9    running
     20   vm15   running
     21   vm5    running
     22   vm11   running
     23   vm2    running
     24   vm7    running
     25   vm18   running
     26   vm8    running
    root@alexhost:~# cd vm-seed/vm29-@千狐/
    root@alexhost:~/vm-seed/vm29-@千狐# virsh start vm29
    Domain 'vm29' started
    root@alexhost:~/vm-seed/vm29-@千狐# virsh autostart vm29
    Domain 'vm29' marked as autostarted
