1404405406407408410»
  • I would say "don't be a dick" should apply equally to a provider or member.
    Your example about Hetzner does not contradict my earlier comment
    @msatt said: There has to be a line drawn where node down for X period without any view to fixing means suspend tag.
    All the provider needs to do is say (somewhere) what and when things are happening to avoid the suspension.
    I don't want to load the mods with any extra work but there should be a standard rule for this.
    The provider is not providing, so suspend.
    To avoid issues this must be node related NOT user related.
    1 month is (I believe) a very reasonable period.
    i think its a little heavy to impose some kind of SLA as:
    • this is lowend
    • LES isn't paid in anyway to vet providers or enforce/monitor such SLAs
    • you will still want more providers willing to advertise than not and this doesn't help
    • Virmach has always been Virmach; first time?
  • JabJab Senpai
    So, did anyone heard anything from VirMach?
    Website update, blog update (LOL), ticket update, status update? Anything?
  • @cybertech
    I think these are very reasonable comments particularly
    I still feel there should be a way to indicate a provider is not providing.
    Just throwing out an idea - how about a "Provider not Providing" thread (sticky) in which a provider can be named if the criteria (whatever that is) is met. The provider details could be removed if they subsequently return to normality. The thread should be locked and an entry is made or removed based on confirmed posts by members.
    At least this method means vetting of the provider remains consistent and should not stop providers from coming to LES.
    Also a regular comment is 'do your own research', well at least the "Provider not providing" thread would be a good starting point.
