Just for fun: Installing 2019 Vanilla Forums software on LTS Debian 11 Bullseye in 2025!
Thanks to and following the kind suggestions from @nwnuyhs here at LES, I decided to try installing the 2019 Version 3.3 of Vanilla Forums on Debian 11 LTS Bullseye.
I am posting here as I go along, just for fun. Besides a few laughs, I also will appreciate friendly suggestions and corrections.
The steps should be, approximately, the same as recommended by @nwnuyhs:
- Get a VPS
- Install aapanel
- Use aapanel to install nginx, PHP 7.4, and mysql 5.7 database
- Download the Vanilla zip
- Extract the Vanilla zip in the website root
- Visit website URL to install
Thanked by (1)nwnuyhs
Step 1: Get a VPS
I provisioned a small VPS at Upcloud. The reason I selected Upcloud was that they still offer one click installation of Debian 11. Plus I had some unused account credits.
Step 2: Install aapanel
With one click I can copy the aapanel install command! Then I can paste the command into root's terminal on the VPS.
Here is a paste of the aapanel install command as I copied it:
I was surprised to be asked for my email at the critical moment when I was wondering whether the one click copy had succeeded:
Running the pasted command as root seems to have succeeded.
I saved 2,024 lines of terminal output. Hundreds of packages were installed.
At the end of the terminal output, I saw login credentials:
Let's go see if we can access the panel. . . .
Yes.
Mostly in accordance with @nwnuyhs' instructions I changed some of the default aapanel software install versions to older versions:
I clicked the One-click button. A pop-up appeared with lots of installs listed. I watched for a while as the installs rushed by, then ate some dinner. When I returned, I saw that there were no remaining tasks and no messages, so maybe that means success. Clicking Execution log shows what seemed like an okay result.
Should an nginx default page be showing on WAN port 80 at this point in the process? I don't see anything on port 80 from outside. Is that a problem? Ah! Lynx does seem to find something at http://127.0.0.1:
Yes, looks like nginx is running:
The next step is to download and extract the Vanilla zip. There doesn't seem to be a /var/www or a /var/www/html directory, so I decided to try to wget the zip to the root directory and extract it later. But where to extract? I never used aapanel or nginx before. . . . Maybe aapanel has a special location for the root directory. Maybe I should look at the aapanel some more. @nwnuyhs
Here below is the interesting download transcript for the Vanilla zip. Can anyone give me a hint about what's going on with those long strings? Also, is there a checksum for the download? Thanks!
I am guessing that I have to add a website in aapanel before I get a webroot directory into which to extract the Vanilla zip.
aapanel best panel
Okay, added a site with aapanel. Webroot found at /www/wwwroot/$site_name.xxx. Seems to render from WAN. No security certificate yet. Here's from my Chromebook in Mexico:
Headed over to /www/wwwroot/$site_name.xxx and unzipped the vanilla-3.3.zip.
Unzipping made a new subdirectory called package. Here's what's inside the package subdirectory:
The README.md file doesn't seem to offer install instructions. If I go in my browser to http://$site_name.xxx/ the default web page shows the same as in the above screenshot. If I point the browser at http://$site_name.xxx/package, I get
The package subdirectory and all the many, many files and directories inside it are owned by root:root, not www:www. That doesn't seem right.
Did I unzip incorrectly? Should the contents of the package subdirectory be one level higher, inside /www/wwwroot/$site_name.xxx? If I had unzipped one level higher in /www/wwwroot and then changed the directory name "package" to $site_name.xxx plus chown everything to www:www, maybe that would have worked? Thanks!
look at who owns "$site_name.xxx" or "wwwroot" and chown all directories and files to that user:group
sorry too late to reply @Not_Oles
I find from this step you maybe face some problem, I will record a video for you
Headed over to /www/wwwroot/$site_name.xxx and unzipped the vanilla-3.3.zip.Just wait for me
This is the video:
sorry, the video has a mistake,the aapanel recommend to use free version , rather than the pro version
aaPanel Free edition install script
URL=https://www.aapanel.com/script/install_7.0_en.sh && if [ -f /usr/bin/curl ];then curl -ksSO "$URL" ;else wget --no-check-certificate -O install_7.0_en.sh "$URL";fi;bash install_7.0_en.sh aapanelSo good, the professional version gives you the Task Manager twice: https://www.aapanel.com/new/pricing.html
And had their reddit thread banned... but it's still listed in their website
https://www.reddit.com/r/aaPanel_Offical/
You can use free version
State owned control panel?
Yeap and as far as I can tell no official release to patch the vulnerabilities they had a few years ago
Just curious: why not use the latest OSS version, which is OSS Release 2025.010 (LTS 2)? See https://github.com/vanilla/vanilla/releases
As far as I can tell, the OSS version is no longer supported or encouraged by Higher Logic, which is the company that now owns Vanilla (now called "Higher Logic Vanilla"). The web site makes no mention of the OSS version (unless I've missed it): https://www.higherlogic.com/vanilla/
Thanks to everyone who has read this thread an also to those who have posted helpful comments!
Thanks especially to @nwnuyhs for his helpful video! I am at 4:09 of the 8:59 minutes. Of course I will watch the remainder of the video.
As shown in @nwnuyhs' video I successfully used aapanel to issue the SSL certificate. Chrome now shows a secure connection.
Here is a screenshot of the beginning of the SSL certificate issuance inside aapanel:
I saw that @nwnuyhs' video showed using aapanel to unzip the vanilla-3.3.zip. I am guessing that aapanel probably extracts the files with ownership different than root:root, probably www:www. But I am not sure.
As root, I unzipped vanilla-3.3.zip into /www/wwwroot. This gave me /www/wwwroot/project, which I changed to /www/wwwroot/$site_name.xxx. Loading the site again gave the fatal Twig error mentioned above:
So I changed ownership of /www/wwwroot/$site_name.xxx to www:www.
Reloading https://site_name.xxx in Chrome gave me progress--an error message from the Vanilla Version 3.3 installer telling me:
Rather than changing ownership of all the files, which might be the correct fix, let's just fix these two errors and see which errors are next. /s
So now I see the Vanilla 3.1 installer.
You are welcome.
And congratulation to you
you are nearly successful to install Vanilla
We really believe in you @Not_Oles !
Making some great progress in this thread
Please confirm it @wadhah
LOL, I'll stick to the free (community) version of Virtualmin, thank you very much! Rather not use a control panel called "AA"Panel, cause they wanted to be listed on top of the, erm, yellow pages? I dont know of any other place that lists companies alphabetically...
It did remind me of the ABCHosting, XYZHosting and other 3 letter CC hosting on LET...
Those are called "features". These so called vulnerabilities allow remote access to ensure you are compliant
@AlwaysSkint @AuroraZero @angstrom
I know zero about aapanel. I never used it before.
Apparently the newly released 2025 version of Vanilla might be in some kind of a development status and needs work before it can be used. I messed with it a while back and had a dozen or more errors from composer.
Yes, if I understand correctly, open source is no longer supported by the company behind Vanilla.
No plans here to actually run a Vanilla instance in production. Just having some fun trying the install old version 3.3. I am using Debian 11 because that's what @nwnuyhs used. I imagined that old Vanilla version 3.3 might be more likely to work on an old version of Debian.
Since I invest so much time here at LES using Vanilla, I think it would be fun to have Vanilla running in an isolated throwaway VPS for a day or two and to be able to look at the actually running Vanilla source code in my terminal.
Thanks, friends, for watching my back!
Best wishes!
Please see this datebase config @Not_Oles
@nwnuyhs
Great! Thanks! I am in now, as you can see.
There seemed to be two problems which now are fixed. First, when set up the database originally, I think the name I originally gave was 18 characters, which might have been a couple of characters too long. I think the name was truncated at 16 characters, without me realizing what had happened.
Second, when I cut and pasted the information from the aapanel -- exactly as shown in your very helpful screenshot above -- somehow a space was added following the database name. Thank you @nwnuyhs very much! Shishi!
So now I will ask, please, for configuration hints to make my install look more like @nwnuyhs install which looks a lot like LES.
Thanks again so much!
Tom
