@somik said: Go with option 2 and then create a cluster so all VMs can be managed from 1 proxmox panel. Makes creating accounts in different regions much easier.
Understood - but current users lose everything hence option 3 i.e. your suggestion works with new hosts going forward.
Feedback appreciated.
Send an email out giving the timeline of events and explicitly state back up your important data. Do the switch give users the new login credentials.
@AuroraZero said: Send an email out giving the timeline of events and explicitly state back up your important data. Do the switch give users the new login credentials.
Thats fine, give me someone to blame ;-)
The Yeti has broad shoulders he can take the heat for ya!!!
@Not_Oles, can give me root access to the server in 1 weeks time?
I want to test what happens if you run rm -rf / && reboot on it
rm -rf / && reboot
on itNever make the same mistake twice. There are so many new ones to make.
You will get some errors. Not all the directories in / like being deleted, even by root.
Ya, but last time i tried, it failed to reboot after that
