Both my default install (please see above screenshot) and the install of @nwnuyhs seem to be using the same Vanilla default "Keystone" theme. In the default setup the name of the selected theme seems to show at the bottom left of the page.
My guess is that LES and @nwnuyhs made a few changes in the CSS. Maybe something more was changed as well.
I'm hoping that @nwnuyhs will kindly comment about what changes he made to the default vanilla-3.3 install to make his install look more like LES.
Excellent! I adjusted the CSS in accordance with @nwnuyhs' above linked description on LowEndAI.com. Now there is what might be described a basic 2019 vanilla-3.3 install which looks somewhat similar to LES and to LowEndAI.
I think I want to poke around a little more with my terminal. Then I think this little project might be finished, unless someone wants something more?
Sincere thanks to @nwnuyhs for being so super helpful and friendly!
Default Vanilla 3.3 Home Page
So ugly
How to make it better?
Themes
Thanks!
Quite easy to get css from LES. As long as you dont use it publicly, it's not even illegal.
I post the custom css here :
https://lowendai.com/discussion/21/how-to-use-custom-css-in-vanilla-forums-inspired-by-lowendspirit-style/p1?new=1
Try the latest dockerized build and compare between the two: https://github.com/vanilla/vanilla-docker
Install docker with composer:
https://docs.docker.com/engine/install/
Clone the repo
Go into the cloned directory and build the images:
Once the build is done, start up the containers:
The vanilla forum should be running on port 80 of your server.
If you already have nginx or something else installed and want to make it run on a different port (other then 80), edit the
docker-compose.yml
file, line 78:https://github.com/vanilla/vanilla-docker/blob/17afb06520b31fb2fe514bad6cfd880a1a9f3b87/docker-compose.yml#L78
Change the 80 to any number you like, 8888 for example:
Maybe someone might be interested in the yabs for the €3.00/month Upcloud VPS on which this thread's project is running. Please see also https://lowendspirit.com/discussion/comment/219926/#Comment_219926 for more details on the VPS.
