Free Dedicated Server Share -- Bucharest -- Thanks Hosteroid!
When is Bucharest going live? 🤔
Does anyone want to share the Bucharest FOSSVPS node with me? Free.
You can work directly on the node from your shell account. You can make containers, KVM VPSes, and use proot or chroot, plus more!
There are 5 IPv4s and an IPv6/48. Bucharest is running Debian unstable (sid).
I really like the Bucharest node! Thanks Hosteroid! ![]()
- Lots of cores!
root@hosteroid:~# nproc
56
root@hosteroid:~#
- ECC RAM!
root@hosteroid:~# dmidecode | grep "Total Width: 72 bits"
root@hosteroid:~#
root@hosteroid:~# free -h
Mem: 251Gi 2.3Gi 250Gi 5.0Mi 802Mi 249Gi
Swap: 3.8Gi 0B 3.8Gi
root@hosteroid:~#
- RAID 10!
from lspci:
root@hosteroid:~# lspci -knn | grep 'RAID bus controller'
02:00.0 RAID bus controller [0104]: Broadcom / LSI MegaRAID SAS-3 3108 [Invader] [1000:005d] (rev 02)
root@hosteroid:~#
from dmesg:
[ 1.574536] scsi host0: Avago SAS based MegaRAID driver
[ 1.582363] scsi host1: ahci
[ 1.582623] scsi host2: ahci
[ 1.582867] scsi host3: ahci
[ 1.583118] scsi host4: ahci
[ 1.583192] ata1: SATA max UDMA/133 abar m2048@0x92301000 port 0x92301100 irq 113 lpm-pol 0 ext
[ 1.583196] ata2: SATA max UDMA/133 abar m2048@0x92301000 port 0x92301180 irq 113 lpm-pol 0 ext
[ 1.583199] ata3: SATA max UDMA/133 abar m2048@0x92301000 port 0x92301200 irq 113 lpm-pol 0 ext
[ 1.583201] ata4: SATA max UDMA/133 abar m2048@0x92301000 port 0x92301280 irq 113 lpm-pol 0 ext
[ 1.583436] ahci 0000:00:1f.2: SSS flag set, parallel bus scan disabled
[ 1.593530] ahci 0000:00:1f.2: AHCI vers 0001.0300, 32 command slots, 6 Gbps, SATA mode
[ 1.593535] ahci 0000:00:1f.2: 6/6 ports implemented (port mask 0x3f)
[ 1.593538] ahci 0000:00:1f.2: flags: 64bit ncq stag led clo pio slum part ems apst
- Rules and Warnings
Free and open source software only.
White hat only.
Be awesome!
Fair use.
Not for commercial use.
No service level agreement.
Ephemeral. Could disappear at any moment!
Clueless™ Administrator!
- How to Apply
Post in this thread, please. Sorry, no PMs, no emails.
Please include or link to your ed25519 ssh public key.
Please include links about yourself, e.g., website, blog, source code repository, other forums.
What do you want to run on the server?
- Yabs
root@hosteroid:~# curl -sL yabs.sh | bash
# Yet-Another-Bench-Script #
# v2025-04-20 #
Sat Oct 11 10:12:32 PM UTC 2025
Uptime : 4 days, 18 hours, 31 minutes
Processor : Intel(R) Xeon(R) CPU E5-2690 v4 @ 2.60GHz
CPU cores : 56 @ 1200.000 MHz
AES-NI : ✔ Enabled
RAM : 251.8 GiB
Swap : 3.8 GiB
Disk : 3.6 TiB
Distro : Debian GNU/Linux forky/sid
Kernel : 6.16.9+deb14-amd64
VM Type : NONE
ISP : Castlegem SRL
ASN : AS34689 Castlegem SRL
Host : HOSTEROID Bucharest
Country : Romania
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/mapper/hosteroid--vg-root):
Read | 95.91 MB/s (23.9k) | 918.19 MB/s (14.3k)
Write | 96.17 MB/s (24.0k) | 923.02 MB/s (14.4k)
Total | 192.09 MB/s (48.0k) | 1.84 GB/s (28.7k)
Read | 794.27 MB/s (1.5k) | 791.87 MB/s (773)
Write | 836.47 MB/s (1.6k) | 844.61 MB/s (824)
Total | 1.63 GB/s (3.1k) | 1.63 GB/s (1.5k)
Clouvider | London, UK (10G) | 843 Mbits/sec | 857 Mbits/sec | 92.0 ms
Eranium | Amsterdam, NL (100G) | 924 Mbits/sec | 917 Mbits/sec | 34.2 ms
Uztelecom | Tashkent, UZ (10G) | 868 Mbits/sec | 643 Mbits/sec | 121 ms
Leaseweb | Singapore, SG (10G) | 715 Mbits/sec | 522 Mbits/sec | 180 ms
Clouvider | Los Angeles, CA, US (10G) | 725 Mbits/sec | 477 Mbits/sec | 167 ms
Leaseweb | NYC, NY, US (10G) | 777 Mbits/sec | 590 Mbits/sec | 109 ms
Edgoo | Sao Paulo, BR (1G) | 669 Mbits/sec | 467 Mbits/sec | 220 ms
Clouvider | London, UK (10G) | 824 Mbits/sec | 659 Mbits/sec | 52.6 ms
Eranium | Amsterdam, NL (100G) | 911 Mbits/sec | 902 Mbits/sec | 34.3 ms
Uztelecom | Tashkent, UZ (10G) | 847 Mbits/sec | 383 Mbits/sec | 120 ms
Leaseweb | Singapore, SG (10G) | 624 Mbits/sec | 557 Mbits/sec | --
Clouvider | Los Angeles, CA, US (10G) | 750 Mbits/sec | 356 Mbits/sec | 167 ms
Leaseweb | NYC, NY, US (10G) | 844 Mbits/sec | 617 Mbits/sec | 109 ms
Edgoo | Sao Paulo, BR (1G) | 611 Mbits/sec | 467 Mbits/sec | 220 ms
Test | Value
Single Core | 1113
Multi Core | 10111
Full Test | https://browser.geekbench.com/v6/cpu/14402584
YABS completed in 13 min 11 sec
root@hosteroid:~#
@Not_Oles and @Hosteroid are awesome
Thank you @Hosteroid these contributions will really benefit others through @Not_Oles hard work.
