Well, Virmach has been busy..
My previously mentioned great Chicago server had been flapping for weeks:
Uptime: 23:09
Yay. Long may it last.
I've been fairly lucky with my VPSes and their downtime, but there definitely have been some hiccups. Hopefully he'll get his act together as Black Friday is coming up!
@localhost said:
Anyone seeing issues with LAX flip flopping every 20 mins or so? I am using thr default template install (tried both windows and linux)
Wanna know if its just me or everyone...
Over the past month, my VPS in Los Angeles has been going offline and then coming back online after a few minutes—this has happened hundreds (maybe even thousands) of times.
I'm not sure if @VirMach has noticed this or is addressing the issue.
Ahh
Ok, so I am not alone and it seems to be the norm.
O well.
Atleast it comes back up
Ahh
O well.
LAX1Z020, right?
Uptime: 23:09
CHIZ035?
I want to know as well.
I've heard people talk about it as if it's the entire LAX location, so if other nodes are involved please let me know.
@VirMach said: I want to know as well.
Happens for me on LAXA019, LAXA022, LAXA026, LAXA029, and LAXA031. Network flaps a few times a day, had six occurrences yesterday. Normally back up within 10 minutes or so. Some times it's all the nodes at the same time, sometimes one, two, or three at the same time. VPS does not reboot or anything like that. It appears to be network related.
LAXA007 network has been flapping since September 6th. Seems like roughly between one and five 20-40 minute outages a day. It stopped October 8-10 then resumed on the 11th and continues today:
LAX1Z020, right?
I believe this issue affects the entire Los Angeles network.
I can't wait for this LAX1Z020 server to be fixed... (phantom) Ticket #989759 opened since 24/AUG/2025 (2 months anniversary in 9 days!). Will an extension of service be granted?
🤡 "The tags provided to users are worthless & permanent labels~ accept them or leave!" 🤡
Hi!
I also experienced the network issue on LAX location. The VM's running, but the network going 'up' and 'down, continuously 'flapping'. it's really annoying :$ Nodes: RYZE.LAX-A026.VMS, RYZE.LAX-A019.VMS, RYZE.LAX-A017.VMS
My VPS from node "ATLZ033" also unreachable.
"Main server IP: offline, Node server: offline" - https://prnt.sc/BNNFoezWsaTV
I opened a ticket to report this anomaly, because I not found any ongoing known issue with this node name on the 'network status' page, (Ticket ID: #968802).
It doesn't seem to be a problem with a single node, but rather a problem with the entire Los Angeles network...
The gateway including IP is also extremely unstable...
"RYZE.LAX-A019.VMS"
In the past 90 days, there have been 152 malfunctions, accumulating 13 hours, 41 minutes and 32 seconds, with an average availability rate of 99.36%
@VirMah OKC's network is experiencing issues again, with carriers including China Unicom completely unreachable and network bandwidth also appearing to have decreased.
I will say, outside of the routing issues the Oklahoma network has been pretty decent for me. I've been transferring some backups across the US and it's been holding a pretty solid 530mbit over sftp, and I think that's my receiving server's fault for not being higher. going to finish up this copy much faster than I expected. Hope I'm not killing someone else's bandwidth over here in the meantime.
Ok ongoing 'flapping' enabled.
Ahh
O well.
LAX1Z020, right?
CHIZ035?
i see similar issues on LAX1Z021 but always just for minutes.
LAX1Z021
LAXA017
these are the 2 ones I am seeing
Thanks much
LAX-Z0015 has had the network drop every 5 minutes for the last 2 months or so, I just shut it off about a month ago because its useless.
My VPS is located in node LAXA009.
Weekly Uptime Monitoring Report
6th Oct - 12th Oct
Recent DOWNTIMES
Start Time End Time Down
2025/10/14 6:04 2025/10/14 6:07 3min
2025/10/14 5:29 2025/10/14 5:31 2min
2025/10/14 4:56 2025/10/14 4:58 2min
2025/10/14 4:02 2025/10/14 4:04 2min
2025/10/14 3:42 2025/10/14 3:45 3min
2025/10/14 1:21 2025/10/14 1:27 6min
2025/10/14 0:22 2025/10/14 0:23 1min
2025/10/13 23:58 2025/10/14 0:00 2min
2025/10/13 23:39 2025/10/13 23:40 1min
2025/10/13 22:57 2025/10/13 23:01 4min
2025/10/13 22:39 2025/10/13 22:41 2min
2025/10/13 22:18 2025/10/13 22:21 3min
2025/10/13 21:53 2025/10/13 21:55 2min
2025/10/13 21:27 2025/10/13 21:31 4min
2025/10/13 20:42 2025/10/13 20:44 2min
2025/10/13 20:22 2025/10/13 20:23 1min
2025/10/13 19:07 2025/10/13 19:10 3min
2025/10/13 18:29 2025/10/13 18:31 2min
2025/10/13 17:45 2025/10/13 17:48 3min
2025/10/13 16:46 2025/10/13 16:48 2min
2025/10/13 15:59 2025/10/13 16:06 7min
2025/10/13 15:19 2025/10/13 15:22 3min
2025/10/13 14:43 2025/10/13 14:45 2min
2025/10/13 14:03 2025/10/13 14:06 3min
2025/10/13 13:25 2025/10/13 13:28 3min
2025/10/13 12:29 2025/10/13 12:30 1min
2025/10/13 12:02 2025/10/13 12:10 8min
2025/10/13 11:42 2025/10/13 11:44 2min
2025/10/13 11:16 2025/10/13 11:22 6min
2025/10/13 9:42 2025/10/13 9:43 1min
2025/10/13 8:03 2025/10/13 8:04 1min
2025/10/13 7:44 2025/10/13 7:47 3min
2025/10/13 7:20 2025/10/13 7:24 4min
2025/10/13 6:25 2025/10/13 6:27 2min
2025/10/13 4:55 2025/10/13 5:01 6min
2025/10/13 4:37 2025/10/13 4:38 1min
2025/10/13 4:01 2025/10/13 4:05 4min
2025/10/13 3:42 2025/10/13 3:44 2min
2025/10/13 2:37 2025/10/13 2:40 3min
2025/10/13 2:19 2025/10/13 2:21 2min
2025/10/13 1:40 2025/10/13 1:41 1min
2025/10/13 0:27 2025/10/13 0:30 3min
2025/10/12 20:58 2025/10/12 20:59 1min
2025/10/12 20:36 2025/10/12 20:38 2min
2025/10/12 20:14 2025/10/12 20:19 5min
2025/10/12 19:39 2025/10/12 19:40 1min
2025/10/12 18:45 2025/10/12 18:49 4min
2025/10/12 18:08 2025/10/12 18:09 1min
2025/10/12 17:46 2025/10/12 17:48 2min
2025/10/12 16:14 2025/10/12 16:15 1min
2025/10/12 15:52 2025/10/12 15:54 2min
2025/10/12 14:41 2025/10/12 14:42 1min
2025/10/12 14:21 2025/10/12 14:23 2min
2025/10/12 14:00 2025/10/12 14:02 2min
2025/10/12 13:35 2025/10/12 13:38 3min
2025/10/12 13:14 2025/10/12 13:19 5min
2025/10/12 10:58 2025/10/12 11:00 2min
2025/10/12 7:51 2025/10/12 7:54 3min
2025/10/12 6:54 2025/10/12 6:56 2min
2025/10/12 5:32 2025/10/12 5:34 2min
2025/10/12 4:37 2025/10/12 4:40 3min
2025/10/12 4:19 2025/10/12 4:20 1min
2025/10/12 3:40 2025/10/12 3:42 2min
2025/10/12 3:22 2025/10/12 3:23 1min
2025/10/12 3:05 2025/10/12 3:07 2min
2025/10/12 2:09 2025/10/12 2:10 1min
2025/10/12 1:31 2025/10/12 1:47 16min
2025/10/12 0:56 2025/10/12 0:59 3min
2025/10/11 23:41 2025/10/11 23:44 3min
2025/10/11 23:19 2025/10/11 23:25 6min
2025/10/11 21:59 2025/10/11 22:03 4min
2025/10/11 20:37 2025/10/11 20:43 6min
2025/10/11 20:20 2025/10/11 20:22 2min
2025/10/11 16:40 2025/10/11 16:45 5min
2025/10/11 16:18 2025/10/11 16:24 6min
2025/10/11 15:24 2025/10/11 15:31 7min
2025/10/11 15:04 2025/10/11 15:07 3min
2025/10/11 14:24 2025/10/11 14:28 4min
2025/10/11 14:05 2025/10/11 14:06 1min
2025/10/11 13:44 2025/10/11 13:45 1min
2025/10/11 13:06 2025/10/11 13:07 1min
2025/10/11 12:22 2025/10/11 12:26 4min
2025/10/11 12:05 2025/10/11 12:06 1min
2025/10/11 11:41 2025/10/11 11:44 3min
2025/10/11 10:31 2025/10/11 10:33 2min
2025/10/11 9:36 2025/10/11 9:37 1min
2025/10/11 9:16 2025/10/11 9:18 2min
2025/10/11 7:45 2025/10/11 7:46 1min
2025/10/11 7:35 2025/10/11 7:41 6min
2025/10/11 5:51 2025/10/11 5:54 3min
2025/10/11 5:17 2025/10/11 5:18 1min
2025/10/11 4:17 2025/10/11 4:21 4min
2025/10/11 2:43 2025/10/11 2:44 1min
2025/10/11 1:45 2025/10/11 1:46 1min
2025/10/11 0:45 2025/10/11 0:47 2min
2025/10/10 23:41 2025/10/10 23:45 4min
2025/10/10 22:57 2025/10/10 23:00 3min
2025/10/10 22:18 2025/10/10 22:21 3min
2025/10/10 20:46 2025/10/10 20:48 2min
2025/10/10 19:49 2025/10/10 19:55 6min
2025/10/10 19:08 2025/10/10 19:09 1min
2025/10/10 17:27 2025/10/10 17:30 3min
2025/10/10 17:05 2025/10/10 17:07 2min
2025/10/10 16:26 2025/10/10 16:29 3min
2025/10/10 16:04 2025/10/10 16:06 2min
2025/10/10 14:22 2025/10/10 14:25 3min
2025/10/10 13:47 2025/10/10 13:50 3min
2025/10/10 11:48 2025/10/10 11:51 3min
2025/10/10 11:09 2025/10/10 11:12 3min
2025/10/10 10:48 2025/10/10 10:50 2min
2025/10/10 10:26 2025/10/10 10:28 2min
2025/10/10 9:39 2025/10/10 9:47 8min
2025/10/10 9:19 2025/10/10 9:21 2min
2025/10/10 8:40 2025/10/10 8:42 2min
2025/10/10 8:19 2025/10/10 8:21 2min
2025/10/10 7:44 2025/10/10 7:47 3min
2025/10/10 7:09 2025/10/10 7:11 2min
2025/10/10 4:51 2025/10/10 4:52 1min
2025/10/10 3:53 2025/10/10 3:58 5min
2025/10/10 2:47 2025/10/10 2:55 8min
2025/10/10 2:30 2025/10/10 2:32 2min
2025/10/10 1:53 2025/10/10 1:57 4min
2025/10/10 1:31 2025/10/10 1:38 7min
2025/10/9 23:35 2025/10/9 23:38 3min
2025/10/9 22:18 2025/10/9 22:20 2min
2025/10/9 21:01 2025/10/9 21:02 1min
2025/10/9 20:37 2025/10/9 20:38 1min
2025/10/9 20:13 2025/10/9 20:18 5min
2025/10/9 19:32 2025/10/9 19:36 4min
2025/10/9 19:15 2025/10/9 19:17 2min
2025/10/9 18:56 2025/10/9 18:57 1min
2025/10/9 18:38 2025/10/9 18:40 2min
2025/10/9 18:17 2025/10/9 18:20 3min
2025/10/9 17:23 2025/10/9 17:24 1min
2025/10/9 14:40 2025/10/9 14:41 1min
2025/10/9 12:17 2025/10/9 12:20 3min
2025/10/9 11:53 2025/10/9 11:58 5min
2025/10/9 10:51 2025/10/9 10:55 4min
2025/10/9 10:08 2025/10/9 10:10 2min
2025/10/9 8:55 2025/10/9 8:57 2min
2025/10/9 8:26 2025/10/9 8:33 7min
2025/10/9 8:07 2025/10/9 8:08 1min
2025/10/9 7:39 2025/10/9 7:45 6min
2025/10/9 7:18 2025/10/9 7:19 1min
2025/10/9 5:56 2025/10/9 6:03 7min
2025/10/9 3:38 2025/10/9 3:46 8min
2025/10/9 3:19 2025/10/9 3:20 1min
2025/10/9 2:59 2025/10/9 3:02 3min
2025/10/9 0:20 2025/10/9 0:21 1min
2025/10/8 21:38 2025/10/8 21:40 2min
2025/10/8 19:41 2025/10/8 19:45 4min
2025/10/8 18:24 2025/10/8 18:27 3min
2025/10/8 16:12 2025/10/8 16:17 5min
2025/10/8 14:25 2025/10/8 14:26 1min
2025/10/8 13:39 2025/10/8 13:41 2min
2025/10/8 13:00 2025/10/8 13:02 2min
2025/10/8 12:38 2025/10/8 12:40 2min
2025/10/8 11:20 2025/10/8 11:21 1min
2025/10/8 10:47 2025/10/8 10:49 2min
2025/10/8 10:29 2025/10/8 10:30 1min
2025/10/8 8:08 2025/10/8 8:11 3min
2025/10/8 7:47 2025/10/8 7:49 2min
2025/10/8 6:17 2025/10/8 6:18 1min
2025/10/8 5:23 2025/10/8 5:28 5min
2025/10/8 3:41 2025/10/8 3:42 1min
2025/10/8 3:16 2025/10/8 3:20 4min
2025/10/8 2:01 2025/10/8 2:02 1min
2025/10/8 0:42 2025/10/8 0:43 1min
2025/10/8 0:25 2025/10/8 0:27 2min
2025/10/8 0:07 2025/10/8 0:09 2min
2025/10/7 23:44 2025/10/7 23:45 1min
2025/10/7 23:17 2025/10/7 23:20 3min
2025/10/7 22:57 2025/10/7 22:59 2min
2025/10/7 22:22 2025/10/7 22:23 1min
2025/10/7 21:05 2025/10/7 21:07 2min
2025/10/7 20:28 2025/10/7 20:29 1min
2025/10/7 19:09 2025/10/7 19:15 6min
2025/10/7 16:57 2025/10/7 16:59 2min
2025/10/7 15:57 2025/10/7 16:00 3min
2025/10/7 15:33 2025/10/7 15:39 6min
2025/10/7 13:47 2025/10/7 13:49 2min
2025/10/7 10:19 2025/10/7 10:20 1min
2025/10/7 9:43 2025/10/7 9:48 5min
2025/10/7 8:42 2025/10/7 8:46 4min
2025/10/7 7:41 2025/10/7 7:42 1min
2025/10/7 7:04 2025/10/7 7:06 2min
2025/10/7 6:04 2025/10/7 6:08 4min
2025/10/7 5:19 2025/10/7 5:23 4min
2025/10/7 3:42 2025/10/7 3:44 2min
2025/10/7 2:28 2025/10/7 2:31 3min
2025/10/7 2:10 2025/10/7 2:11 1min
2025/10/7 0:48 2025/10/7 0:50 2min
2025/10/7 0:32 2025/10/7 0:33 1min
2025/10/7 0:16 2025/10/7 0:17 1min
2025/10/6 23:54 2025/10/6 23:58 4min
2025/10/6 23:36 2025/10/6 23:38 2min
2025/10/6 22:37 2025/10/6 22:38 1min
2025/10/6 21:38 2025/10/6 21:42 4min
2025/10/6 20:46 2025/10/6 20:48 2min
2025/10/6 20:30 2025/10/6 20:31 1min
2025/10/6 20:08 2025/10/6 20:15 7min
2025/10/6 19:25 2025/10/6 19:27 2min
2025/10/6 19:02 2025/10/6 19:08 6min
Yup. Stable for 2 days now.
I'm hungry but I should be sleeping
Eat in your dreams. It's free food!
@Virmach, any update on ATLZ033? I.P is not even pinging, dead.
LAX1Z020server to be fixed... (phantom) Ticket #989759 opened since 24/AUG/2025 (2 months anniversary in 9 days!). Will an extension of service be granted?🤡 "The tags provided to users are worthless & permanent labels~ accept them or leave!" 🤡
We've doubled your current service state
@VirMach
Hi!
"RYZE.LAX-A019.VMS"
All of L.A Nodes were off and came back.
Atlanta is still off.
Kick back and enjoy the buz.
ATLZ033 down 6d ago
TYOC027 down 24d ago
AMSD025 down 65d ago
NYCB037 down 3mo+ ago
And MIA?
/me shakes fist.
All of L.A Nodes are off again.
Looks up again.
