BanatSync – 10Gbps IPv6-Only VPS – starting from $4.08/month
Greetings LES!
We're introducing our newest product: IPv6 only VPS with 10Gbps Uplink
Monthly price is €3.50 (~$4.08)
Annual price is €42/year (equivalent to €3.50/month)
Traffic limit is: 50TB/month
Limited offer: only 10 VPS available!
Order here: 10Gbps IPV6 VPS
YABS:
# Yet-Another-Bench-Script #
# v2025-04-20 #
Fri Oct 17 23:09:17 BST 2025
Uptime : 0 days, 0 hours, 0 minutes
Processor : Intel(R) Xeon(R) CPU E5-2667 v2 @ 3.30GHz
CPU cores : 2 @ 3299.998 MHz
AES-NI : ✔ Enabled
RAM : 1.9 GiB
Swap : 0.0 KiB
Disk : 29.0 GiB
Distro : Ubuntu 24.04.3 LTS
Kernel : 6.8.0-85-generic
VM Type : KVM
IPv4/IPv6 : ❌ Offline / ✔ Online
Read | 4.35 MB/s (1.0k) | 30.60 MB/s (478)
Write | 4.38 MB/s (1.0k) | 31.00 MB/s (484)
Total | 8.73 MB/s (2.1k) | 61.60 MB/s (962)
Read | 55.51 MB/s (108) | 69.86 MB/s (68)
Write | 58.43 MB/s (114) | 74.51 MB/s (72)
Total | 113.95 MB/s (222) | 144.38 MB/s (140)
Clouvider | London, UK (10G) | 5.99 Gbits/sec | 7.23 Gbits/sec | 9.27 ms
Eranium | Amsterdam, NL (100G) | 9.26 Gbits/sec | 9.26 Gbits/sec | 3.41 ms
Uztelecom | Tashkent, UZ (10G) | 2.32 Gbits/sec | 1.83 Gbits/sec | 96.1 ms
Leaseweb | Singapore, SG (10G) | 1.38 Gbits/sec | 1.37 Gbits/sec | 157 ms
Clouvider | Los Angeles, CA, US (10G) | 1.17 Gbits/sec | 841 Mbits/sec | 151 ms
Leaseweb | NYC, NY, US (10G) | 2.69 Gbits/sec | 3.05 Gbits/sec | 81.6 ms
Edgoo | Sao Paulo, BR (1G) | 976 Mbits/sec | 1.19 Gbits/sec | 186 ms
Geekbench releases can only be downloaded over IPv4. FTP the Geekbench files and run manually.
YABS completed in 5 min 37 sec
If you have any questions, don't be shy leave them below ^_^
$4 per month and couldn't throw in a IPv4? Sad...
Not low end.
@dosai said:
Added one more, so it's affordable for everyone
Check out the €13.00/yr ($15.16/yr)
2 cores 1 gb ram and 30 GB Disk and 35TB Bandwidth
Order here
Maybe that offer fits you
I offer $6/year
If that would be Africa or South America, sure.
But the Netherlands is full of cheap offers, cheaper then yours and they even include IPv4.
Did you limit it to 1k IOPS (for 4$) or you misconfigured something?
Its a feature
The server where we host those is equipped with a SATA SSD, but on our tests it performed fine even though the speed in FIO is kinda slow.
Price seems steep for a CPU from 2014
