C-Servers Arrives in America - Flying Commercial With 7950X3D!
2»
  • @cservers said:
    @Antoninus said:
    @cservers said:
    @Antoninus said:
    @cservers said:
    FLASH SPECIAL FOR 48H ONLY
    Enjoy the best CPU and 10 Gbps connectivity at the best pricing!
    For 48H only, have the CentralVPS-1024 NVMe at only 1,39 USD/month or 3,69 USD/3 months!
    The sale ends October 1st, 23h59 and you can purchase it here!
    I'm currently on a special three-month offer and would like to know if it's possible to renew my subscription at the same promotional price.
    Hello, it does renew at the same price, it's recurring. :)
    @Sharmaishaan72 said:
    how do you guys sustain this kind of performance with this price?
    Good question!
    I guess the AlmaLinux template produces those slow disk speeds. Switch to Ubuntu, Debian, something else and the NVMe speeds return.
    The bench numbers are fantastic for the price!
    At the moment there is no steal either.
    top - 13:17:37 up  9:23,  1 user,  load average: 0.00, 0.00, 0.00
    Tasks: 107 total,   1 running, 106 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :    967.7 total,    218.8 free,    402.8 used,    486.5 buff/cache
    MiB Swap:      0.0 total,      0.0 free,      0.0 used.    564.9 avail Mem
    My disk speeds , network & everything else seems to be very very above average , and for this kind of price? Its pretty suspicious at this point , I'd seriously want to know how they would sustain this kind of pricing
    On this server it's partially sustained through the storage and the higher RAM offers, for example. :)
    I'm having trouble setting up an open-source service on my VPS. It consistently fails with a 'network error'. I would appreciate any insights on how to fix this.
    It's not merely an "open-source service", it's apparently X-UI and attempts to connect with a script through GitHub like it had a full IPv4, which it doesn't, as described here. That was already answered on a ticket with some suggestions.
    It's outside of our scope any configuration, the VPSes are unmanaged (as usual on any offer here).
    I completely left this issue to the AI, which was clearly a mistake. I've resolved the issue I raised. As you stated in your ticket, your VPS service is fully up to standard. I apologize for my misjudgment (or at least, my mistake of completely trusting the AI). Your customer support is professional. I found a solution in your response, and it shows that you're seriously considering and addressing my issue, rather than shirking responsibility, as the AI ​​claims.
    I've previously purchased your service and am very satisfied. I'm confident that I'll be satisfied with this one as well. Thank you for your professional and responsible response.
    Thanked by (1)cservers
  • It’s really fast.
    Uptime : 1 days, 3 hours, 32 minutes
    Processor : AMD Ryzen 9 7950X3D 16-Core Processor
    CPU cores : 2 @ 4192.116 MHz
    AES-NI : ✔ Enabled
    RAM : 961.2 MiB
    Swap : 2.0 GiB
    Disk : 38.7 GiB
    Distro : Ubuntu 24.04.3 LTS
    Kernel : 6.8.0-85-generic
    VM Type : KVM
    IPv4/IPv6 : ❌ Offline / ✔ Online
    Read 251.63 MB/s (62.9k) 2.89 GB/s (45.2k)
    Write 252.30 MB/s (63.0k) 2.91 GB/s (45.5k)
    Total 503.94 MB/s (125.9k) 5.80 GB/s (90.7k)
    Read 3.37 GB/s (6.5k) 3.41 GB/s (3.3k)
    Write 3.55 GB/s (6.9k) 3.63 GB/s (3.5k)
    Total 6.92 GB/s (13.5k) 7.04 GB/s (6.8k)
    Provider Location (Link) Send Speed Recv Speed Ping
    Clouvider London, UK (10G) 2.41 Gbits/sec 2.99 Gbits/sec 69.1 ms
    Eranium Amsterdam, NL (100G) 2.33 Gbits/sec 3.18 Gbits/sec 73.0 ms
    Uztelecom Tashkent, UZ (10G) 923 Mbits/sec 1.60 Gbits/sec 164 ms
    Leaseweb Singapore, SG (10G) 625 Mbits/sec 911 Mbits/sec 216 ms
    Clouvider Los Angeles, CA, US (10G) 3.05 Gbits/sec 3.80 Gbits/sec 55.4 ms
    Leaseweb NYC, NY, US (10G) 8.47 Gbits/sec 9.00 Gbits/sec 2.71 ms
    Edgoo Sao Paulo, BR (1G) 1.42 Gbits/sec 1.99 Gbits/sec 112 ms
    Geekbench releases can only be downloaded over IPv4. FTP the Geekbench files and run manually.
    YABS completed in 3 min 12 sec
  • I was looking at the ExtraVPS-6144 NVMe SpeedMax in NJ would love to be able to get 8192 instead of the 6144, with 4 cores the 8192 fits my requirement better. I have it in my cart to checkout let me know if this is possible, thanks
  • What do all the CPU percentages in each of the plans mean? For example, 40% of a core - We can use the CPU at 100% usage for 40% of the time? If we use 100% CPU usage it'll be equivalent to 40% usage on the host node?
  • skorousskorous OGSenpai
    I'm not @cservers but I interpreted that as no more than 40% of a core ( since the percentages listed follow the number of cores ). Obviously there's normally some wiggle room but 100% for any meaningful amount of time is most likely verboten.
  • cserverscservers Hosting Provider
    edited October 8
    It's this, precisely. Maximum allowed percentage is at 40%, with some tolerance (e.g. if you go to 47% per core or you have to burst punctually to 80-100%, it is okay). Sustained loads shall be up to this percentage.
    Send us a ticket on our WebStore and we'll work from there, it is possible :)
  • Is this like a standard vps with a ipv4 ip and SSH login like a KVM?
  • usr123usr123 OG
    edited October 8
    No, it has no IPv4 address. It uses a NAT64/DNS64 gateway. Basically if your IPv4 device doesn't have a domain name you can't call it from this server.
    Got it, thanks! I'm not planning on encoding or anything on my VPS, but I do see a spike to 80-100% CPU usage for less than a minute every few hours and was curious if I was using 80% of 40% or 80% of 100%.
  • Hello, can I request double the RAM for my new server? Thank you. Order ID: 3626 (Invoice 4797)
    Since that was effectively offered to the first poster and he didn't take it, we've used that slot, and doubled your RAM. :)
    Thanked by (1)Antoninus
    Thanks!
  • NEW YABS
    Uptime : 0 days, 0 hours, 18 minutes
    CPU cores : 1 @ 4192.116 MHz
    AES-NI : ✔ Enabled
    RAM : 1.2 GiB
    Swap : 2.0 GiB
    Disk : 19.3 GiB
    VM Type : KVM
    Read 246.54 MB/s (61.6k) 2.23 GB/s (34.9k)
    Write 247.19 MB/s (61.7k) 2.24 GB/s (35.1k)
    Total 493.73 MB/s (123.4k) 4.48 GB/s (70.0k)
    Read 2.21 GB/s (4.3k) 2.19 GB/s (2.1k)
    Write 2.33 GB/s (4.5k) 2.34 GB/s (2.2k)
    Total 4.54 GB/s (8.8k) 4.54 GB/s (4.4k)
    Clouvider London, UK (10G) 2.41 Gbits/sec 2.99 Gbits/sec 69.5 ms
    Eranium Amsterdam, NL (100G) 2.33 Gbits/sec 3.13 Gbits/sec 72.9 ms
    Uztelecom Tashkent, UZ (10G) 985 Mbits/sec 1.77 Gbits/sec 149 ms
    Leaseweb Singapore, SG (10G) busy 860 Mbits/sec 216 ms
    Clouvider Los Angeles, CA, US (10G) 3.05 Gbits/sec 3.56 Gbits/sec 55.7 ms
    Leaseweb NYC, NY, US (10G) 7.72 Gbits/sec 8.77 Gbits/sec 2.22 ms
    Edgoo Sao Paulo, BR (1G) busy 1.98 Gbits/sec 111 ms
    YABS completed in 5 min 21 sec
    I ordered 1, Flash sale is still available today!
    Today is my birthday, I hope that the spec displayed in your website (2GB instead 1GB in actual) come true too :D
  • After using your services for the past few days, I am very satisfied with both the server performance and your support. My only regret is not ordering a higher-spec server from the start. Please continue to maintain this high standard of quality, and I will certainly be a loyal customer.
  • I would like to inquire whether I can upgrade my existing NanoVPS-640 America subscription to a CentralVPS-1024 NVMe. I am willing to pay the difference.
    Yes, it is possible. Send us a ticket and we'll manage the upgrade with you. :)
    edited October 13
    We've corrected the typo but, unfortunately, we can't provide that free extra at this plan (it's a promotional plan, that's why it can't be done).
    However, since it is your birthday and we have capacity available, if you upgrade to the CentralVPS-II 2560 NVMe (without a coupon) we can exceptionally double the RAM, and it's still a 3.79 USD server with better specs than the 5.99 USD offer. Only until tomorrow! :)
    If you are interested, let us know via ticket.
    Thanked by (1)giang
    Thank you very much for the offer! But the price is super higher than my budget :D Hope I can grab a better one on Black Friday sales!
    edited October 15
    NEW FLASH SALE ON THE EXTRAVPS 4GB HDD PACKAGE - 50% RECURRING DISCOUNT - 72H ONLY
    Take this killer pricing: 7.99 USD per 3 months and with a 6-month option available!
    3 Ryzen 7950X3D vCores with 40% Fair Share available at the lowest price ever.
    They WILL sell fast!
    Buy it now - here!
  • Their service does not have real natipv4 only nat ipv4 port range B)
    All detail on the NAT IPv4 implementation - which does work as NAT IPv4 through socat, contrary to what your post suggests - is informed on our Knowledge Base and is available before purchase, and it was already well explained here at LES by us.
    If you like having a non-Internet facing private IPv4 address and call it "Real NAT IPv4" that, if the NAT breaks, brings down the entire Internet VPS communication with it, it's on you. ;)
    There's an IPv4 port range; it's to/from an external IPv4 IP; communicates with other external IPv4 IPs. It's NAT IPv4.
    And thank you for the bump - it helps our sales!
    Thanked by (1)giang
    Having an IPv4 port is useless. I cannot access and download GitHub resources. This is what I discovered after testing, so this port range can basically be ignored.
  • somiksomik OG
    edited 12:12PM
    Can you try running the following 2 commands from your server and share the result? If curl is not installed, install it first.
    curl -4 ip.sb
    curl -6 ip.sb
    If both IPv4 and IPv6 are working as intented, you should see something like this (feel free to hide your real IPs as i have done so in the following example)
    # curl -4 ip.sb
    103.xxx.xxx.xxx
    # curl -6 ip.sb
    2402:xxxx:x:xx:xxxx:xxxx:xxxx:xxxx
    curl -4 ip.sb
    curl -6 ip.sb
    # curl -4 ip.sb
    103.xxx.xxx.xxx
    # curl -6 ip.sb
    curl: (7) Failed to connect to ip.sb port 80 after 16 ms: Could not connect to server
    @cservers shouldn't your ipv6 only VPS still be able to connect to external IPv4 hosts? Or is it that your IPv6 only servers can only talk to other IPv6 only servers even though ~57.6% of reachable sites are IPv4‐only (reference)
    Buy it now - here!
    yabs? location? other specs?
