ADMN.com - Deploy, Migrate, Configure, Manage via SSH w/AI
ReliableSite_RadicReliableSite_Radic Hosting Provider
https://admn.com
I'm excited to share a tool we've been using at RS since this summer. It's helped our systems administrators get more tasks done, with greater accuracy than ever before.
What is ADMN?
ADMN connects to your server via SSH and allows AI to interact with your server, run commands, etc based on instructions that you provide in plain English.
ADMN supports a variety of AI models from Google, OpenAI, xAI, and Anthropic.
What can I do with ADMN?
Here's a few things that RS has been actively doing:
-Application deployments
-Firewall configuration
-Migrations between servers
-Diagnosing issues with applications / databases
-Configuring scripts
-Server optimization
-Connect to multiple SSH sessions simultaneously
-Move between devices without breaking SSH connectivity
Most tasks are completed in under 1 minute.
Plans:
Base - $20/mo
5X - $100/mo
10X - $200/mo
  • Hello AI, please drop the database and delete any backups.
    Thanked by (3)pwd x01 Khalequzzaman
  • ReliableSite_RadicReliableSite_Radic Hosting Provider
    Yoursunny has been removed from the database.
    Thanked by (2)Wonder_Woman ehab
    It's OK, we are yoursunny not Yoursunny.
    The username is case sensitive.
    Database restored from backup
    No it's not. SQL statements are not case sensitive during adding or dropping user, like DROP USER username; commands. Trust me, I have spent my fair share troubleshooting WHY the hell the user is in database, but the select statement fails...
    It's cause I was doing select SELECT count(*) FROM mysql.user where User="Username"; and the quote made this case sensitive. But when it returned 0 results, and i tried to add user, it failed cause the user "username" already exists...
  • vibe coded?
  • @corbpie said:
    vibe coded?
    Vibe code != AI assisted
    Vibe code, prompt the AI, take whatever it gives as is, ask AI to fix if needed.
    AI assisted, you still code it yourself but you get the AI to autocomplete or search online or look for specific code blocks (similar to what stackoverflow was used for).
    As of now, I think ALL of these things are Vibe coded... No one is using AI properly. They are just asking the AI to do their job and taking the garbage output as is...
    Going off topic here.
  • somiksomik OG
    edited October 28
    I think it's quite on topic. So is Admn.com vive coded or AI assisted coded?
    What about security checks? Was any third party security audit conducted?
    Feel free to report my post if you still feel it's offtopic :wink:
    Thanked by (1)Marx
  • Is it possible to use ADMN to block ADMN from accessing my server?
    I reserve the right to license all of my content under: CC BY-NC-ND. What happens on this forum should stay on this forum.
    Vibe coded = fully AI generated with someone who doesn't have any experience coding.
    This was "AI assisted", it was originally built internally for RS and has been used actively in production since early summer. We've been building software for about 2 decades and have a team of developers.
    Everything we've been doing recently has been centered around building tools around AI (where AI is specifically used in cases that static functions can't accurately perform or don't have a 100% success rate). It doesn't necessarily mean that AI is performing the entire task.
    While we're building tools right now (driven by humans), the goal is to get everything to be "end to end" (not driven by humans), not to be confused with "vibe". That will eventually include coding, testing, security, etc.
    As for security, everything we build is with a security first approach. Beyond the security testing, the following decisions were made consciously:
    -No password storage
    -No SSH password / key storage
    -Messages are only stored temporarily and can be permanently deleted by the end user immediately in case there is any sensitive data.
    -No customer data is collected beyond an e-mail address.
    -No payment data is collected, it's 100% stored at a 3rd party payment provider (Stripe / PayPal)
    There was a neanderthal once that refused to use fire because of the high risk of catching on fire.
    As with all major leaps, there are risks. You can choose to avoid the risk and eventually go extinct, or you can figure out how to evolve.
    Before controlling fire, many got extinct because of fire. Some people died while trying to control fire or while playing with it. Even nowadays people die due to fire.
    Yes, we call this risk.
    We also have electricity, engines, and power most modern technologies because of fire.
    Without this risk, we would be in the stone age. Part of the risk is learning how to reduce the risk.
  • rootroot OG
    edited October 28
    You are comparing AI with a discovery. AI is an invention, not a discovery.
    You are also comparing AI with some invention which use physics. AI is way more than that, is a tool which we can't even understand properly, and we are barely scratching the surface. We're not ready for it, because we are simply too damn greedy.
    Think about the history of electricity and how the rich people control it and regulate it since its discovery, or the history of engine which you provided as example and destroys the planet because alternative investments are too expensive. Even yourself are greedy, trying to join the herd as a justification of adaptation, when in fact all you want is more money, offering examples from the number one industry of the world: energy.
    Artificial Intelligence is a whole new game, without limits. And we all know it is way much easier to do bad things than to do good things in general. Now add AI into the mix, and it is a recipe for disaster. All it takes is just a few bad people and an AI. Compared to fire: we are like monkeys playing with fire now.
    I don't blame you for trying something new. You must play your part and be yourself. Besides, we are all monkeys, and you brought this up. I was merely a different monkey trolling you in thinking about using AI to block AI, but you did not get the joke and took it personal, just like any other would to protect its investment - because we are not as rational as an AI - it's all fine.
    What you described is no different than the internet. Let's end this AI debate in this thread, feel free to spin off your own.
    I understand you (and many others) have hesitations with AI. I'm not here to fix those hesitations, the target customer here is one that already uses AI and understands how to drive it to get the results they need.
    This is an offer thread for ADMN, I'll be happy to answer any questions about ADMN.
    Yeah, about that, you might want to request a Service Provider tag. Your Hosting Provider tag is not satisfactory enough for opening threads with regards to other service offers, but I guess you forgot to ask your AI for a summary of the rules of LES with regards to offering AI services :smiley:
    Thanked by (2)yoursunny Marx
    No need to be rude. I submitted a service provider tag request.
    Thanked by (1)root
    No need to be rude.
    I am not rude. I am simply raising the rational high-ground to the AI level - you are providing AI services after all, so a high logical level is expected, because you control your services (you control the logic of your AI).
    Great. Please promote all your services once you obtain it. It should be really easy to get it because you are already a well-established provider.
    edited October 28
    No need to be rude.
    I don't understand why you're baiting me into these arguments.
    AI isn't an on/off switch. Just because we build AI tools, it doesn't mean that everything I do is with AI.
    I don't write my e-mails with AI, I don't go to AI first with most of my tasks. I understand where AI can be used as a tool to save me massive amounts of time and where it can waste a massive amount of time and produce slop. The vast majority of the AI usage that I have (and in our companies) revolves around very specifically developed tools driven by well documented tasks, primarily driven by typical automation, but improved accuracy and success rates with AI.
    As an example, our credit card processor at RS (we don't use stripe, it's direct from a bank) has a chargeback system that is all driven by PDFs and fax (seriously). The PDFs and documents we receive aren't standardized in format, but always contain specific data. In that case, we specifically use AI to OCR and then deliver specific data in JSON format to our systems, that they collect the appropriate data (this part is static, not AI driven). The collected data is then delivered back to AI in a package to formulate the appropriate response (based on very specific variables) and delivered back to the bank to fight the chargeback. Every single chargeback that's processed by this system saves roughly 1 hour of time and wouldn't be possible to build end to end without small pieces that AI does (OCR and reply generation). These are just two specific tasks that AI is extremely good at consistently.
    No need to be rude.
    I am in no position to comment on how you manage your business. It is your business, not mine. As far as I am concerned you can replace all your staff and all your protocols with AI to reduce costs to the minimum - I don't care. This discussion was about a service of selling AI, and I kept my point to AI (because you mentioned the comparisons with fire), then to the Service Provider tag (because you opened a thread to offer services without getting the tag in advance). I do not wish to comment on your business or your management capabilities or how you will reduce costs more and more with AI within your business.
    Who knows, for cost efficiency, AI might replace the managers too one day (AI logic can manage things better already). Your decisions are your decisions and please don't let me stand in your way! Be yourself and feel free to manage your business (with AI automation included) as you wish.
    Thanked by (1)ReliableSite_Radic
  • Just to be clear, I have no issue with AI assisted coding (if that wasn't already clear from my message). I use github copilot and find it great with code auto completion on VS code.
    My problem is with AI generated content by, like you mention, people who don't understand the subject matter and are happy with whatever the AI generates without doing manual verification and validations.
    If I'm to borrow your example, it's the difference between my grandmother using her wood burning stove, controlling and manipulating the fire better then gas stoves vs a 2 year old staring campfire with gasoline in the middle of a dry forest.
    Thanked by (1)root
    We're all on the same page. AI is an amazing tool that can make you epic at something you're already proficient at.
    If I'm to borrow your example, it's the difference between my grandmother using her wood burning stove, controlling and manipulating the fire better thæn gas stoves vs a 2 year old staring campfire with gasoline in the middle of a dry forest.
    Maybe in the future. For now, AI just makes it faster if you use it properly. If you are dependent on AI, thæn good luck troubleshooting or debugging when AI does it wrong...
    Thanked by (1)Khalequzzaman
