@tonyapac said:
Node ATLZ033, what happened? It has been offline for a couple of weeks. @VirMach
He doesn't care my friend~
🤡 "We can confirm that this is not an issue with any servers, network, or power equipment on our end." 🤡 "We have temporarily paused controls for this service as we are performing maintenance on the server." 🤡 "The servers are working, they are just not connected to the internet!" 🤡
@msatt said:
7 VMs cancelled so far and will continue reducing. @bakageta I admire your stamina, but once you perfect a strategy for a downed VM, then what is the point of purchasing more VMs that will go down.
In the past, the VMs were at least useable for non-production stuff. They're less useful for that now, but out of my 5 virmach VPSs, all 5 are up, 2 with recently-spotty internet. It's not like "my vm has been down for months!" is the average, it just doesn't phase me if that happens to one. It helps that I'm not trying to run a static set of things, I'm spinning up something to test, getting satisfied with the implementation and fallback, implementing it elsewhere, and blowing them up, leaving the VPSs idle a lot. I don't need as many as I have, but the cheap price makes it easy enough to have enough idle to always have something usable for my needs.
The automation around dealing with issues is far from a "perfect strategy and done" kind of thing, though. It's not like you just set it up once and forget about it, everything works perfect with no adjustments. If that were the case, I'd be out of a job. If you care about more than manually intervening when there's a problem, you have to do the maintenance on your automation, otherwise you'll find none of it works when you actually need it.
@bakageta said: If that were the case, I'd be out of a job.
This is one of my lower-end Digital Ocean boxes-
$ w
17:33:47 up 951 days, 39 min, 1 user, load average: 0.28, 0.25, 0.27
KPatched, up to date, decent hosting, services restarted when necessary.
But still, my Virmach-
$ w
12:34:08 up 227 days, 8:36, 1 user, load average: 0.12, 0.09, 0.14
When it works (and you don't need intervention), it's great. When SHTF, you get to keep the fan, and whatever you can lick off of the blades.
I've stopped buying cheap-for-cheap-sake stuff, but I'll probably hold onto my remaining Virmach until they just stop working. I mean, I'm barely paying for the IP space rental.
I got rid of all virmach systems but one free one that been up over 700 days. 700 days ago was around the end of all the major migrations that were going on. I think it is is in or around EWR now, but I stopped trying to keep track after about the third address change.
Easter? I kept that one as long as I could, but for some reason it decided that it was being abusive despite only running thttpd to serve the single OpenBSD conf file for the kernel. It kept getting suspended weekly, even after I literally nuked the bootsector.
I have 13 vps with vir, 1 of them is up but pretty much unusable (LA node), some are okay, some are somewhat perfecto. I'll keep most of them i think.
nb: I use DO for important sites
This is one of my VPS that is hosting shopping website. Running fine without issues although occasionally I will receive notification from Hetrix Tools that it is down for a minute or two.
What if Vir is a sadomasochist and he enjoys this?
What if Vir was abducted by aliases?
What if Vir is being held captive in the yeti's basement?
What if Vir was abducted by aliases, is being held captive in Yeti's basement, and is enjoying it?
Here is another one which remains idle.
LA?
I think that location has been flapping like crazy for quite sometime now.
LA?
he's not gone, he'll do the usual, fly around, fix some servers, do some migrations, credit for downtime, get people happy again... sell a shitton of deals. etc...
I have been waiting since AUG 2025~ almost 3 months now..
migrations only work for a while until the next down time. hardware need to be fixed
preparing for 2025
@VirMach BF is coming, https://virmach.com/black-friday-cyber-monday/
Virmach Deals
domain expired
Dataplane.org's current server hosting provider list
I'ma still keep some of my Virmach VPS.
My couple of VPSes are online.
Is my dedi online? Maybe, but I don't have IPs 😭
Virmaaaaaaaaaaaaaaaaaaaaaaaaaach
Powerful AMD Ryzen VPS (aff)
What if Virmach is the new provider for OpenAI?
OpenAI will die very quickly.
Feel free to put 'N/A'
LA?
https://vps.blackfriday/ is back online
Virmach Deals
Switching soon.
Soon.
Both NY
yawwwn no active dealz there
MIAZ014?
4 more days for monthly anniversary
The guy is gone~
