What do you use to manage & update multiple servers?
So I have a few servers on ubuntu and debian that I need to ssh into and run the following commands:
sudo apt update
sudo apt upgrade -y
sudo reboot
Previously I created a shell script that I ran from my linux box to ssh into the servers one by one and update them. I also configured the servers sudoers file to allow to run the above 3 commands for my user without password.
So I am wondering if there is a better way to do this.
Current ideas:
1. Continue to use shell scripts
2. Setup unattended-upgrades and run all updates through that
3. Use ansible from a control node
4. Give root access to chatgpt to run updates for me
5. Maybe a mixture of options 1 to 3?
Would love to hear how you are handling the updates and what you recommend is the best way.
