What do you use to manage & update multiple servers?
So I have a few servers on ubuntu and debian that I need to ssh into and run the following commands:
sudo apt update
sudo apt upgrade -y
sudo reboot
Previously I created a shell script that I ran from my linux box to ssh into the servers one by one and update them. I also configured the servers sudoers file to allow to run the above 3 commands for my user without password.
So I am wondering if there is a better way to do this.
Current ideas:
1. Continue to use shell scripts
2. Setup unattended-upgrades and run all updates through that
3. Use ansible from a control node
4. Give root access to chatgpt to run updates for me
5. Maybe a mixture of options 1 to 3?
Would love to hear how you are handling the updates and what you recommend is the best way.
So we have a total of 18.4 quintillion blocks of 18.4 quintillion IPv6 IPs?!?
«13
    Unattended upgrades and kernel patching with notifications.
    Unattended upgrades, sure.
    How to do kernel patching with notifications?
    I see I need to write a blog post on it
    Thanked by (1)wankel
  • SharedGridSharedGrid Hosting Provider
    The professionals setup n8n to run updates for them.
    For Ubuntu we use unattended upgrades for security updates. Anything else is done via Ansible.
  • edited November 4
    NixOS.
    Discovered it in 2021 and never looked back.
    Now, We manage over 20 VPS, some with a provider, some self hosted.
    Thanked by (1)x01
  • Ansible for this and many other tasks.
    Thanked by (1)sh97
  • I use this: https://jimradford.github.io/superputty/
    While its not automated, it allows you to issue a command to multiple server at once. Currently have 12 server setup in the manager. Saves time over having to putty to each server individually..
  • Hmm, for some reason, I feel like I should try to do this with Ansible. Not sure why I feel that way. Just a gut feeling I guess... :lol:
    @sh97 said:
    Try Ansible - I think that is the way.
    Surprised no one mentioned using Ansible...
    1. CTRL+ALT+T opens the terminal.
    2. Type ssh vps0 to connect to server.
    3. Type sudo apt update && sudo apt full-upgrade -y && sudo reboot to run the upgrade, and copy this command to clipboard.
    4. CTRL+SHIFT+T opens a new tab.
    5. Type ssh vps1 to connect to server.
    6. Paste the copied command.
    7. Repeat steps 4~6 for the remaining 28 servers.
    8. If SSH says hostname not found, it means the hostname is available for the next $6/year dealz.
    Thanked by (2)themew root
    If that's how you want to do it, you can do it much easily using a shell script (like i used to)...
    Thanked by (1)jaden
    Did anyone mention Ansible?
    Thanked by (1)jaden
  • Xpanes with an alias in my .zshrc to all the VM's IP's. Then I drop the yay bomb.
    Thanked by (1)ehab
  • @thagoat said:
    Xpanes with an alias in my .zshrc to all the VM's IP's. thæn I drop the yay bomb.
    zshrc = mac?
    I see they have it for debian/ubuntu and centos as well... But i dont really use linux as a daily driver anymore. Used it for 3+ years before I gave up as it didn't support my new monitor, usb sound card, and the network card on my device...
  • I use Ansible and Puppet: Ansible to run commands on all the hosts in my inventory, Puppet to get each host to a certain state depending on what the host is supposed to do.
    Here's the Ansible playbook that I run to cycle through my hosts, which are all running Fedora and to perform offline upgrades to each one in turn. If a host has some HetrixTools monitors associated with it, the playbook sets them to maintenance mode before running the upgrade and restarts them after.
    - name: "offline-upgrade"
      hosts: all
      user: operator
      become: true
      serial: 1
      tasks:
        - name: Pause Uptime Monitors
          uri:
            url: "https://api.hetrixtools.com/v2/{{ hetrixtools_api_token }}/maintenance/{{ item }}/3/"
          with_items: "{{ hostvars[inventory_hostname]['hetrixtools_monitors'] }}"
          delegate_to: "127.0.0.1"
        - name: Download Upgrades
          shell:
            cmd: dnf5 upgrade -y --refresh --offline
          register: dnf_download
        - name: Pause Before Reboot
          pause:
            seconds: 30
        - name: Rebooting Host
          shell:
            cmd: sleep 5 && dnf5 -y offline reboot
          async: 1
          poll: 0
          ignore_errors: yes
        - name: Host Is Installing Upgrades
          pause:
            seconds: "{{ wait_after_reboot_secs }}"
        - name: Waiting For Host Reboot
          wait_for_connection:
          args:
            delay: 15
            timeout: 300
        - name: Execute Puppet
          shell:
            cmd: /usr/local/sbin/puppet
        - name: Restart Uptime Monitors
          uri:
            url: "https://api.hetrixtools.com/v2/{{ hetrixtools_api_token }}/maintenance/{{ item }}/1/"
    Thank you for the ansible playbook! Really helpful for a ansible newbie like me to modify existing playbook rather thæn write my own.
  • Outside ansible, another option is to use a terminal multiplexer like Terminator to type commands in many windows at once
    If you do go with ansible, I'd propose the way we do it at work:
    • Store ansible playbook in git repository
    • git commit + push any change you actually deploy
    • Run ansible from your laptop
  • telegram bot
    my server pick up a command & run it every 1 min (if exist)
    Thanked by (2)quicksilver03 wankel
    @netrix said:
    telegram bot
    That is kind of a novel way to do it.
  • Shameless Nix plug here.
    You don't need to switch distros to get the benefit of nix.
    Why did you do it man? Wy did you have to do it?
  • edited November 5
    why not? Nix is great but lacking marketing resources like Ansible!!
  • What is Nix?
    @localhost said:
    What is Nix?
    SSSSSSHHHHHH man you will awaken the weirdos!!!
    Thanked by (2)localhost wankel
    @localhost said:
    What is Nix?
    Why you think I posted this ?
    Its too quiet here
    @localhost said:
    @localhost said:
    What is Nix?
    Its too quiet here
    You don't want that kind of weirdness believe me man.
  • @netrix said:
    telegram bot
    do you run a bot per server?
    I tried something similar, but multiple instances of the same bot were no bueno
    Maybe you can give some context, would love to know where i went wrong
