How do you set up your terminal?
2»
    CSS mark up for an editor. Let me guess, you have to run it in node from a docker image?
  • edited November 2025
    Since Not_Oles is forever young and modern, I can act as old and boring :D My terminals are pretty much standard bash with just a few simple modifications in .bashrc:
    PS1='[\e[01;32m]\u@\h[\e[0m:\e[01;33m]\w\$>[\e[0m] '
    alias sr='screen -D -r'
    alias v='ls -al'
    alias vd='ls -al -r -t'
    alias vm='ls -al | more'
    alias vs='ls -al -r -S'
    alias dus='du -d 1 | sort -n'
    alias free='freecolor -mt'`
    When it comes colors, it has always been black background, white/silver font and colors enabled. I used to be SecureCRT user for 20 years but recently I have been using tabby.sh as my primary terminal program. Everything works out of the box and no reason to tweak things. I use tabs instead of keeping them all visible on screen and with this little addition to .bashrc the tab in tabby.sh keeps updating accordingly wherever I have ssh'ed into.
    ORIG=$PS1
    TITLE="\e]2;Not_Oles Hosting LLC server #1\a"
    PS1=${ORIG}${TITLE}
    Once the box is open I typically keep gnu screen running with certain tail -f's of commonly checked log files and stuff.
    That pretty much sums it all up!
    All my work is done on a chromebook (developer mode). ssh works great and if I need graphics, spice or VNC works perfectly. Majority of my work is cli based so as long as I have ssh and a browser it is job done. Been using this method for at least 10+ years.
    I have not found anything I can't handle (yet)....
    ssh terminal is 'hazy' - deep purple with light text. Works well in day or night light.
    So I suppose I would say the classic 'thin' client approach.
  • @Not_Oles
    nothing fancy, i am old school, i use https://gnome-terminator.org/
    plenty of shell scripts to help reduce commands.
    @ehab Eeeks! Your screenshot seems almost familiar! :star: Thank you!
    Thanked by (1)ehab
    @msatt said: if I need graphics, spice or VNC works perfectly
    Hi @msatt! I am curious what you are using for Spice and VNC clients.
    There was a Chrome Spice extension that I used a few times on my Chromebook, but this extension got taken out with the departure of Manifest v2.
    For VNC I used to use a RealVNC Chrome extension, but, IIRC, RealVNC stopped development in favor of their Android extension. I tried Remmina a few times. It seems to work well, but recently I have been getting notices about Remmina wanting some kind of key:
    chronos@penguin:~/servers/linveo$ remmina
    ** Message: 13:25:18.028: Remmina does not log all output statements. Turn on more verbose output by using "G_MESSAGES_DEBUG=all" as an environment variable.
    More info available on the Remmina wiki at:
    https://gitlab.com/Remmina/Remmina/-/wikis/Usage/Remmina-debugging
    Load modules from /usr/lib/aarch64-linux-gnu/remmina/plugins
    Remmina plugin glibsecret (type=Secret) has been registered, but is not yet initialized/activated. The initialization order is 2000.
    Pop-up says: Authentication required. An application wants access to the keyring "Default keyring", but it is locked.
    Remmina seems to work without giving it any password, although the pop-up appears 3 times. I have been too lazy to check into what is happening. :) Maybe you know what this is? And, if you do not mind, what do you use for Spice and VNC on your Chromebook?
    @Not_Oles Yes, I am using Realvnc and for spice, I just download the credentials and run virt-viewer in the chromebook cli.
    I needed to do some video editing so used a cloud VM. Vnc does not support remote audio so I used spice which worked very well. No point (in my opinion) having a powerful laptop if you have more powerful cloud VMs.
  • vyasvyas OGSenpai
    Nice discussion on terminals and modifications, etc..
    I used to have more "detailed" terminals before, neofetch, transparency, split terminals...
    Now ? Less is more. Similar to images posted by @Not_Oles and @ehab but if you are still curious- click below
    Thanked by (2)Not_Oles ehab
    Thanked by (1)vyas
  • vyasvyas OGSenpai
    Saw this one on X.. couldn't help posting. I suppose it does not meet the "intent" of the thread.. but..
    Full Video at : https://www.youtube.com/watch?v=-DiK5FDpBTg
    Thanked by (2)Not_Oles Crab
