Singapore High Monthly Transfer VPS under 10$
VPS For VPN usage.Not for illegal usage.We just use for social media.In Myanmar current state, we need vpn for social media.My requirement is Singapore Region VPS which has high transfer traffic over 10Tb prefer.Cpu Ram Storage doesn't matter. 1vcpu 1gb ram 10gb storage is enough.
More prefer support cheap floating ip provider or additional ip with cheap price.Because sometime, our isp block vps ip.
  • Check out hostdzire's offer in lowendtalk.
    Thanked by (1)austinbrady
  • Btw, which VPN are you planning to use? Just curious on how you are going to setup a VPN.
    3xui panel ( v2ray based vpn panel). It can use vpn that support v2ray.
  • edited November 2025
    I host my site on a toaster with IPv6.
    🎵 Try my free YouTube to WAV Converter — fast, secure, and easy to use.
  • DazzleDazzle OG
    What?
  • @Dazzle said:
    @arham321 said:
    Hi austinbradyaustinbrady
    Good question — I’ve been working with a Flask‑based project that converts YouTube videos to WAV audio files, so I’m also looking at VPS with high monthly transfer and good region routing (Asia / Singapore).
    One thing I found useful: when I expect a lot of data throughput, check the actual upstream bandwidth and see what kind of “burst” traffic is allowed. Some Singapore providers charge extra above a certain “fair use” limit even if they advertise “high transfer”.
    Also, ask specifically:
    Is the VPS IPv4 only or does it include IPv6?
    What are the routing/latency benchmarks from your location to Singapore?
    Extra IP addresses cost? Because you mentioned needing floating IPs or additional IPs.
    I’d appreciate any recommendations others have had in the Singapore region that deliver real high‑transfer at under US$10/month.
    — Arham
    What?
    Nothing to see here, just a 100% AI generated response...
