"There is no cloud, it's just someone else's computer."
Today, as I was performing my usual server maintenance, I ran ls and found two script files I didn't recognize. My first reaction was a server intrusion, but after checking the script contents, I thought it might be a joke from the hosting provider.
Neither of the two scripts had any malicious function. Script 'a' was responsible for installing qemu-guest-agent, and script 'b' was responsible for running script 'a' and then deleting both scripts 'a' and 'b'. However, they did not execute successfully.
My VPS's system in the control panel is listed as Debian, but it is actually running Arch Linux. I suspect that the hosting provider distributes installation scripts based on the system shown in the control panel. Since I didn't have apt installed on Arch, the script encountered an execution error and exited directly, which is why the two scripts were preserved.
#!/bin/bash
echo `date`: Recipe ID: -524;
sh /root/recipe_-524.sh > /root/recipe_-524.log 2>&1;
echo `date`: RET: $?;
rm -f /root/recipe_-524.sh;
rm -f /root/exec_recipe.sh
if [ -f /etc/debian_version ]; then
        OS=Ubuntu
elif [ -f /etc/redhat-release ]; then
        OS=redhat
elif [-f /etc/oracle-release ]; then
        OS=redhat
fi
if [ "$OS" = redhat  ] ; then
        systemctl status qemu-guest-agent
        if [ $? != 0 ] ; then
                yum  --skip-broken -y install qemu-guest-agent
        fi
elif [ "$OS" = Ubuntu  ] ; then
                apt-get clean -y 2>&1
                apt-get update -y 2>&1
                apt-get install -y qemu-guest-agent 2>&1
        fi
fi
systemctl enable qemu-guest-agent
                # Get the version of qemu-ga
                REL=$(qemu-ga -V | grep -oP "\d+\.\d+\.\d+")
                #path
                config=/etc/sysconfig/qemu-ga
                # Check if the version is 8.0.0 or higher
                if [[ "$REL" =~ ^(8|\d{2,})\.[0-9]+\.[0-9]+$ ]]; then
                        #taking backup of old file for safer side
                        cp /etc/sysconfig/qemu-ga /etc/sysconfig/qemu-ga.bk
                        #injecting the guest-exec and guest-exec-status command for enabling
                        sed -i '/^FILTER_RPC_ARGS="--allow-rpcs=/ s/"$/,guest-exec,guest-file-open,guest-file-read,guest-file-close,guest-exec-status"/' $config
                else
                        sed -c -i "s/\(BLACKLIST_RPC *= *\).*/\1guest\-file\-seek/" $config
                fi
        fi
REL=$(cat /etc/redhat-release)
rhel9="$(echo $REL | egrep -i '(release 9)')"
echo $rhel9
if [ "$?" -eq "0" ]; then
        sed -c -i "s/\(BLOCK_RPCS *= *\).*/\1guest\-file\-seek/" $config
fi
systemctl unmask qemu-guest-agent
systemctl restart qemu-guest-agent
  • Okay
    (Was there a question?)
  • @angstrom said:
    Okay
    The title is not a question, it is a statement, because it ends with a dot.
  • @root said:
    @angstrom said:
    Okay
    This is true. But the relevance of the statement to the body of the post is not entirely clear, nor is the purpose of the thread.
  • @tetech said:
    @root said:
    @angstrom said:
    Okay
    We might need an AI translation, because MJJ language is quite difficult to understand due to so many variations in interpretation.
    Perplexity seems to offer a simple point of view. Hopefully I did not break some Cloudflare bot with my request.
    The phrase "There is no cloud, it's just someone else's computer" highlights that cloud services rely on physical servers owned by others. In your case, while maintaining your VPS, you discovered two unfamiliar scripts which initially seemed like a security breach. After inspection, the scripts weren't harmful; one intended to install qemu-guest-agent and the other to run this installation then remove both scripts. However, they failed to run because your VPS actually operates on Arch Linux, despite being labeled as Debian in the control panel. The hosting provider likely pushes installation scripts based on the control panel's OS info, causing the apt-based script to fail on Arch, leaving the scripts intact without execution. This illustrates how cloud systems can sometimes have discrepancies due to provider configurations and assumptions about the environment.
  • You are pushing the frontier of AI capability.
    WTF? I am leaving for the big boys. This is above my pay grade.
  • teamaccteamacc OGSenpai
    Thanked by (2)bmoto Alyx
  • While looking through my drawers, I found some loose coins.
    Not sure why you need to know that, but I felt that I should share with you, just as you have with us. :lol:
    Thanked by (1)bmoto
    Preserve it. It will be a relic pretty soon. /s
  • AI doesn’t always have a question
  • #dicks
    Thanked by (1)skorous
