What do you use to manage & update multiple servers?
13
  • bingobangobongobingobangobongo Hosting Provider
    @IAmNix said:
    Fought with ansible for a while. It wants python module called "six" to be installed on ALL of my remote nodes/vms...
    Anyone know what I am doing wrong?
    This smells like mismatched ansible version to me. Ubuntu repos especially are very behind - maybe try finding a PPA to install ansible from. Or maybe install it from pip.
    Yep definitely something between versions here… I actually don’t install anything on nodes and have a Debian prep script that runs everything needed, so any blank/base install just werks.
    Will sanitize and post here shortly!
  • Currently have my laptop and phone (juice ssh) with keys to most vms
    Realized it hard way a few days ago... if I wanted to transfer files from one vm to another it is next to impossible as all are key based auth and none have keys to login to other
    Curious what is the way to go about...
    Have a decent bunch of idlers so having n idlers keys on m machines seems too much?
    Maybe have a secondary layer of auth/keys for stuff between nodes? Then as part of setup, deploy the key used for inter node work?
    Or Ansible, since noone has mentioned it yet…
    Thanked by (1)localhost
    Yeah.
    Secondary keys is needed. But wanna keep overhead of number of keys limited.
    How to securely set same key on all nodes?
    I started tinkering with ansible and got my laptop and phone keys added to authorized keys. So there's that. But actual private key sharing over the wire seems trippy?
    Thanked by (1)bingobangobongo
    python3 -m HTTPServer
    Thats one way I was thinking too.
    Curious if having one key across all makes sense or to do the painful way for x keys on y servers
  • @localhost said: Curious if having one key across all makes sense or to do the painful way for x keys on y servers
    2 keys total, one main one and a backup. If you are the only admin there is no sense making it difficult to manage or prone to human error.
    No, it's never a good thing to share ssh keys.
    I usually go with 3 ways.
    If I want to automate file transfers, I usually create a low level user on the remote server and setup a ssh key between the 2 servers (like from my main server to my backup server).
    If I only need to transfer a lot of files, I use SCP to download it to my desktop and reupload it back.
    If it's just 1 or 2 files, I use: https://github.com/somik123/python3_http_upload_progress
    I installed it from ubuntu's repo, when that didn't work, I reinstalled it from python3 pip, but that didn't help either. I guess it's time to either try a proper PPA or install centos 8 and try from there. Thanks for the recommendations!
    Thanks! Looking forward to it!
    Interesting
    Well file transfer is definitely not automated.
    And its not just transfer. I may need to quickly ssh into another box right from there... I know I can connect organically from my laptop. But since inam already on server 1 so if I need to check something in server 2 it should be easy, right?
    Thanks for the quick http file server. Will bookmark it
  • I've not been following this fully, but a few quick hints:
    1. Assume that your SSH connections are white listed (i.e. A->B, A->C and B<->C is allowed)
    2. You have an ssh key for logins to connect from A->B and A->C
    3. You want to transfer some file(s) from B->C
    4. Use ssh-agent forwarding to provide access to your key ("resident" on A) to B (or C) thereby allowing B->C (or C->B) connections via this agent.
    5. Since B->C (or vice-versa) is possible via agent forwarding, you can now directly rsync/scp files from B->C (or vice-versa).
    6. man ssh-agent and ssh-add for options/security etc. RTFM.
    Profit?
    Thanked by (2)localhost wankel
    Profit?
    I think ssh-agent forwarding may work. Thanks
    Profit?
    ssh bastion host?
    Profit?
    ssh bastion host?
    That too...
    Any recommendations?
  • @localhost said:
    ssh bastion host?
    That too...
    DIY solution without any software bloats or extra security risks?
    https://smallstep.com/blog/diy-ssh-bastion-host/
    Or you can go with one of the more popular software solutions:
    https://goteleport.com/blog/ssh-bastion-host/
    Or go with a proper zero trust network with bastionXP:
    https://www.bastionxp.com/docs/guide/
    Thanked by (2)localhost IAmNix
    The ssh agent forwarding option is -A.
    So the commands would look like this:
    user@laptop:~$ ssh -A server-1
    user@server-1:~$ scp my-files/ server-2:
    Only do this if you trust server-1. It essentially shares access to all ssh keys on your laptop. As the man ssh says:
    Agent forwarding should be enabled with caution. Users with the ability to bypass file permissions on the remote host (for the agent's Unix-domain socket) can access the local agent through the forwarded connection. An attacker cannot obtain key material from the agent, however they can perform operations on the keys that enable them to authenticate using the identities loaded into the agent. A safer alternative may be to use a jump host (see -J).
    Finally posting my Ansible template for Debian setup... Sorry for the delay!
    Codie mc Coderson
    - name: Initial Debian Server Setup
      hosts: all
      gather_facts: no
      # Prompt for credentials at the very start.
      vars:
        # Automatically read the public key from the control node's /.ssh/id_ecdsa.pub
        authorized_pub_key: "{{ lookup('file', lookup('env', 'HOME') + '/.ssh/id_ecdsa.pub') }}"
      vars_prompt:
        - name: "username"
          prompt: "Enter the username to create"
          private: no
        - name: "password"
          prompt: "Enter the password for the new user"
          private: yes
          confirm: yes
      pre_tasks:
        - name: Install Python (required for all other Ansible modules)
          raw: |
            if ! command -v python3 &> /dev/null; then
              apt update && apt install -y python3
            fi
          become: yes
          changed_when: false
        - name: Update apt cache
          apt:
            update_cache: yes
        - name: Upgrade all installed packages (dist-upgrade)
          apt:
            upgrade: dist
        - name: Check if sudo is installed
          command: which sudo
          register: sudo_check
          ignore_errors: yes
        - name: Install sudo if not present
          apt:
            state: present
            update_cache: yes
          when: sudo_check.rc != 0
        - name: Install community.general collection
          ansible.builtin.command: ansible-galaxy collection install community.general
          delegate_to: localhost
          run_once: true
          changed_when: false
        - name: Gather facts now that everything is set up
          setup:
      tasks:
        - block:
            - name: Install generally required packages
              apt:
                name:
                  - curl
                  - zip
                  - unzip
                  - git
                  - smartmontools
                  - nvme-cli
                  - htop
                  - iperf3
                  - dnsutils
                  - net-tools
                  - whois
                state: present
                update_cache: yes
            - name: Hash the password using mkpasswd
              command: "mkpasswd --method=SHA-512 {{ password | quote }}"
              register: hashed_password
              no_log: true
            - name: Create the user with a hashed password
              user:
                name: "{{ username }}"
                password: "{{ hashed_password.stdout }}"
                shell: /bin/bash
                state: present
                groups: sudo
                append: yes
                createhome: yes
              become: yes
            - name: Pause for 3 seconds to ensure user is registered
              pause:
                seconds: 3
            - name: Ensure the user's home directory exists and set ownership
              file:
                path: "/home/{{ username }}"
                state: directory
                owner: "{{ username }}"
                group: "{{ username }}"
                mode: '0755'
            - name: Ensure .ssh directory exists with correct permissions
              file:
                path: "/home/{{ username }}/.ssh"
                state: directory
                mode: '0700'
            - name: Add authorized SSH key for the new user
              authorized_key:
                user: "{{ username }}"
                key: "{{ authorized_pub_key }}"
                state: present
                path: "/home/{{ username }}/.ssh/authorized_keys"
            - name: Set correct permissions on the authorized_keys file
              file:
                mode: '0600'
            - name: Allow the user passwordless sudo in sudoers.d
              copy:
                dest: "/etc/sudoers.d/{{ username }}"
                content: "{{ username }} ALL=(ALL) NOPASSWD: ALL\n"
                mode: '0440'
            - name: Remove all files in sshd_config.d directory
              command: find /etc/ssh/sshd_config.d/ -type f -delete
              changed_when: true
            - name: Configure SSH to disable password authentication for sudo/admin users
              copy:
                dest: /etc/ssh/sshd_config.d/10-disable_password_for_admins.conf
                content: |
                  Match Group sudo,admin
                      PasswordAuthentication no
                mode: '0644'
              notify: restart ssh
            - name: Ensure PermitRootLogin is set to prohibit-password in sshd_config
              lineinfile:
                path: /etc/ssh/sshd_config
                regexp: '^#?PermitRootLogin\s+.*$'
                line: 'PermitRootLogin prohibit-password'
                state: present
                backup: yes
              notify: restart ssh
            - name: Install fail2ban package
              apt:
                state: present
                update_cache: yes
            - name: Configure fail2ban with custom settings and SSH protection
              copy:
                dest: /etc/fail2ban/jail.d/custom.conf
                content: |
                  [DEFAULT]
                  ignoreip = 127.0.0.1
                  bantime = 1h
                  findtime = 10m
                  maxretry = 3
                  banaction = ufw
                  [sshd]
                  enabled = true
                  port    = ssh
                  filter  = sshd
                  logpath = /var/log/auth.log
                mode: '0644'
              notify: restart fail2ban
            - name: Install ufw package
              apt:
                state: present
                update_cache: yes
            - name: Allow SSH through UFW
              community.general.ufw:
                rule: allow
              notify: restart ufw
            - name: Deny RPC through UFW
                rule: deny
                port: '111'
              notify: restart ufw
            - name: Enable UFW on startup
                state: enabled
              notify: restart ufw
          rescue:
            - debug:
                msg: "An error occurred during provisioning. Please check the logs above."
            - fail:
                msg: "Provisioning failed."
        - debug:
            msg: "Provisioning complete. All tasks executed successfully."
        - name: Flush all pending handlers
          meta: flush_handlers
        - name: Prompt for reboot confirmation
          pause:
            prompt: "Server setup is complete. Do you want to reboot the server now? (y/n)"
          register: reboot_response
        - name: Reboot the server
          reboot:
            reboot_timeout: 300
          when: reboot_response.user_input | lower in ['y', 'yes']
        - name: Display message if reboot was skipped
          debug:
            msg: "Reboot skipped. You may want to reboot manually later to ensure all changes take effect."
          when: reboot_response.user_input | lower not in ['y', 'yes']
      handlers:
        - name: restart ssh
          service:
            state: restarted
        - name: restart fail2ban
          service:
            state: restarted
        - name: restart ufw
          service:
            state: restarted
    Codie mc Coderson
      hosts: all
      gather_facts: no
      vars:
      vars_prompt:
        - name: "username"
          private: no
        - name: "password"
          private: yes
          confirm: yes
      pre_tasks:
          raw: |
            if ! command -v python3 &> /dev/null; thæn
            fi
          become: yes
          changed_when: false
          apt:
            update_cache: yes
          apt:
            upgrade: dist
          command: which sudo
          ignore_errors: yes
          apt:
            state: present
            update_cache: yes
          run_once: true
          changed_when: false
          setup:
      tasks:
        - block:
              apt:
                name:
                  - curl
                  - zip
                  - unzip
                  - git
                  - smartmontools
                - nvme-cli
                  - htop
                - iperf3
                - dnsutils
                - net-tools
                  - whois
                state: present
                update_cache: yes
              no_log: true
              user:
                shell: /bin/bash
                state: present
                groups: sudo
                append: yes
                createhome: yes
              become: yes
              pause:
                seconds: 3
              file:
                state: directory
                mode: '0755'
              file:
                state: directory
                mode: '0700'
              authorized_key:
                state: present
              file:
                mode: '0600'
              copy:
                mode: '0440'
              changed_when: true
              copy:
                content: |
                mode: '0644'
              notify: restart ssh
              lineinfile:
                state: present
                backup: yes
              notify: restart ssh
              apt:
                state: present
                update_cache: yes
              copy:
                content: |
                  [DEFAULT]
                  bantime = 1h
                  findtime = 10m
                  maxretry = 3
                  banaction = ufw
                  [sshd]
                  enabled = true
                  port    = ssh
                  filter  = sshd
                mode: '0644'
              apt:
                state: present
                update_cache: yes
                rule: allow
              notify: restart ufw
                rule: deny
                port: '111'
              notify: restart ufw
                state: enabled
              notify: restart ufw
          rescue:
            - debug:
            - fail:
        - debug:
          pause:
          reboot:
            reboot_timeout: 300
          debug:
      handlers:
        - name: restart ssh
          service:
            state: restarted
          service:
            state: restarted
        - name: restart ufw
          service:
            state: restarted
    Wow... I'll need this weekend to process this...
    Thanks for the detailed ansible template!
  • SpeedBusSpeedBus Hosting ProviderOG
    Codie mc Coderson
    Nice! A couple of nice nuggets in that config. Consider them stolen. 😝
  • IDK if its already said, but you can install Komari Monitor and you can use remote exec commands on all servers at once.
  • I don't think I mentioned Ansible in a minute or two, sorry I am slacking
    Codie mc Coderson
      hosts: all
      gather_facts: no
      vars:
      vars_prompt:
        - name: "username"
          private: no
        - name: "password"
          private: yes
          confirm: yes
      pre_tasks:
          raw: |
            fi
          become: yes
          changed_when: false
          apt:
            update_cache: yes
          apt:
            upgrade: dist
          command: which sudo
          ignore_errors: yes
          apt:
            state: present
            update_cache: yes
          run_once: true
          changed_when: false
          setup:
      tasks:
        - block:
              apt:
                name:
                  - curl
                  - zip
                  - unzip
                  - git
                  - smartmontools
                  - nvme-cli
                  - htop
                  - iperf3
                  - dnsutils
                  - net-tools
                  - whois
                state: present
                update_cache: yes
              no_log: true
              user:
                shell: /bin/bash
                state: present
                groups: sudo
                append: yes
                createhome: yes
              become: yes
              pause:
                seconds: 3
              file:
                state: directory
                mode: '0755'
              file:
                state: directory
                mode: '0700'
              authorized_key:
                state: present
              file:
                mode: '0600'
              copy:
                mode: '0440'
              changed_when: true
              copy:
                content: |
                mode: '0644'
              notify: restart ssh
              lineinfile:
                state: present
                backup: yes
              notify: restart ssh
              apt:
                state: present
                update_cache: yes
              copy:
                content: |
                  [DEFAULT]
                  bantime = 1h
                  findtime = 10m
                  maxretry = 3
                  banaction = ufw
                  [sshd]
                  enabled = true
                  port    = ssh
                  filter  = sshd
                mode: '0644'
              apt:
                state: present
                update_cache: yes
                rule: allow
              notify: restart ufw
                rule: deny
                port: '111'
              notify: restart ufw
                state: enabled
              notify: restart ufw
          rescue:
            - debug:
            - fail:
        - debug:
          pause:
          reboot:
            reboot_timeout: 300
          debug:
      handlers:
        - name: restart ssh
          service:
            state: restarted
          service:
            state: restarted
        - name: restart ufw
          service:
            state: restarted
    So have you got all your fancy new BF deal VEE PEE ESSES built via Ansible yet or what?!?
  • Hey anyone mention Ansible yet?
  • Ansible
    No, got just 1 dedi from "he who shall not be named (on LES)" and set it up with docker. Did not get the bandwidth to work on ansible yet...
    Maybe i'll give it a try this coming weekend!
    Ansible? Is that like a new TV show?
    What's that? Can eat?
    @dosai said:
    Ansible
    No, it's A-sible. We do not put "an" before "S" :lol:
    @dosai said:
    Ansible
    Ansible? Never heard of it
  • Emacs
    Unattended upgrades and kernel patching with notifications.
    That sounds like ubuntu cheats. How about debian?
    Same use it on debian 12 daily.
