Fought with ansible for a while. It wants python module called "six" to be installed on ALL of my remote nodes/vms...
Anyone know what I am doing wrong?
This smells like mismatched ansible version to me. Ubuntu repos especially are very behind - maybe try finding a PPA to install ansible from. Or maybe install it from pip.
Yep definitely something between versions here… I actually don’t install anything on nodes and have a Debian prep script that runs everything needed, so any blank/base install just werks.
Will sanitize and post here shortly!
Currently have my laptop and phone (juice ssh) with keys to most vms
Realized it hard way a few days ago... if I wanted to transfer files from one vm to another it is next to impossible as all are key based auth and none have keys to login to other
Curious what is the way to go about...
Have a decent bunch of idlers so having n idlers keys on m machines seems too much?
Maybe have a secondary layer of auth/keys for stuff between nodes? Then as part of setup, deploy the key used for inter node work?
Or Ansible, since noone has mentioned it yet…
Yeah.
Secondary keys is needed. But wanna keep overhead of number of keys limited.
How to securely set same key on all nodes?
I started tinkering with ansible and got my laptop and phone keys added to authorized keys. So there's that. But actual private key sharing over the wire seems trippy?
python3 -m HTTPServer
Thats one way I was thinking too.
Curious if having one key across all makes sense or to do the painful way for x keys on y servers
No, it's never a good thing to share ssh keys.
I usually go with 3 ways.
If I want to automate file transfers, I usually create a low level user on the remote server and setup a ssh key between the 2 servers (like from my main server to my backup server).
If I only need to transfer a lot of files, I use SCP to download it to my desktop and reupload it back.
I installed it from ubuntu's repo, when that didn't work, I reinstalled it from python3 pip, but that didn't help either. I guess it's time to either try a proper PPA or install centos 8 and try from there. Thanks for the recommendations!
Interesting
Well file transfer is definitely not automated.
And its not just transfer. I may need to quickly ssh into another box right from there... I know I can connect organically from my laptop. But since inam already on server 1 so if I need to check something in server 2 it should be easy, right?
Thanks for the quick http file server. Will bookmark it
@nullnothere said:
I've not been following this fully, but a few quick hints:
Assume that your SSH connections are white listed (i.e. A->B, A->C and B<->C is allowed)
You have an ssh key for logins to connect from A->B and A->C
You want to transfer some file(s) from B->C
Use ssh-agent forwarding to provide access to your key ("resident" on A) to B (or C) thereby allowing B->C (or C->B) connections via this agent.
Since B->C (or vice-versa) is possible via agent forwarding, you can now directly rsync/scp files from B->C (or vice-versa).
man ssh-agent and ssh-add for options/security etc. RTFM.
Profit?
I think ssh-agent forwarding may work. Thanks
ssh bastion host?
The ssh agent forwarding option is -A.
So the commands would look like this:
user@laptop:~$ ssh -A server-1
user@server-1:~$ scp my-files/ server-2:
Only do this if you trust server-1. It essentially shares access to all ssh keys on your laptop. As the man ssh says:
Agent forwarding should be enabled with caution. Users with the ability to bypass file permissions on the remote host (for the agent's Unix-domain socket) can access the local agent through the forwarded connection. An attacker cannot obtain key material from the agent, however they can perform operations on the keys that enable them to authenticate using the identities loaded into the agent. A safer alternative may be to use a jump host (see -J).
Yeah.
2 keys total, one main one and a backup. If you are the only admin there is no sense making it difficult to manage or prone to human error.
If it's just 1 or 2 files, I use: https://github.com/somik123/python3_http_upload_progress
Thanks! Looking forward to it!
Interesting
Profit?
ssh bastion host?
That too...
Any recommendations?
DIY solution without any software bloats or extra security risks?
https://smallstep.com/blog/diy-ssh-bastion-host/
Or you can go with one of the more popular software solutions:
https://goteleport.com/blog/ssh-bastion-host/
Or go with a proper zero trust network with bastionXP:
https://www.bastionxp.com/docs/guide/
-A.So the commands would look like this:
server-1. It essentially shares access to all ssh keys on your laptop. As theman sshsays:Agent forwarding should be enabled with caution. Users with the ability to bypass file permissions on the remote host (for the agent's Unix-domain socket) can access the local agent through the forwarded connection. An attacker cannot obtain key material from the agent, however they can perform operations on the keys that enable them to authenticate using the identities loaded into the agent. A safer alternative may be to use a jump host (see -J).Finally posting my Ansible template for Debian setup... Sorry for the delay!
Codie mc Coderson
Wow... I'll need this weekend to process this...
Thanks for the detailed ansible template!
Found this on reddit a while ago,
https://www.reddit.com/r/selfhosted/comments/1nlth9k/finally_built_patchmon_my_linux_updates
GitHub: https://github.com/PatchMon/PatchMon
Nice! A couple of nice nuggets in that config. Consider them stolen. 😝
IDK if its already said, but you can install Komari Monitor and you can use remote exec commands on all servers at once.
ServerStatus , slackvpn , linux mirrors
Recommended Providers: Servarica(aff) | HostBRR(aff) | SolidVPS(aff) | RackNerd(aff) | KuroIT(aff) | AlphaVPS(aff) | HostDare(aff)
I don't think I mentioned Ansible in a minute or two, sorry I am slacking
So have you got all your fancy new BF deal VEE PEE ESSES built via Ansible yet or what?!?
Hey anyone mention Ansible yet?
Ansible
No, got just 1 dedi from "he who shall not be named (on LES)" and set it up with docker. Did not get the bandwidth to work on ansible yet...
Maybe i'll give it a try this coming weekend!
Ansible? Is that like a new TV show?
What's that? Can eat?
No, it's A-sible. We do not put "an" before "S"
Ansible? Never heard of it
https://patchmon.net
Emacs
That sounds like ubuntu cheats. How about debian?
Same use it on debian 12 daily.
