I want to make an AI website ,can some recommend me some wordpress themes?
Hey everyone,
I’m planning to build a website focussed on AI (artificial intelligence) — maybe for a startup, service offering, blog or agency. I’ll be using WordPress, so I’m on the lookout for good theme recommendations that work well for AI-related sites (clean modern design, tech/innovation vibe, good performance, easy to customise).
If you’ve used any themes that you’d rate highly (especially those with templates for tech/AI, good page builders, and solid support) please drop the names and a quick note why you liked them.
Thanks in advance!
Ask AI for recommendation and coding help.
No hostname available. affbrr
I don't think wordpress is really needed you can get it done with self made php script by AI and use free hosting just buy domain
as has been asked by others before:
a. Why WordPress (why not others?)
b. ASK AI / LLM exactly the same question, but keep a look and feel/ theme in mind. Technology/ Blog/ Sci-Fi theme? or functional ?
c. If you ARE committed to WP, then use a base theme like underscores or something bootstrap-ish, and then ask the LLM to create a custom theme for you.
Edit:
I just completed a test project where I specifically wanted to use an older non block/Gutenburg theme, I opted for RAMS and McLuhan themes by Anders Noren, and asked Gemini/ Grok to go nuts with the theme
(PHP/ CSS/ native lazy loading/ caching.... etc...). Quite a learning experience, there comes a time when the AI tool simply behaves like a dog who is on a long walk and suddenly sits down and does not want to go home.
BR
blog | exploring visually |
Hello!
Nice to see you again!
Not trying to give you a hard time. Just inviting you to enjoy a little joke together with me.
https://wordpress.org/themes/wp-dos/
Haven't used this theme. Haven't used Wordpress except a little.
Go with green! /s
WordPress isn’t the best fit for an AI-focused site unless you’re just blogging. For a startup or service site pitching innovation, you want speed, clean UX, and modern interactions - things WP struggles with out of the box
