LES BSD Thread!
1121314151618»
    edited November 22
    @cmeerw said: the article has this note
    Oops! :)
    Thanks @cmeerw! <3
  • FreeBSD 15 release is just around the corner!
    https://www.freebsd.org/releases/15.0R/relnotes/
    My rocking @linveo instance is going to be the first one that'll receive this upgrade.
    Thanked by (1)angstrom
    Anyone using GhostBSD on their desktop or laptop? What are your thoughts on it versus any other BSD variant? Tried to get it going in a local VM but updates / software installs kept failing or taking hours. (Network connectivity is fine, I think their update / package servers are too distant or too bogged down)
    Hi @MannDude! I never tried GhostBSD, so I can't really comment. Best wishes!
    GhostBSD has a tool that allows you to manipulate mirror settings (https://github.com/ghostbsd/software-properties-station)
    You can check your current repo configuration like this:
    sudo software-properties-station --current
    Other possible mirrors can be fetched with this command:
    sudo software-properties-station --list
    You can switch the current setting with something like:
    sudo software-properties-station GhostBSD_US
    /etc/pkg/GhostBSD.conf should reflect whatever changes you made.
    Hopefully this will help!
    Thanked by (2)Not_Oles MannDude
    I am having the same issue, but with FreeBSD. The mirrors are insanely slow and I cannot be bothered to use them. It's the only thing stopping me from using FreeBSD especially after their Laptop Project this 15 release.
    Thanked by (1)MannDude
  • edited December 3
    FreeBSD 15.0 is here and update to the @linveo instance was smooth as butter and everything working great!
    EDIT: Linveo instance was using pf firewall which didn't have any issues, but proceed cautiously if you have ipfw installed. After 15.0 kernel installation and the first reboot, network was down due to ipfw being very unhappy. Stopping ipfw made networking to work and after finishing the full update process, ipfw continued to work again. Make sure you have VNC accessible or disable ipfw before booting for the first time!
  • @Otus9051 said: I am having the same issue, but with FreeBSD. The mirrors are insanely slow and I cannot be bothered to use them. It's the only thing stopping me from using FreeBSD especially after their Laptop Project this 15 release.
    If GeoDNS is not able to provide you the closest mirror using downloads.freebsd.org, you can check them manually at https://docs.freebsd.org/en/books/handbook/mirrors/. Generally I have had very adequate performance out of the mirrors, even at peak times like today's release date, but of course YMMW.
    I used fastest_pkg and the fastest I can get is around 800kb/s. Definitely not a problem with my internet/vm networking because it can still fetch at 18-20 MB/s, which is the max my internet plan goes. Problem isn't with GeoDNS, but probably some sort of weird throttling/peering issue that I cannot quite put my hands on.
