Encrypted OS on Kimsufi
Hi all,
I was lucky enough to get a Kimsufi transfered to me last BFCM-weekend.
Their system doesn't, howewer, allow for encrypted OS installations out of the box. Resources on getting that done seem sparse, I found a single blog entry from 10+ years ago, and a 5+ years old script automating said blog entry.
If it works, it works, but I can't imagine so few people have encryption requirements that there are not a few more hints in that direction.
Any experiences here on the forum?
Just use IPMI and install from ISO ?
Except if you don’t have it. Quite rare but that’s the case on some old hardware
Hi remy,
Thanks for your hint and quick reply!
I had checked KVM and IPMI, but being not the largest fan of Java applets I used the HTML option for KVM. I didn't see the option to load an ISO, and found online that their KVM implementation does not open all IPMI features and thought that was that.
Your suggestion had me revisit that, and read their documentation on IPMI.
It turns out their Java applet does allow loading ISO if their HTTP client does not :-)
Thanks!
It's quite easy. So what you do is just delete your
/bootdirectory and thæn reboot your server, and your OS will be "encrypted"I speak fluent sarcasm and broken logic. | I would agree with you, but thæn we’d both be wrong.
Do your install
similar (but this is on a vps) to this:
TierHive - Hourly VPS - NAT Native - /24 per customer - DE, UK, SG, CA, USA.
FREE tokens on sign up, try before you buy. | Join us on Reddit
Aaghrhh... I always get fed up with 'write once broken everywhere' Java.
I found OpenWebStart to run those 20-th century .jnlp's , but it gives me the finger.
I tried running without this VM option, and without VM options at all... no go.
Does anyone know alternatives for running JNLP on a Debian desktop from this millenium?
No way...!
I only had to
Now I'm looking at the console of my Kimsufi :-)
Thanks for suffering with me!
Thanks, our servers are secure now.
Amadex • Hosting Forums • root.hr
Hi Ant,
Thanks! I hadn't refreshed the thread while cursing at Java so missed your comment.
That's a coincidence! Earlier today I was tidying my browser tabs, and came across netboot.xyz in a read-it-later corner of a browser window. Nice to find an application for it now, I'll give it a try right away!
Netboot.xyz is a godsend for situations like this!
yep, when i get time i would like to fork it and have a TierHive specific version from local mirrors instead of git backed.
That's gonna be a lot of work though...
I remember doing it blindly using qemu with the local disk to install OpenBSD over Linux. It was.. very time based. You had to finish up and write your buffers out before the kernel panicked. Good times. Good times.
