I want to make an AI website ,can some recommend me some wordpress themes?
Hey everyone,
I’m planning to build a website focussed on AI (artificial intelligence) — maybe for a startup, service offering, blog or agency. I’ll be using WordPress, so I’m on the lookout for good theme recommendations that work well for AI-related sites (clean modern design, tech/innovation vibe, good performance, easy to customise).
If you’ve used any themes that you’d rate highly (especially those with templates for tech/AI, good page builders, and solid support) please drop the names and a quick note why you liked them.
Thanks in advance!
  • Ask AI for recommendation and coding help.
    Thanked by (2)vyas alim
    No hostname available. affbrr
  • I don't think wordpress is really needed you can get it done with self made php script by AI and use free hosting just buy domain
  • vyasvyas OGSenpai
    edited November 24
    as has been asked by others before:
    a. Why WordPress (why not others?)
    b. ASK AI / LLM exactly the same question, but keep a look and feel/ theme in mind. Technology/ Blog/ Sci-Fi theme? or functional ?
    c. If you ARE committed to WP, then use a base theme like underscores or something bootstrap-ish, and then ask the LLM to create a custom theme for you.
    Edit:
    I just completed a test project where I specifically wanted to use an older non block/Gutenburg theme, I opted for RAMS and McLuhan themes by Anders Noren, and asked Gemini/ Grok to go nuts with the theme
    (PHP/ CSS/ native lazy loading/ caching.... etc...). Quite a learning experience, there comes a time when the AI tool simply behaves like a dog who is on a long walk and suddenly sits down and does not want to go home.
    BR
    Hello!
    Nice to see you again!
    Not trying to give you a hard time. Just inviting you to enjoy a little joke together with me. :)
    @nwnuyhs said:
    Hey everyone,
    https://wordpress.org/themes/wp-dos/
    Haven't used this theme. Haven't used Wordpress except a little.
    Thanks in advance!
    Go with green! /s
    Thanked by (1)MichaelCee
  • WordPress isn’t the best fit for an AI-focused site unless you’re just blogging. For a startup or service site pitching innovation, you want speed, clean UX, and modern interactions - things WP struggles with out of the box
