I removed the tag because I chose to. I work with clients across multiple channels, so taking down one listing doesn’t mean I’ve stopped offering services elsewhere. Everything I do is self‑funded and debt‑free; I have the resources to run my businesses long term. The Yeti is 49 and retired, that’s background, not a liability. No need to speculate further; I’ll post updates where appropriate.
They stopped VPS service but, as far as we were told, LIR service continues. https://www.cloudie.sh/
Website has link to billing panel only.
Oh right, might have to leave that thanks, but pretty VPS and BGP service stuff is definitely gone. Maybe it's not taking new business? I assume the admins have a contact address that can be used for a liveliness test every so often. Maybe failure to respond after 3 contact attempts or no login for 2+ years a provider gets marked as "idle" or something?
Elsewhere someone proposed Virmach be stripped of its provider tag. It doesn't seem like an unreasonable request, but I think the approach is not particularly defensible in this case. I've been meaning to ask, should there be a process for providers to maintain their tags? Some sort of liveliness check for sure, but maybe some, hopefully easy and simple, ongoing eligibility criteria that must be maintained? Then I'd suggest the answer is yes, there should be some basic policy to remain on the list in good standing.
I don't think this needs to be complicated. Maybe even delegate some of this work to forum users, where they bring to the attention of the group an argument for de-listing, and mods can decide whether such an action is warranted or worth further investigation. Possible causes of de-listing or suspension might be the start of a policy, and for guidance purposes only such as (suggestive only)
Unresponsive, no forum activity, lack of non-automated answers to tickets
@jtk said: Unresponsive, no forum activity, lack of non-automated answers to tickets @rockinmusicgv said:
I would argue that as long as his stuff is still working, he's still a provider...
Does this put @ViveHosting in the sights, given my non-operational VPS that has two (one Closed now) ignored Tickets against it?
@jtk said:
At quick glance, these might be candidates for being purged?
cloudie (out-of-business, listed in multiple sections)
Is a formal process for removing a host besides the obvious out-of-business evidence? charityhost might be a provider to end relations with? I can think of one other that should be considered, but some of you won't like it.
I advocate for a minimum level of Quality of Service (QoS) test and when those criteria are not met the provider is purged... I suggest just this criteria for now: "answer publicly within 1 month of a concern being raised in the forum" (which is quite lax since it does not deal with the outcome, it is only about getting a public reply from the provider). Thanks.
Not really my choice but I'm intrigued to say the least
I removed Cloudie's hosting provider tag. Kept their service provider tag as per yoursunny's post below.
Thanks but I feel 149 lol
BRING BACK YA MUM JOKES!
Your mom’s so legendary, Google shows “Did you mean: Her?
best of "yoursunny lore" by Google AI 🤣 affbrr
Dataplane.org's current server hosting provider list
and maybe some other reasons.
Another provider update:
I thought Anynode customers just became BuyVM customers. Were they keeping the other brand alive?
Quote from Francisco from May 2021: "We aren't buying anynode, it'll continue to operate its dedicated servers, IPs, etc."
Right, minor update on the provider list to remove VPS as one of the offered services. An update, not a removal.
Done
Also added @VM6 to the list
This service appears to be offline:
I tried to remove Virmach but you can see how it went~.
💩 VirCrap 💩
This hosting provider link is broken:
https://amadex.com seems to work, perhaps it should be that now?
This provider seems to have gone away. Main site is 404. There is a .com of the same name, but that doesn't appear to be the same operation.
