TierHive - NAT Native - /24 per customer - Lab in the cloud - Free to try - HOURLY VPS - Update!
backtogeekbacktogeek Hosting ProviderOGSenpai
edited December 16 in Offers
Hi Folks,
Today, we launched version 0.2.2 Alpha of TierHive. Many fixes are in, thanks to user feedback and also many things we did not consider at scale were improved so not much is visible. This was really the first big maintenance tranche of work.
  • There was an issue with the PostgreSQL database imports that was fixed.
  • Some customer subnet isolation rules were not working and this has been fixed.
  • MANY admin-side things have been fixed.
  • Better filtering is in place for duplicate accounts (Free token abusers)
  • The resource settings slider for disk no longer defaults to 10GB, causing accidental upgrades.
  • The REFFERALS system is in place now and visible, so you can get FREE tokens hourly for links or an X/tweet, doubled for now!
Reminder - This product is still in Alpha
Cost: FREE Tokens when you sign up, try before you buy, we only need a username and email address.
Examples of the cheapest and most expensive VPS:
  • 1 x vCPU
  • 128MB Ram
  • 1 GB Disk
  • Free priority tier
    $0.000135 per hour | $0.00324 per day | $0.09855 per month | $1.1826 per year
  • 1 x vCPU
  • 2048 MB Ram
  • 25 GB Disk
  • High priority tier
    $0.002403 per hour | $0.057672 per day | $1.75419 per month | $21.05028 per year
What We Offer and Why It's Different.
  1. NAT Hourly VPS service with a network first principal, upon sign-up (free tokens) or first payment, your network is setup, you get a whole /24 e.g. 10.55.44.0/24, this is meshed across all locations for you, so you can create a vps in Germany and a vps in the UK and a VPS in Canada and they can all talk to each other directly on your own isolated network as if they were on the same LAN.
  2. You can self-migrate your own servers between regions.
  3. You can change your own Ram/Disk and priority tier resources for your VPS
  4. You get 2 TCP/UDP ports forwarded to every VPS you create so it becomes reachable from outside.
  5. We offer HAProxy + SSL termination at no extra cost, and provide starter webserver configs for compatibility.
  6. Email relay services, we also allow email through most major relays as standard.
  7. Database offloading, let us do that compute work for you.
  8. Recipe system, want to deploy WireGuard to 200 VPS at once? , want to deploy 100 VPS at once?, want to deploy a LibreNMS cluster with nodes? , Want your known dev environment set up automatically for you? Just create and save a recipe, 1-click deployment! Share it publicly and earn tokens as others use it.
  9. 1 Hour minimum for the Hourly VPS
Terms: The usual, if its morally questionable, ask, no TOR no Torrents, No SPAM etc. one account per customer please we dont accept orders from Brazil, China, Vietnam, Russia, Iran
Short demo of the panel and creating a VPS.
As always, questions, comments and feedback are welcome. This is our own creation, completely custom. If anyone has any good ideas, we will consider them. Just keep in mind, it's a small team of 3 people, we are not Amazon :D
TierHive - Hourly VPS - NAT Native - /24 per customer - Lab in the cloud - Free to try.
FREE tokens when you sign up, try before you buy.
  • Whereabouts on the roadmap is IPv6? Will open up some other use options for me...
  • Without installing the operating system, you can choose 128MB, while even the smallest Alpine installation requires 256MB.
  • backtogeekbacktogeek Hosting ProviderOGSenpai
    Best guess, March/April 2026, we want our own IPv6 before doing this, IPv6 is so easy to get wrong early and then you trap yourself.
    is that a question or advice for others?
    question, I don't know how to create a 128MB VPS. =)
    edited December 16
    oh ok, select "No Operating System" from the list, and self-install, or install with 512MB then when its ready, downgrade to 128MB
    Thanked by (2)jcn50 zrj766
  • edited December 16
    We don't know why people still abuse a ≈$1/year/VPS product.
    In many currencies, even in a developing country, this is still a non-trivial amount.
    Unless they are underaged and don't have their own online form of payment yet.
  • 3 persons , Ant + @WSS + @AuroraZero
    ASSzero ?
  • @backtogeek said:
    ASSzero ?
    hahahahhahahahhah .....
  • I turned mine off. Not sure if I have a use for it. Someone else can enjoy it.
    well your credit is not going away, use it any time, maybe at some point you need a vps for something you can set and forget or for a few hours, bam... tierhive.
    Thanked by (2)WSS skorous
  • ❯ curl -s https://ipinfo.io/ | jq -r .country
    BR
    ❯ curl -v https://tierhive.com/
    < HTTP/1.1 301 Moved Permanently
    < location: http://kernelkeepers.com/geo.html
    Is it geo blocked?
    @eliphas said: Is it geo blocked?
    thats right, we dont accept orders from Brazil, China, Vietnam, Russia, Iran
  • Da hail did I do? I am minding my own bidness in my cave coding crap and you all got to drag me back!!!
  • teamaccteamacc OGSenpai
    How would the mariadb offloading work? I'm currently running a 20gb database, I'd probably guess that offloading that would not be, ehrm, the point of this?
    probably best on AWS :D
