LES BSD Thread!
1121314151618»
    edited November 22
    @cmeerw said: the article has this note
    Oops! :)
    Thanks @cmeerw! <3
  • FreeBSD 15 release is just around the corner!
    https://www.freebsd.org/releases/15.0R/relnotes/
    My rocking @linveo instance is going to be the first one that'll receive this upgrade.
    Thanked by (1)angstrom
    Anyone using GhostBSD on their desktop or laptop? What are your thoughts on it versus any other BSD variant? Tried to get it going in a local VM but updates / software installs kept failing or taking hours. (Network connectivity is fine, I think their update / package servers are too distant or too bogged down)
    Hi @MannDude! I never tried GhostBSD, so I can't really comment. Best wishes!
    GhostBSD has a tool that allows you to manipulate mirror settings (https://github.com/ghostbsd/software-properties-station)
    You can check your current repo configuration like this:
    sudo software-properties-station --current
    Other possible mirrors can be fetched with this command:
    sudo software-properties-station --list
    You can switch the current setting with something like:
    sudo software-properties-station GhostBSD_US
    /etc/pkg/GhostBSD.conf should reflect whatever changes you made.
    Hopefully this will help!
    Thanked by (2)Not_Oles MannDude
    I am having the same issue, but with FreeBSD. The mirrors are insanely slow and I cannot be bothered to use them. It's the only thing stopping me from using FreeBSD especially after their Laptop Project this 15 release.
    Thanked by (1)MannDude
  • edited December 3
    FreeBSD 15.0 is here and update to the @linveo instance was smooth as butter and everything working great!
    EDIT: Linveo instance was using pf firewall which didn't have any issues, but proceed cautiously if you have ipfw installed. After 15.0 kernel installation and the first reboot, network was down due to ipfw being very unhappy. Stopping ipfw made networking to work and after finishing the full update process, ipfw continued to work again. Make sure you have VNC accessible or disable ipfw before booting for the first time!
  • @Otus9051 said: I am having the same issue, but with FreeBSD. The mirrors are insanely slow and I cannot be bothered to use them. It's the only thing stopping me from using FreeBSD especially after their Laptop Project this 15 release.
    If GeoDNS is not able to provide you the closest mirror using downloads.freebsd.org, you can check them manually at https://docs.freebsd.org/en/books/handbook/mirrors/. Generally I have had very adequate performance out of the mirrors, even at peak times like today's release date, but of course YMMW.
    I used fastest_pkg and the fastest I can get is around 800kb/s. Definitely not a problem with my internet/vm networking because it can still fetch at 18-20 MB/s, which is the max my internet plan goes. Problem isn't with GeoDNS, but probably some sort of weird throttling/peering issue that I cannot quite put my hands on.
    Hetzner EX63 dedicated server installed with FreeBSD 15 via depenguin.me:
    chronos@penguin:~/2025-post-backup/ex63$ ssh [email protected]
    The authenticity of host 'xxx.xxx.xxx.xxx (xxx.xxx.xxx.xxx)' can't be established.
    ED25519 key fingerprint is SHA256:iwrKeqa9NGjDx66VtAkXinv/JQsm7+9ta6LFdUE14Ns.
    This key is not known by any other names.
    Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
    Warning: Permanently added 'xxx.xxx.xxx.xxx' (ED25519) to the list of known hosts.
    FreeBSD 15.0-RELEASE (GENERIC) releng/15.0-n280995-7aedc8de6446
    Welcome to FreeBSD!
    Release Notes, Errata: https://www.FreeBSD.org/releases/
    Security Advisories:   https://www.FreeBSD.org/security/
    FreeBSD Handbook:      https://www.FreeBSD.org/handbook/
    FreeBSD FAQ:           https://www.FreeBSD.org/faq/
    Questions List:        https://www.FreeBSD.org/lists/questions/
    FreeBSD Forums:        https://forums.FreeBSD.org/
    Documents installed with the system are in the /usr/local/share/doc/freebsd/
    directory, or can be installed later with:  pkg install en-freebsd-doc
    For other languages, replace "en" with a language code like de or fr.
    Show the version of FreeBSD installed:  freebsd-version ; uname -a
    Please include that output and any error messages when posting questions.
    Introduction to manual pages:  man man
    FreeBSD directory layout:      man hier
    To change this login announcement, see motd(5).
    Want to see how much virtual memory you're using? Just type "swapinfo" to
    be shown information about the usage of your swap partitions.
    tom@ultra:~ $ date
    Fri Dec 26 19:56:26 UTC 2025
    tom@ultra:~ $ sudo su -
    root@ultra:~ #
    Thanked by (2)cmeerw Crab
  • edited December 26
    Hetzner used to formally support FreeBSD, had their own rescue images etc everything working great until one day they just simply dropped it. You can still naturally install it on their dedis and it works great, but it was still a sad day.
    https://www.reddit.com/r/freebsd/comments/wf7h34/hetzner_has_silently_dropped_support_for_freebsd/
    On an E5-1650 from the Hetzner Server Auction via depenguin.me:
    chronos@penguin:~/2025-post-backup/1650$ ssh [email protected]
    ED25519 key fingerprint is SHA256:3d9Uut3RMez504W6Q+VxRV9eX01poBTt2xW4RPfTzbE.
    Welcome to FreeBSD!
    If you want to recursively copy a directory preserving file and directory
    attributes use
    "cp -a source target"
                    -- Lars Engels <[email protected]>
    tom@E5-1650:~ $ sudo su -
    root@E5-1650:~ #
