@eliphas said:
The lifetime VPS that I bought yesterday at Ashburn (US East) is an EPYC.
Funny the IP address is geolocated at Baghdad/Frankfurt depending on who you ask; support ticket says it is normal and the GeoIP people will eventually update; I can't confirm or deny that
Still configuring it but overall seems very snappy.
It is a fact that if you buy a VPS (vServer) with a configuration higher than 5.5 vCores, the performance is not used continuously. I made a mistake when buying a VPS in Germany, with an order of 64 vCores (((. My VPS cannot take full advantage of the performance, any CPU burst activity greater than 5.5 vCores will be automatically sent an email by Zap-Hosting (Regardless of the configuration of your VPS) and the system will automatically shut down the VPS. It feels so disappointing.
With RAM prices sky-rocketing, I'm happy I snagged another lifetime vps at that price on bf. Pretty sure monthly/yearly contracts will soon enough increase in pricing across the board.
Christmas is here and with it great discounts and savings opportunities.
These include Flash voucher codes with discounts up to 70% that are only valid for a short time! Flash voucher codes for VPS and lifetime VPSs are available on ZAP-Hosting at the following times:
VPSs:
27.12.2025: 19 hrs - 20 hrs CET
28.12.2025: 06 hrs - 07 hrs CET
28.12.2025: 19 hrs - 20 hrs CET
29.12.2025: 06 hrs - 07 hrs CET
Lifetime VPSs:
27.12.2025: 11 hrs - 12 hrs CET
27.12.2025: 20 hrs - 21 hrs CET
28.12.2025: 11 hrs - 12 hrs CET
28.12.2025: 20 hrs - 21 hrs CET
Gameservers:
27.12.2025: 13:00 hrs - 14:00 hrs CET
27.12.2025: 23:00 hrs - 00:00 hrs CET
28.12.2025: 13:00 hrs - 14:00 hrs CET
28.12.2025: 23:00 hrs - 00:00 hrs CET
Lifetime Gameservers:
27.12.2025: 15:00 hrs - 16:00 hrs CET
28.12.2025: 03:00 hrs - 04:00 hrs CET
28.12.2025: 15:00 hrs - 16:00 hrs CET
29.12.2025: 03:00 hrs - 04:00 hrs CET
VPSs:
Lifetime VPSs:
Gameservers:
VPSs:
Lifetime VPSs:
Gameservers:
Hmm up to 70%, the lifetimes I think have only ever gotten max 30% coupon on BF I think?
VPSs:
Lifetime VPSs:
Gameservers:
I think max on lifetimes was smth like 30-35%. 70% is definitely for the rental servers
🇺🇸 **Dallas Update**
Over the past three days, we have been affected by severe downtime at our Dallas location. The cause was an air conditioning issue on the data center's side, which forced several servers into overheat protection. As a result, some hardware components and a critical core switch were damaged.
In the meantime, the data center has resolved the issue, and we have been able to restore all hardware components. We are still working on bringing the last remaining services back online, but we expect everything to be running stably again within the next two hours. We deeply appreciate your patience throughout this period.
All customers with services at this location will be compensated with €20 in ZAP credit. In addition, you will receive a 50% discount on your next Dallas order using the voucher code: Dallas-50off-1225
Fyi: Dallas-50off-1225 works with 50% off lifetime vps 👀
Looks like Santa was late but finally came with a lifetime discount haha
Wow!! I think that's a record coupon!
You could potentially get a small storage box (500gb) for a little over 100 with this!
You can also later switch location iirc (for a price). Nvm, after redeeming the coupon, I could also select Germany location right away (32€).
I wouldn't chance it and it could have been a bug but it looks like it was applying the coupon to other locations as well
Yeah, seems that way. Anyway, I'm probably not going to order anything anyway. The price is tempting, but I've already 2 (mostly) idling vps with them
It's indeed a record coupon and I couldn't resist so I went ahead and got a beefy VPS in Germany for a poorly optimized gameserver which needs strong single threaded performance, something my dedis can't provide (* cries in Ivy Bridge cpu marks *) but I unfortunately got deployed on an older v4 node.
I might ask whether I can migrate to an EPYC or Ryzen host as they advertised most servers would get deployed there (if not all?)
mar 30 dic 2025 06:12:05 EST
Uptime : 0 days, 0 hours, 7 minutes
Processor : Intel(R) Xeon(R) CPU E5-2680 v4 @ 2.40GHz
CPU cores : 8 @ 2397.222 MHz
AES-NI : ✔ Enabled
RAM : 26.9 GiB
Swap : 0.0 KiB
Disk : 393.6 GiB
Distro : Debian GNU/Linux 13 (trixie)
Kernel : 6.12.41+deb13-amd64
VM Type : KVM
Test | Value
Single Core | 865
Multi Core | 4405
Full Test | https://browser.geekbench.com/v6/cpu/15843888
YABS completed in 11 min 58 sec
I asked them if it was possible to migrate to a newer node, which they agreed to. But looks like the CPU limits are still equally as strict:
mar 30 dic 2025 08:06:09 EST
Uptime : 0 days, 0 hours, 6 minutes
Processor : AMD EPYC 7763 64-Core Processor
CPU cores : 8 @ 2450.000 MHz
AES-NI : ✔ Enabled
RAM : 27.4 GiB
Swap : 0.0 KiB
Disk : 393.6 GiB
VM Type : KVM
Test | Value
Single Core | 857
Multi Core | 4500
Full Test | https://browser.geekbench.com/v6/cpu/15845419
AES-NI : ✔ Enabled
RAM : 26.9 GiB
Swap : 0.0 KiB
Disk : 393.6 GiB
VM Type : KVM
Test | Value
Single Core | 865
Multi Core | 4405
AES-NI : ✔ Enabled
RAM : 27.4 GiB
Swap : 0.0 KiB
Disk : 393.6 GiB
VM Type : KVM
Test | Value
Single Core | 857
Multi Core | 4500
My vps was also on Xeon cpu but I also asked them and it seems like it'll be moved to Epyc now Great! A while ago they couldn't accommodate my request (during bf sale), so quite happy to have my first lifetime vps on EPYC
AES-NI : ✔ Enabled
RAM : 26.9 GiB
Swap : 0.0 KiB
Disk : 393.6 GiB
VM Type : KVM
Test | Value
Single Core | 865
Multi Core | 4405
AES-NI : ✔ Enabled
RAM : 27.4 GiB
Swap : 0.0 KiB
Disk : 393.6 GiB
VM Type : KVM
Test | Value
Single Core | 857
Multi Core | 4500
Edit: It's on EPYC now
Did you have the chance to compare CPU performance between the two? A support rep. told me that performance should be about the same regardless of CPU model, because they are selling virtual cores. (They have never promised dedicated cores/threads, though)
They are willing to investigate it and work on it if I provide details about the gameserver I am intending to run (which I will) but I don't have high hopes
Thanks for sharing.
BTW, that was some fast ticket response, 4 minutes in plain weekend after BF. Color me impressed!
SSDNodes Coupon 30% - SSDNodes
Maybe this is off-topic (delete if so) but I have received this email regarding an open technician position for their Eygelshoven DC.
Just posting in case anyone nearby is interested on personally taking care of their lifetime servers
https://join.com/companies/zap-hosting/15308236-full-time-data-center-technician-m-f-d-eygelshoven-nl-close-to-aachen
Recieved this the other day
VPSs:
Lifetime VPSs:
Gameservers:
I already bought on bf. It's enough
sure. i believe you!
Got this on Discord:
That stoopid code worked. Now stuck with another lifetime vps.
Ah, dammit. This is better than bf. Bought one at 50% off in Germany
Ordered, but not yet deployed. Seems like it's on-hold. Maybe the coupon has been overused?
Edit: got deployed
Now, this is a story, all about how, I ended up with yet another lifetime ZAP server...
