Alternative to Cloudflare for SaaS for more than 50k custom domains
I have an idea for a project I might actually build in 2026, which would offer users the ability to configure custom domains for their accounts.
Years ago I used to run a blogging platform that I built myself for a couple of years, and I had to do a lot of work to implement custom domains support, which is something I'd rather not have to do again.
I use Cloudflare for a lot of things and I know they now have a product called "Cloudflare for SaaS" which makes it ridiculously easy to add a custom domains feature to a SaaS product, but it supports max 50k domains per account. Beyond that, it's enterprise pricing so I don't know how expensive it would be. Perhaps it would be fine, since already 50k paying customers (the custom domains feature would be a paid only feature) would mean quite a good revenue already, but I am wondering about scalability in the event the product takes off. If it does, 50k is really not a lot of domains.
As an alternative I found https://saascustomdomains.com/ which I had never heard of before, but they claim to support unlimited domains. They cost twice as much as Cloudflare at $0.20 per domain per month, instead of $0.10 (with Cloudflare the first 100 domains are free also).
Have you used any of these or similar products?
For my old project I implemented custom domains with multiple ingress controllers in Kubernetes, and each custom domain had its own ingress resource. In theory I could do that again but scalability would be a problem, because of etcd and the number of objects that would have to be stored in etcd. I have read that Traefik for example can read routes from a relational database instead of using resources stored in etcd, but I don't think Traefik scales much anyway.
I have also read that Caddy can support losts of virtual hosts even on a single machine, but I don't have much experience with it.
In general, I would prefer using something like Cloudflare for SaaS for the simplicity of it, but I am open to suggestions.
Has any of you implemented custom domains support for a SaaS product?
SprintPulse - Retrospectives for Teams That Ship
