Since you dont want english, edit the code for en.php itself. Or for ru.php
Basically pick a language you dont need and make it chinese instead of figuring out how to convert it to chinese, specially if you want to USE the vanilla forum and not sell it.
Just in case, 1.5 times older phpBB code (3.0.x - 2010 I believe) works literally perfect if you can supply proper PHP version (5.3 or so).
In my experience, with an old forum: past a certain point, even if I used the old php version (5.4 was in that case if memory serves me), the available DB version installed on the shared hosting server could no longer support the forum's software so it started getting bugs until I updated it to a version that uses a newer PHP version.
So, past a certain point, the old software can get tricky to run (I'd have to use a VPS with older stuff installed on it).
@DataRecovery said:
Since we're talking about forums.
Did someone say "docker container stack"?
Did someone mention Docker Container Crap?
But you have to admit, if you are gonna put old and outdated software on your server, docker is the way to go. I mean the main reason to use docker is it's readonly file system and support for so many softwares, at the cost of slight overhead.
Ok, maybe not slight, since you usually run 1 container with mysql for every stack that needs a database...
Look at how dumb you are.
He really doesn't know us does he?
I thought he was a bot posting random things to keep his account active?
If it was anyone else, they would have been banned long ago by @Mason for spamming or "being a dick"
Hi @ehab! I said "What?" cuz our friend @wssy hypothesized that he was the only one here. He always has been helpful and polite to me, ever since I first came here. I want him to know -- like I feel from you and many others here -- that he never needs to feel alone here.
Here is the download link, valid for 3 days:
https://kfels.com/file/mphvd/thankfulpeople2-plugin-2.2.4.zip
Just to take note, this is from 2015... 10 YEARS old code...
Perfect for Vanilla
Thanks!
What could possibly go wrong
Best vintage!
Thanks so much!
Does any one know how to set the Chinese language for this plugin? I copied the en.PHP and named to zh.php. But it doesn't work!
Just edit the code.
I mean that zh.PHP or zh_CN.php
So people think by renaming a file the interface would suddenly change its language???
What world are we living in?
I mean that the language PHP file's name. I have already translated the file to chinese.
★ 80–85% ↓↓ – NVMe(NL) from 1c EPYC/1G/30G/1T – $12/y (ref), codes: LETMINI80, LETSAILOR80 respectively / SSD(US) from 1c/2x256M/2x10G/256G – $5.4/y (ref), ×2 upg. via ticket, codes: SPECIALMINI85, LETSAILOR85, SEAMANSSD85
what file is that ?
WHO is the bot?
@WSS
Just look at his recent posts: https://lowendspirit.com/profile/comments/WSS
@WSS what is the secret password to prove your not a bot.
do not add dicks
need to know you have a real one
No, I am not powered by an LLM. I am powered by hatred. Also, I'm grandfathered in before there was a stupid rule about dicks.
yep,sounds like WSS
happy new year
I'm the only one here today, my back hurts, and I want to go home. 2026 sucks. Where's the snow?!
What? 👋
happy new year Tom ... How are you? hope all is good.
don't mind WSS he didn't have sex for a long time.
