[WANTED] Dev Box – 2–4 Cores, 4GB RAM, 40–75GB SSD, 2TB BW – $5/mo Paid Monthly
AuroraZero
Retired
in Requests
Looking for a low-cost dev box with the following minimum specs:
CPU: 2–4 cores (4 preferred, shared OK)
RAM: 4 GB
Disk: 40–75 GB SSD (no HDD)
Bandwidth: 2 TB/month
Location: Flexible, but prefer stable network and upstream
Budget: $5/month max, paid monthly (no annuals)
Use case: Light dev workloads, no abuse, no crypto, no torrents
OS: Debian/Ubuntu preferred, but flexible
Billing: Monthly only — no upfront annuals
Not looking for trialware, bait-and-switch, or “promo” pricing. Just a stable, honest box with predictable billing and decent I/O. Open to lesser-known providers if ops are solid.
If EUR4.99 works for you, check out layer7.net
Solid provider, and you can get 4C/8G/120GB for that price.
https://extravm.com/billing/store/kvm-nvme-vps-dallas-tx/4gb-dallas-deal
Double specs double price for idling?
@AuroraZero If you’d like that in Toronto on EPYC 7702P - I’d be happy to oblige! (Also have Xeon gold if it doesn’t matter)
Lesser known, yes. Good with Dad/bad jokes, also yes!
LG: https://tor-lg.hostbilby.com
I just didnt renew a naranjatech box (NL) with 50gb of storage, 2gb ram, 9554P cpu (1 core) at 24 euro/year. Ping me if you want to take it. Available till black friday.
Does seem to dip its network once a month for a minute or so.
I appreciate it man but, one core just will not cut it. The app is way to heavy for that.
I am going with the ExtraVM offering. They are stable and I have never had a problem with them over the years.
check my offerings on order.noackhosting.se might not be all u want but there might be codes available
Mikael Krantz
email: [email protected] [email protected] [email protected] No Ack Infrastruktur AB aka No Ack Hosting
We are always available and happy to help - link in sig
Less cores than yeti would like, but both are all his. RAM and dik are also enlarged to yeti standards:
4 dedi cores (2× bigger plan) is also available for $8/mo.
Been with them for 3 years.
Should yeti decide this one isn't cool enough for some unknown reason, they have a cool 7 day money back guarantee.
☰ Black Friday Storage — AMD EPYC VDS (ref), up to 4TB NVMe / NVMe + big HDD VPS (ref) from $2.29/TB/mo / Storage/GPU dedis (ref)
Check order.noackhosting.se we do have all u need and cheap
Mikael Krantz
Calm down, one was enough.
At least fucking use https:// so most browser gonna handle it as link if you can't create a proper link with markup.
well https is per default copy paste url
https://order.noackhosting.se
Mikael Krantz
Which one of your offer meets the OPs requirement? $5 USD is about 46.12 Swedish Krona.
If the answer is none, either post a custom offer that matches or is close to the OPs requirements or dont post. No time to sift through your website when it's useless for OP.
There is a code just have to find it or ask me for it and its 52% off
Mikael Krantz
OK I listen and I fix
https://order.noackhosting.se/?cmd=cart&action=add&id=844
Specifications:
CPU: 4 Core
RAM: 4 GB (4096 MB)
Disk Space: 100 GB SSD (Additional storage options available for large data requirements)
IPv4: 1 Address
IPv6: 1 Address
Network Interface: 10Gbit
50 SEK /month = 4.65 EURO 5.42 USD
Mikael Krantz
Can order additional disk per 1TB for 700 SEK /Year on nfs storage. 75 USD 65 Euro let support know and we can arrange it
Mikael Krantz
