SYN-ACK reflection attacks
Is there anything that can be done to prevent your server from being used in a SYN-ACK reflection attack?
It's just a few packets per seconds, and if you wouldn't look for it, you wouldn't really notice...
  • AuroraZeroAuroraZero Retired
    Yeah most modern kernels have this on by default.
    sysctl -w net.ipv4.tcp_syncookies=1
    Prevent half open connections not a real fix but helps to not waste resources.
    The real fix is this:
    iptables -A INPUT -m conntrack --ctstate INVALID -j DROP
    Drop invalid packets that do not make sense in the context of a real connection.
    Sorry for the formatting on mobile and doing 100 things at one time I apologise.
    Thanked by (3)host_c skorous Ympker
    edited 5:13PM
    See, only experienced guys do 100 things at once, todlers get stuck at 98. =)
    So, may I step in and help, so you can advance to 101 things to do at once ? :3 :
    I would do this:
    iptables -A INPUT -m conntrack --ctstate ESTABLISHED,RELATED -j ACCEPT
    iptables -A INPUT -p tcp --tcp-flags SYN,ACK SYN,ACK -m conntrack --ctstate NEW -j DROP
    iptables -A INPUT -p tcp --syn -m conntrack --ctstate NEW -j ACCEPT
    iptables -A INPUT -j DROP
    Thanked by (1)atomi
    Don't think that actually helps. Maybe I wasn't entirely clear about what I am worried about. Not so much worried about the resource consumption on my own server, but about the server being used in the attack to amplify the (spoofed) traffic (by a factor of 5 - i.e. for each spoofed SYN packet, the server sends 5 SYN-ACK packets).
    My mistake
    Strict rp filters
    Lower synak retries
    Optional rate limit your synack
