Most are yearly plans, some are triennial plans
So the number will not decrease any time soon
28 servers? You're basically running your own ISP at this point! The struggle of "good deals" is real.
28 VPS is not much. 28 dedicated servers, yes. So which is it?
Only 4 dedicated / 24 vps
24 VPS are on the 4 dedicated? Or elsewhere?
Elsewhere. That’s the problem
Unless you need the geo, transfer all of the vps on a big dedi. Makes life much easier
I think I'm at ~20+ dedi and 75+ vps, not counting the VMs I run on the dedis. Most stuff sits idle. Might eventually do a freevps type thing with some of the capacity.
I got a slightly newer shitbox to migrate all of my KVMs to. I've been paying for it since November, but I was kept busy, and now with Lent looming on the horizon, that work is taking up far too much time for me to care right now.
