Cloudcone hacked
As information from OGF and Nodeseek.
Cloudcone was hacked, but no more infos given yet.
https://cdn.nodeimage.com/i/xxi1urTNiu6mmWas5hP0XFCBj1HHI9CZ.webp
Any official message?
!! does anyone know what backend they were using? i wonder if there's a vulnerability
They had bespoke/in-house backend.
I feel bad for them.
The stuff of nightmares.
TierHive - Hourly VPS - NAT Native - /24 per customer - Lab in the cloud - Free to try. | I am Anthony Smith
https://status.cloudcone.com/incidents/346624
Issue
We have identified an outage on our services, at this stage, some services should be facing network timeouts
Our network engineers and sysadmins are investigating the issue at the moment.
January 30, 2026 · 08:48 AM
I can't login into client area.
It would be sad to see them go - I really liked @Cloudcone for their client area and services provided so far.
https://status.cloudcone.com/incidents/346624#activity-id-714050
What We First Observed
We were initially alerted to the incident when our monitoring systems detected that several VMs lost network connectivity. Upon investigating, we found ransom messages being displayed at boot on all of the affected VMs.
Our engineering teams immediately isolated the affected servers and began analysis. During the investigation, we confirmed that the boot sectors of impacted VM disks had been overwritten with the ransom message. We are attempting to recover the data by various means including examining raw block devices, reconstructing partition tables, and searching for intact filesystems.
How the Attack Was Executed
Meanwhile, the team investigating the breach discovered that a remote bash script (which is no longer accessible) had been executed across all affected nodes. Shell histories on those hosts had also been cleared. We performed a thorough review of authentication activity using system journals, rotated log files, login records and auditing data and found no evidence of unauthorized SSH access. All recorded user logins matched known internal accounts.
At this point, we started looking into other infrastructure that could have facilitated this attack and discovered that logs of one of our Virtualizor instances had been cleared from around the time of the incident. This is the Virtualizor instance that all of the affected nodes are connected to.
At this time, based on the available evidence, we believe that the attackers used the “Server Terminal” functionality within Virtualizor to gain shell access to connected nodes and execute the malicious script. This access method does not use SSH, which explains the lack of evidence relating to SSH connectivity, and we also discovered that this doesn’t leave any login records on the nodes (all root level logins are also alerted via emails), explaining why we didn’t find anything out of the ordinary earlier.
Scope of Impact
We use Virtualizor instances to support our VPS services. At this time, we have confirmed that only nodes connected to a single Virtualizor instance were impacted. Nodes attached to our other platforms were not affected.
We also do not store personal or billing information of our users within virtualization platforms such as Virtualizor. Our investigation has found no evidence that customer databases or billing systems were accessed or compromised.
We are currently working on the way forward, and all affected clients shall be emailed, and we apologize for the inconvenience this has caused to all our affected clients.
Its been a while since I used Virtualizor, but from what I remember, it does actually store personal information as standard its sucked over via the API in to the end user profile page, I just used the Virtualizor live demo and verified this
Virtualizor emails customers when reinstall, install and other things happen so this seems a bit odd, not thorwing shade, they have a custom control panel so maybe they have a tight API only intergration, but I have to question:
Just the immediate questions I am asking in my head, while also genuinely feeling the 2nd hand stress they must be under.
So there's an encryption of some kind?
Sounds very secure
No wonder this guy is renewing:
☰ Black Friday Storage — AMD EPYC VDS (ref), up to 4TB NVMe / NVMe + big HDD VPS (ref) from $2.29/TB/mo / Storage/GPU dedis (ref)
CC officials have issued an email stating that attackers have compromised the data, rendering all information irretrievable.
They further assert that attackers cannot access the data, implying that even payment of the ransom would not restore it.
While acknowledging the Virtualizor vulnerability, CC officials maintain that all other security measures remain intact.
No compensation scheme has been proposed.
Is it possible the attacker downloaded all the data before destroying it (and might offer a copy of it)?
It appears unlikely.
Whether you request a decrypted file as proof before paying the ransom or proceed to pay it outright, he will cease all communication with you.
Some customers reported they paid and never heard back?
As far as I can tell from the examples I've seen, no one has yet succeeded in obtaining the decrypted data.
The encryption used is usually one way. So you wont get any data back. Back in the days of windows ransomware it was the same. They will pretend to have a way to decrypt your data, get your money and just stop responding. It's cause they need a software that was used to encrypt your data (which deletes itself to prevent reverse engineering). So to decrypt, you'll also need their "decryption software", which also runs the risk of being reverse engineered.
Also, if you already paid them, there is NO obligation for the hacker to do anything else. You wont be doing any chargebacks and "bad feedback" does not matter to hackers. You cant go to court as they are already doing things illegal and you dont have any info on them. So once you pay them, say bye to your money and data.
Now do note that there "may" be cases where the hacker returns the data, but it wont be for small amounts like 100 dollars. If it's a large corpo willing to pay 100k or more, thæn hacker have an incentive to return the data to show to the next "client" that they will return data if they are paid.
Amadex • Hosting Forums • root.hr
It depends on the ransomware, there were a bunch of Windows ransomware that did actually have legitimate decryption tools:
In general, it's more beneficial for the attacker to decrypt files after payment because it encourages more people to pay the ransom. For example, I'm sure more people would have paid the ransom if people were successfully getting their files decrypted on LE* and other forums.
But, some attackers may just not bother with this.
