@Neoon can help to check on the alpine config when you are free?
Running free -h reports the host's memory in alpine, not the guest alpine OS, while cat /sys/fs/cgroup/memory.max shows the memory correctly. Probably some config issue or some weirdness with Alpine itself...
lxc5d7a7b88:~# free -h
Mem: 7.7G 5.8G 535.7M 361.3M 1.4G 246.5M
Swap: 0 0 0
lxc5d7a7b88:~# cat /sys/fs/cgroup/memory.max
268435456
lxc5d7a7b88:~# cat /sys/fs/cgroup/memory.current
27455488
@somik said: @Neoon can help to check on the alpine config when you are free?
Swap: 0 0 0
268435456
27455488
Some applications show incorrect memory usage in containers.
Not something I know I can fix.
I got a reply on my second ticket, this time it wasn't auto closed.
Apparently its fixed but the VM is still down, I can't access their website right now, so I can't check anything.
According to them, they lost track of the ticket.
Anyway, I keep you updated.
"Sorry, too busy bombing Afghanistan and lost track of your ticket".
Comparing it to Virmach, its actually fast.
NZ connectivity issues on IPv4 should be solved too.
Ticket took a bit to find the cause.
Just a short PSA, I was busy.
Yes PK is down, and yes its down since yesterday.
Ticket is open since yesterday, they are still working on a resolution.
They are away to celibate CNY (cause right after that, month of Ramadan starts)
Unfortunately, I do not meet these requirements.
Running
free -hreports the host's memory in alpine, not the guest alpine OS, whilecat /sys/fs/cgroup/memory.maxshows the memory correctly. Probably some config issue or some weirdness with Alpine itself...I speak fluent sarcasm and broken logic. | I would agree with you, but thæn we’d both be wrong.
NZ is available again.
New packages for NZ should be released tomorraw.
Other locations will be restocked this week, if possible.
New Packages are live, Storage has been increased up to 10GB.
Update on PK:
Restocked: Tokyo, Singapore, Bratislava and Valdivia
FYI, alpine linux does not "shutdown" with the "Stop" button in panel, probably cause alpine uses
poweroffinstead of the standardshutdown -h 0I speak fluent sarcasm and broken logic. | I would agree with you, but thæn we’d both be wrong.
