TierHive | 128MB Ram - 1 GB Disk = $6 for 5 Years! (yes actually) | Hourly VPS | FREE to try.
AnthonySmith
ModeratorHosting ProviderOGSenpai
Go here and play with the sliders, build your own package: TierHive
vCPU: 1vCPU for upto 2048MB then anything over gets 2vCPU
Ram: 128MB upto 4096MB - 128mb incrememnts
Disk (NVMe): 1GB upto 50GB - 1GB Increments
Disk (HDD): 1GB upto 4000GB - 1GB increments
Disk (Network): 1GB upto 100GB - 1GB Increments
Free HAProxy, Load balancing, Failover, SSL, SQL Offload, Email relay
Actual hourly billing with 1 hour minimum
Meshed NAT, each user gets a /24 from 10.0.0.0/8 you can use your /24 over all locations and all your VPS can talk to each other over the mesh no matter the location.
For the rest of February, the minimum top-up is $3 instead of $5, credit never expires, services auto stop when you run out, you have around 3 days to recover, after that they are deleted, we auto cancel debt, so you will never owe anything.
We are privacy-focused, we don't want your ID or personal details, the free trial credit does not require a credit card or validation, its enough to get you running for a few hours or a few days or weeks, depending on what you deploy.
Locations:
- Canada East
- Kansas, MO, USA
- London, UK
- Frankfurt, DE
You can self-migrate your own server in most instances. Big HDD storage is only available in London right now, working on S3 compatibility before we also roll out big storage in the USA.
Cheers!
I need classic Openvz 6 to make my kernel run with 128 MB.
We have Alpine and freedos you will be fine!
TierHive - Hourly VPS - NAT Native - /24 per customer - DE, UK, SG, CA, USA.
FREE tokens on sign up, try before you buy. | Join us on Reddit
Would you consider significantly increasing sql offload size (30-50gb) or is that way beyond the scope of this project?
CPU (vCores): 1 vCPU
CPU Priority: High Priority
RAM: 1024 MB
Fast Disk (NVMe): 11 GB
IOPS Tier: High Performance
Network Tier: High Performance
VPS Resources: 0.001232 tokens/hr
Total Hourly Cost: 0.001232 tokens/hr
Monthly Estimate: ~0.8991 tokens
Interesting little setup. cpu steal was pretty reasonable even as yabs was running - 3% ish, but iowait spiked to around 50%
Will be interesting to see how it does under normal use tho!
I think it's likely to move to a charge based on space and activities in the long run without a specific limit, but for now to be honest I am being held back from cutting it completely.
So few people are using it compared to the overall customer base, but still not even out of month 3 yet I keep getting reminded.
So it needs a rethink, redesign, revamp or just more time, it's not worth the maintenance overhead. But you know that's what an ALPHA is for, testing and learning what you need to fix.
Do you actually have a database that size you need hosting for that you would be happy to have on none critical infrastructure? I might be able to help you out with it as long as expectations are realistic.
Haha yeah iowait would always spike as you are being artificially limited after your initial burst.
That's the sign of a very curious or very patient person to run yabs on TierHive haha.
But no IPv6?
Not yet, we will have Ipv6 in when we get to Beta.
We want to make sure it's done in a platform appropriate way.
So no suspension on CPU and I/O at 100% all the time, just throttling?
best of "yoursunny lore" by Google AI 🤣 affbrr
Basically, yes, but your priority will just get lower and lower and lower IF doing this causes contention for other users on the same or a higher tier as you.
I am from Vietnam and get this message:
I work at https://osd.vn. I work for https://thienphat.com.vn and https://luatsuanviet.com
In the other thread you say:
But, NetBSD is missing... Any chance/interest in adding that?
Oh dear, you are right it is set to admin only on our side, I will ask my colleague why he did that, I assume it's a good reason.
You can boot to rescue and use netbook.xyz to install it in the meantime time if that helps or pick no os and chain load it via ipxe.
We had the template live, I will find out why it's not and when it will be back on Monday.
Sorry about that.
